Tip & How-To about Audio Players & Recorders
Watch Blu-ray and DVD movies on Palm Pre Plus with your desired file size
One feature of smart phones is that enables users to play back digital video and audio on the go, here we just focus on the newly released Palm Pre Plus. This little device has a vivid and bright capacitive touch screen, which is made out of hard plastic, although not as good as glass, holds up fine. The screen is 3.1 inch, at 320 x 480 pixels, with multitouch capabilities. Besides this, Palm Pre Plus has doubled internal memory from 8GB to 16GB, so you can store more videos, music, and photos on it, and access them whenever and wherever at will.
To enjoy Blu-ray and DVD movies on the Pre Plus, two things you need consider: firstly, the file format, secondly, the capacity of your device. First off, let’s see the Pre Plus supported file formats:
Playback Digital Video Formats: H.264, MPEG-4, H.263 video and AMR audio
Supported Digital Audio Standards: AAC, AMR, MP3, WAV, AAC +, eAAC+
In addition to copy protections (CSS, AACS, BD+), DVD movies, especially the Blu-rays always has large file size, so we need a tool to assist us to remove protections as well as compress file size, or select a specific clip for playback. When it refers to this function, Pavtube Blu-Ray Ripper is recommended.
Part one: About Pavtube Blu-Ray Ripper:
It is an all-in-one Blu-ray and DVD ripper, converter and editor. With this application you can directly rip Blu-ray and protected DVD movie from the discs without other decryption software and convert them to compatible video and audio formats to transfer to Palm Pre Plus, iPod, iPhone, PSP, Apple TV, Blackberry, Gphone, 3GP, Zune, Xbox 360, Creative Zen, Archos, Nokia, DV, Adobe Premiere, Sony Vegas etc for playback and editing.
It supports both HD and SD output formats and allows you to customize video size, aspect ratio, bitrate, frame rate, audio channel, etc. Movie collectors would be glad to find that Pavtube Blu-ray Ripper removes the protections of Blu-Ray movies and protected DVD when back them up for collection.
The ripper handles all versions of Blu-ray discs/DVDs, and allows you to select your desired subtitle and audio track, so you will never miss *********** language.
Part two: How to rip Blu-ray and DVD movies for Palm Pre Plus with your required file size
Step 1: Launch Pavtube Blu-Ray ripper and import Blu-ray/DVD files to it
There are three ways to load Blu-ray and DVD files: through "DVD Rom", "DVD Folder" and "IFO/ISO".
Step 2: Select output format for Palm Pre Plus
Since Palm Pre Plus supports playback H.264, MPEG-4, H.263 video, here I choose "H.264 Video (*.mp4)" as output format.
Step 3: Customize file quality and file size
Click "Settings" button, and then the following interface will show up, on which you are able to adjust bit rate, frame rate, sample rate, aspect ratio, etc. to make control of the output file size and quality. To compress the file size, what you should do is changing the figures of these options to be smaller only. One more thing you must be sure that there will be some quality loss if you compress them to be a much smaller size, which means you’d better make a balance between the size and image quality. At least the output video quality should be acceptable by yourselves.
Step 4: Start Blu-ray/DVD ripping
As long as the former three steps are set well, then you can click "Convert" button to start Blu-ray/DVD ripping. Once finished, you can find out the output files via clicking "Open" button. After that the generated files are prepared for playback on your Palm Pre Plus.
Additional tips:
How to select a specific video duration to rip
You can click on the "Edit" button on the main interface firstly, and then click on "Trim" icon. After that you can drag the slider bars below the preview window to mark the beginning and the end of your clip during the preview, or you can input the certain time into "Start" and "End" boxes directly to do your selections.
For more: http://www.pavtube.com/blu-ray-ripper/
Hello there, I bought my Palm Pre in Germany, sadly without the manual. I found out that I could not get it paired up with other phones and transfer music by Bluetooth. This is still the case five months after purchase. I'd appreciate it if you could tell me how to solve this problem. Best wishes, Nat
Hello, Natking04 -
It seems there is more than just one version of the Palm Pre. It would help to know what version yours is:
- Palm Pre
- Pre Plus
- Pre 2
- HP Pre
You can add information to your question with the Comment feature.
Also, are you in the USA now? Fixya.com receives questions from people all over the world and some answers are dependent upon knowing where the questioner resides.
Until I know more, this is the link to the Palm Pre user manual:
https://support.sprint.com/global/pdf/user_guides/palm/pre/palm_pre_ug.pdf
You also may find the information here helpful:
https://www.safaribooksonline.com/library/view/palm-pre-the/9780596806835/ch01.html
Jan 14, 2018 | Palm Pre Cell Phone
257 people viewed this tip
 Grubhead
Grubhead
