Tip & How-To about Heating & Cooling
Save cost with some precautions
Precautions to be taken in air conditioners and to save cost.
These are some useful precautions to be taken in air conditioners (A/C).Improper refrigerant charge can damage your compressor, which is the heart of your air conditioning system; this is an expensive air conditioner repair. Systems improperly charged will cause increased electric bills because this will reduce the efficiency of your air conditioning system. The proper refrigerant charge will provide longer equipment life, lower your utility bills and reduce the need for air conditioning service.
A dirty condenser coil (outside unit) will reduce your air conditioning systems ability to remove and reject heat from your home. This will cause your system to run longer and increase your electric bills. The benefit of a clean condenser coil is proper heat rejection, reduced run time and lower energy bills. A dirty air conditioning condenser can lead to system failure and the need for you air conditioner to be repaired, dirt and house dust that escapes through your air conditioning filter can cling to the cold moist coil. This will restrict the air flow through the coil reducing your air conditioning system of performance and capacity. Maintaining the evaporator coil will ensure that proper air flow is delivered to all areas of your home, increase comfort levels, provide a cleaner healthier indoor environment. Inspecting and changing your air filter on a monthly basis will help prevent air conditioner repairs.
As your air conditioning system removes heat from your home, humidity is extracted from the air. The condensation created by warmer air passing over a cold coil must be drained from your system. This is done through a condensate drain line. The drain must be checked and cleared of algae build up or foreign particles clogging the drain, which could cause water damage to the ceiling or floors of your home. By keeping your air conditioner drain line clear you will reduce the need for air conditioning service and overflow problems which can result in water damage. Proper draining will also aid in maintaining indoor humidity levels.
Cause of air flow
Dirty blower wheels can affect the air flow to your home; limit your air conditioning system's capacity and your comfort. It can also spread dust particles which irritate sinus and allergies. A clean blower wheel and fan motor will provide maximum air flow, improved comfort levels and proper cooling. Most of air conditioner repairs are caused by dirt and the lack of maintenance.
Cause of electrical panel
Your thermostat should be properly calibrated. This will ensure accurate temperature control and operating cycle. This will save you on operating cost and assure your comfort level. Moving parts in need of lubrication can cause increased electrical consumption and air conditioner repairs. This is due to additional power required to overcome the resistance in motors and drive shafts that are not lubricated. Proper system lubrication will offer smooth motor and shaft operation, extended part life and less air conditioner repairs. The electrical components on your air conditioning system should be inspected regularly for signs of wear. Faulty electrical components can lead to very expensive air conditioning repairs. A thorough inspection will reduce the need for air conditioner service if the faulty or worn parts are replaced when found.
Carrying this tips help reduce the amount of air conditioner repairs you will encounter over your air conditioning systems lifespan. If you are in need of air conditioner service make sure the company you choose is licensed and insured to do the required repair work (warranty) .
Heating & Cooling Logo
need to replace gas valve. is this something I can do myself
If you have the proper tools, are mechanical and can get the gas valve yes you can. However there are precautions that need to be taken when dealing with replacing gas components.
Shut it off gas to device before doing any work, ventilate the area of gas vapors when disconnecting the gas device, use the proper fittings and pipe lubricant for the gas device being replaced, ensure the install is according to code, and purgthe line while tightening up the connections. Finally do a soap bubble test on all the joints you tightened with the main gas valve on to the device to check for leaks. Make sure you installed the gas device according to code. you can call the city inspection dept and talk with them to ensure you are in compliance,
Jan 19, 2016 | Heating & Cooling
what special tool is required to remove the air bag or can it simply be done using a flat pry bar??
Hi there jwhyrich,
Stop, hold everything, do nothing.
You have not said whether or not it has been deployed or what your goal is here. But one thing I do know is that these devices are dangerous. They don't hit you like a fluffy pillow. Premature deployment of an unanchored airbag can be deadly.
Even if you are extracting a previously deployed airbag and have no intention of replacing it, consider, 'is this the only air bag in the car'?
I will get into how they are removed after my mandatory (imposed by me) list of precautions.
Click here for a list of precautions. Read them. Read them again and take them seriously.
I'll repeat a statement from the link. Taking these precautions does not make them safe, it lets a person handle them with a higher degree of safety.
Now if you've read and understand the precautions, the special tool is a screw driver. Four screws hold it in.
Best regard and be safe
Mike
Nov 11, 2010 | 1998 Chevrolet Monte Carlo
No longer blows cold air and the unit is only 15 months old
First please clean the air filter and ensure that there is no dust settled on the filter which could chock the circulation of air.
To throw cool air the unit got to **** the air from the room and in case the air filter is blocked with dust then there will be no cooling at all.
Please ensure the thermostat knob is turned to the desired cooling level and try running the unit.
Ensure there is no escape route for the cool breeze.
Minimize the frequency of the door or window opening in the area to retain cooling efficiency.
I am sure your unit will work on taking the above precautions before operating it.
Jul 08, 2009 | Haier CPRD12XH7 Air Conditioner
Air hammer tips
Always keep in mind that air hammers are extremely powerful tools. Thus, particular safety precautions should be taken when using them. Be certain to wear safety equipment such as safety glasses and earplugs. Also, when changing the air hammer's bits, always be sure to unplug the air hammer first. Finally when using an air hammer, always be aware of the position of the tool and work piece. The tremendous force that the air hammer exerts can cause the tool or work piece to jump powerfully. This movement could easily cause injury to the operator.
Aug 27, 2008 | Ingersoll Rand Air Hammer 2 9/32" Stroke,...
422 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
