Tip & How-To about Computers & Internet
How to fix a dead microwave.
Your unit is dead, mains are good, tried power plug in other receptacles, still no power. You have a bad fuse inside the unit. Unplug the unit. Remove the cover. Generally this requires removing all the screws on the back perimeter and lifting the cover up. Sometimes they stick due to old grease, etc. Somewhere in the area of where the power cord comes in, or near the transformer there should be a small fuse in a holder. It is not a glass fuse and should be replaced with the same kind (ceramic) and value. This is important for future protection. You can get the fuse at www.mcmelectronics.com . Get a box of five for future problems. If this was the only problem your microwave should work. If it blows the new fuse you could have a shorted power transformer, bad high voltage diode, or a bad magnatron in that order. There could also be a short in the board with the display but that would be unusual.
hardrocko
Thanks for using FixYa
Computers & Internet Logo
My jmc7000 jenn-air blew a circuit breaker. No power to the unit. There is power to the recepticle. I'm wondering if it blew a circuit breaker, does that mean the problem is most likely a big problem and I maybe better off replacing the unit, or is that not necessarily a big deal just because it blew a breaker. Any idea if I should replace or repair? The unit is 10 years old. Thanks
Yau say a few conflicting things. First you wonder if it blew a breaker, and then say you have power to the receptacle. If you have poer to your receptacle your breaker if not tripped. There are NO breakers Inside of the Microwave. Only 1 time fuses. So, if your init is dead it has probably blown a fuse inside of the unit. If that is the case. Probably shorted HIgh volt capacitor would be my first guess. If it is jsut dead. it can be other things than just a blown fuse. bad thermal protectors, bad low voltage transformer on main circuit board. Burnt wires. Anything that will cause it to lose power inside the unit. From bad parts to bad connections.
Aug 16, 2017 | Jenn-Air JMC7000 Microwave Oven
when plugged into outlet will not turn on panasonic viera 42 inch
Power supply board is dead.Tries wbsites Shopjimmy.com,Ebay.com to buy a refurbish power supply board to replacement.
Mar 13, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
No lights - no power - DEAD! Worked fine an hour earlier now ... nothing. Check fuse in mains box - all OK - tried it plugged into another outlet... nothing.
Your unit is dead, mains are good, tried in other receptacles, still no power. You have a bad fuse inside the unit. Unplug. Remove the cover. Generally this requires removing all the screws on the back perimeter and lifting the cover up. Sometimes they stick due to old grease, etc. Somewhere in the area of where the power cord comes in or near the transformer there should be a small fuse in a holder. It is not a glass fuse and should be replaced with the same kind (ceramic) and value. This is important for future protection. You can get the fuse at www.mcmelectronics.com . Get a box of five for future problems. If this was the only problem your microwave should work. If it blows the new fuse you could have a shorted power transformer, bad high voltage diode, or a bad magnatron in that order. There could also be a short in the board with the display but that would be unusual. Let me know if you need anymore helpl
hardrocko
Feb 26, 2010 | GE Microwave Ovens
electric dryer is totally dead WEC6430A - has
Hello, Remove the back panel from the dryer and test the thermal fuse, it looks like this: 908c006.jpg With and ohms meter take wires off and test for condinuity...if no condinuity replace it, Hope this helps. Good Luck! Mike
Aug 15, 2009 | Whirlpool Dryers
133 people viewed this tip
David Payne
David Payne
