Tip & How-To about Refrigerators
What to Look For in a Refrigerator
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Refrigerator Buying Guide
Buying a refrigerator is an issue that is too complicated to many types of refrigerators that are available today. The function of refrigerator has actually gone beyond the basic of keeping food cooled and chilled. There are features that are equipped in most advanced refrigerators now. Therefore, choosing the right one that suits your family will take some time and require some basic knowledge on refrigerators. Here are a couple of things that you need to look out when buying a refrigerator.
The first thing that you need to decide is the capacity when it comes to buying a refrigerator. The rule of thumb here is to go with the general guideline where a family of two needs at least 10 cubic feet of fresh foot storage. You can add extra cubic feet for additional person in your family. Therefore, an 18-cubic-foot refrigerator is the smallest unit that you should get for a couple. A family of four needs at least a 22-cubic-foot refrigerator. Of course, if you can afford bigger refrigerator, the better it is. But be reminded that it takes more electricity to operate a bigger refrigerator which leads to higher electricity bill.
Adding to the capacity, the size of the refrigerator is also important. The size can sometimes be a limiting factor in determining the refrigerator that you want to buy. In a case of a family that needs a 22-cubic-foot refrigerator but the space in your kitchen can only accommodate an 18-cubic-foot unit. If that is the case, you should probably make some space by removing certain items in the kitchen to fit the 22-cubit-foot refrigerator. Or else you can consider a side by side refrigerator if space is a concern. A side by side refrigerator consists of a freezer that is adjacent to the refrigerator. The advantage of side by side refrigerator is that it needs less door clearance which makes it ideal for a narrow kitchen.
Other factor to consider when buying a refrigerator is to select the type that suits your living style. There are several types of popular refrigerators in the market ranging from the commonly used top freezer, bottom freezer, side by side to the exotic French door unit. The top freezer is the most commonly seen refrigerator due to its affordability and simple design. Besides, the top freezer is also the one that has the least problem. Therefore, reliability issue seldom exists in top freezer refrigerator.
The bottom freezer model is equally comparable to top freezer but it's slightly more expensive. The advantage of bottom freezer lies in the convenience where more frequently used storages are placed at eye level. It's claimed that people with back pain problem should use the bottom freezer refrigerator to alleviate the back pain since you don't have to bend to access the food in the refrigerator.However, people will sometimes accommodate a side by side refrigerator in their kitchen. One of the reasons behind it is that, these refrigerators are often equipped with plenty of extra sophisticated features that offer loads of conveniences to its users. Other reason might be due to the exotic look of these types of refrigerators instead of the normal top and bottom freezer units.
Note, if you planned to get a refrigerator that is more than 22 cubic feet in capacity, consider one which is Energy Star qualified. An Energy Star qualified refrigerator means energy efficiency. An energy efficient refrigerator is very conservative in terms of electricity usage and it might help you to save some utility cost. One thing for sure is that you might be able to get rebates of up to a few hundred dollars for trading in your old refrigerator with a new Energy Star qualified model. A lot of utilities companies and even the local government do offer this kind of rebates. Therefore, do enquire the sales persons when you are in the stores.
All in all, buying a refrigerator is not that of a difficult task. All you need is some practice and some basic knowledge in refrigerator. Please whenever you really want to buy a refrigerator , make sure that you have done some research on the model that you are looking for ,the things that you want to look out and the cost of purchasing and the features so that when you are at the store, you will really go for your choice from your re-search.
Refrigerators Logo
is it worth buying
if you need a refrigeretor, it's worh buying ONE. Now, the question is the Brand you might be interested. Some are better then others.
You might be interested about information on TOP Refriegerators in these reports for consumers: You even can look for more info, doing a google dearch for TOP REFRIGERATORS
Top Freezer Refrigerators
2014 Best of Year Refrigerator Awards
Aug 13, 2015 | Refrigerators
control board has no lights or power
Hello Todd Line - Often when the refrigerator is inoperable and has no LED lights, it is because it could be something as simple as a damaged cord or an issue more complicated that requires the help of a professional. Check that the household circuit breaker has not been tripped or that any fuses are blown. Also, try reprogramming the refrigerator by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the fuses are working fine, however issue persists, then the refrigerator may be experiencing some form of a sealed system issue or a faulty electronic control board. At this point, I would personally recommend contacting a certified technician to accurately diagnose the unit to determine the root cause to reduce the risk of unnecessary parts.
Mar 20, 2013 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
I have a Hotpoint HSS25GFPH white side by side refrigerator. We're buying a new house with black appliances. I don't want to buy a new refrigerator so I'm contemplating painting the whit
Paint? unless you have a spray booth, and are good at such things, I would avoid that...
I would go with a vinyl or similar adhesive sticker. There are companies that do whole fridge front stickers with artwork/nature pictures etc. Google "refrigerator stickers" and you might find one that will do, just plain black.
Apr 24, 2012 | Hotpoint HSS25GFP Side by Side...
refrigerator light won't turn off
Either the doors are not closing properly, or the door-light switch is bad. Though I would not be at all surprised that it is a more complicated issue such as a motherboard since it is an LG (low grade) refrigerator.
Jul 28, 2010 | LG Refrigerators
Water dispenser just stopped working. We changed the filter but made no difference. You could hear the new filter fill with water but when you press the dispenser button on the door nothing happens. LG LRFD22850ST
This is probably a service call issue. The lines could be bad. The dispenser could be bad. You will be playing :poke and hope" and buying parts you don't need. The system is complicated and needs to be diagnosed by an authorized tech.
Jan 24, 2010 | LG LRFD22850ST French Door 22.4 Cu. Ft....
239 people viewed this tip
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
