Tip & How-To about Office Equipment & Supplies
How to fix print problems on Epson All-In-One Inkjet printers.
When your Epson Inkjet printer outputs paper with nothing printed on it you have one of two problems. Either your cartridge is empty and needs replaced or your driver is corrupt and needs reinstalled.
If the cartridge has been replaced you probably do not have a catridge issue.
To establish which problem you have print a test page from the printer. You need to hold down the cartridge button while turning the unit on. This works on most Epson printers but if it does not work for you, try holding down the next button while turning on and keep changing the button you hold down until the unit prints a test page. You will be able to tell when you have the correct button as the lights will continue flashing until the page prints.
If the test page prints OK, you need to install a new driver. You can do it with the disc that came with the unit but it would be better to go to the Epson website and download the newest driver. They have probably corrected what caused your problem in the first place. The website and driver is located at http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes&expansion=0100000 .
Using their search engine plug in your model number and follow the download instructions. Install the software, shutdown and restart your computer and you should be back in business. If during the test page print you get nothing on the paper, I would replace the inkjet cartridge.
hardrocko
Thanks for using FixYa
Epson Sx415 New Cartridge,empty already?!?!
1. New original ink tank will dried for several times of head cleaning procedure.
. ....ran a nozzle check and cleaned print heads because it wasn't printing any ink on the paper.... ???
Nothing at all? If yes, problem is in the printer main board. Lost electricity to the head.
Jan 13, 2013 | Epson Office Equipment & Supplies
epson stylus s20 problem. Printer will not print if just one of the four colour cartridge is empty. Can the printer be programed to print with what cartridges are avalible? The printer message does not say that a cartridge is empty but that it is 'not recognised'.
Unfortunately, all cartridges must be used in unison. In order to print one color you can usually go into your settings and set it to black and white only, but some models will not even do this. To be frank, these Epson models have a horrific reputation on the Internet for not recognizing cartridges, only printing 10's of pages before the ink runs out, and just general overall problems. I am sorry, but I would professionally suggest buying the cheapest Kodak/HP/Brother at Wal-Mart over even trying to troubleshoot this model at all.
Oct 22, 2009 | Epson Stylus S20 InkJet Photo Printer...
bad printing after changing 2 inks also clicking noise not before
shouldn't be the ink. I assume you have an epson as in the picture. my ink refill kit mentions that "epson intellidge chipped cartridges" require an "ink level resetter" to complete the kit. So if you have these cartridges even once refilled the chip tells the printer the cartridge is still empty so you'll need to reset the chip with the ink level resetter.
Aug 20, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Acts like it's printing, ink is good, but nothing prints out on paper.
Nothing at all? Poor you are. The pump may damage or lost electricity.
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Epson Stylus Photo R220 InkJet Problem
this sounds like ur both cartridges are empty...
Jul 28, 2008 | Epson Stylus 880 InkJet Color Printer
196 people viewed this tip
jasbo
jasbo
