Tip & How-To about Computers & Internet
How to set up you wireless router to use a wireless network.
From a wired connection open you internet browser and type in 192.168.1.1 . The user name or password is usually "admin" or the password is sometimes blank. Once you log in you should change you network name from the default. For example a Linksys router's network name will be Linksys, this is fine unless someone else in you area has the same network name then neither of you will be able to connect.
To set up a wireless security you will need to select the type of security you want to use WPA or WEP and so. WPA is easier to remember as it is just a word you choose, while WEP generates a key based on a word you enter. If you do not set up a key you wireless network will be listed a unsecured.
If you set up a network key make sure to write it down, you will need it for every computer that wants to connect to your network.
If you are still not able to connect to the internet go back to the router menu via you internet brouser again. this time change the last letters of the default server. example 192.168.1.1 --> 192.168.1.4
Computers & Internet Logo
How to connect to nintendo wifi connection?
sir first connect your router with a lan cable with a computer then open the internet browser and type the ip in the address bar it must be 192.168.0.100 and then type the user name :admin password : admin then go to configure tab then type ip of your internet provider, you can check it by connecting your pc to the internet and then open the network connection/status/support. type that ip into your dns server and select the password what ever you want and save and reboot it it will work fine thank you
Apr 16, 2012 | Computers & Internet
How do I get into the routers homepage to change some settings so I can run a wireless internet connection to my laptop while my Playstation is hard wired. I have DGL 4500
To get into the D-Link DGL 4500 router homepage, simply open an internet browser window and type in the following address:
http://192.168.0.1 and press Enter.
When the login window appears, set the user name to Admin and leave the password box empty.
Then, click Login to continue.
Here is the link to the PDF version of the User Manual:
http://www.dlink.com/-/media/Consumer_Products/DGL/DGL%204500/Manual/DGL%204500_Manual_EN_US.pdf
Jul 29, 2011 | D-Link DGL-4500 Wireless Router
please i would like to know how to configure the alvarion radio wireless acess point . thanx!
YOU CAN SEE YOUR DEFAULT GATEWAY IN NETWORK CONNECTION STATUS COPY THE NUMBERS, OPEN INTERNET EXPLORER TYPE THE NUMBERS IN THE IE WEB BROWSER THEN ENTER.
WHEN ASK USER NAME AND PASSWORD.TRY THIS USER-NAME admin PASS admin OR user-user.
note; you cannot open it in another web browser like Firefox chrome etc. just IE only
Dec 22, 2010 | Alvarion Wireless Access Point
how do i get my password from my linksys
  1. Open a web browser (such as Internet Explorer or Netscape)
  2. When the browser opens, go to the "Address" bar and input the IP address of the Wireless Router (The default IP Address is 192.168.1.1).
  3. A "User Name" and "Password" prompt will appear, leave the "User Name" field blank and input the Wireless Routers password (The default password of a Linksys Router is admin) into the "Password" field.
Jul 10, 2010 | Linksys WRT160N Wireless Router
How do I get into the D Link DI-624 router administration? URL?
If you havn't changed anything in the router - Then open Interner Explorer
In the web address bar type - 192.168.0.1 press enter (or go)
Apr 16, 2008 | Computers & Internet
1,066 people viewed this tip
David Payne
David Payne
