Tip & How-To about Washing Machines
Kenmore Oasis Constant Audible Beep
If you own a Kenmore Oasis washer that has an audible beep that occurs randomly, or remains constant, whether or not the appliance is in use, the following information explains what causes the problem and how to correct it.
This is a common and very well known problem with the Oasis that commonly occurs due to a failed or shorted relay on the operator/user interface board inside the control panel. These boards are not serviceable and usually requires you to replace the operator/user interface to correct the problem. The board is located directly behind the control knob. You can usually order the part at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Just type in your model number and look under the "Control Panel Parts" heading. All these sites are reputable and offer great service with competitive pricing. The first three sites I listed also inlcude helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
If you do not find your model number listed at some of the websites, use the part number you obtain from the Sears website and do a Search by Part Number at the other sites. Sometimes the model number may not be listed, but the parts are still listed. Sears tends to have a more extensive data base of model numbers, but may not always have the better price.
To replace the user interface board, follow these steps:
1. Unplug the washer.
2. Locate and remove the retaining screws in the back of the control panel. With the screws removed, the control panel will lift from the back first, then off. NOTE: Be careful when lifting the panel, there is a small interface cable plugged into the control board.
3. Remove the interface connector and pull the control knob off.
4. Lay entire panel face down on a soft surface (such as some folded towels).
5. Remove the user interface cover (this is item 10 if you use the drawings in the Sears website).
6. With the cover removed, take a small flat blade screwdriver and pry back the tabs that hold the board in place. There will be several around the entire perimeter of the board.
7. Once the old board is removed, carefully insert the new control board making sure you don't put it in upside down. Mark the location of the interface connector plug as a reference. NOTE: Do not handle the surface area of the board with your hands. This can cause damage from electro-static discharge to small components of the board and render it unusable. Hold the board by the edges only.
8. Reinsert the interface cover and flip the control panel over to its upright position.
9. Reinstall the control knob and make sure you plug the interface connector back in.
10. Reinstall control panel by inserting the front edge of the panel into the grooves on the washer top casing and lower it back. Tighten all mounting screws.
This is a pretty simple repair job. The hardest part you may encounter is removing the old board. The small tabs can be difficult to bend sometimes. Also, use care not to apply too much pressure on the new board when you install it. They can be difficult to snap back into place at times. Just take your time.
If you have questions about this repair, please let me know. I hope this information is found to be helpful.
HELPFUL HINT: You may try unplugging the washer and remove the control panel and try cleaning the interface connector to see if this helps BEFORE you order parts. Sometimes it helps.
Washing Machines Logo
kenmore Oasis HT washer, starts water comes out , then nothing but contant beeping and flashing , with an "F" code
Sears are a department store not a manufacturer, they contract other manufacturers to build the appliances for them and these are then sold under the Sears/ Kenmore brand.
To find who made your appliance, check the first three digits of your model number against the list below and this will give you the manufacturer of your appliance. Then the code that you have shown can be determined and know what needs to be replaced or repaired
Amana Caloric D&M Fedders 596.####### 174.#######
960.####### 587.####### 484.####### GE Gibson Jenn Air Kelvinator 362.#######
363.####### 253.####### 629.####### 417.#######
628.#######
662.####### Litton Maycor Roper Speed Queen 747.####### 925.####### 103.#######
155.#######
647.#######
835.#######
911.####### 651.####### Tappan Toshiba WCI Whirlpool 791.####### 562.####### 790.####### 106.#######
110.#######
198.#######
562.#######
665.#######
May 07, 2011 | Kenmore Oasis HE 27082 Top Load Washer
My Kenmore Elite Oasis HE top load washer seems to work fine, but I get a beeping sound about every minute during the wash cycle and after it is complete.
If you are referring to a constant, or random audible beep that occurs whether the washer is running or not, this is a well known problem with the Oasis. The User Interface Control board behind the control panel is the cause. The following links explains the problem in more detail:
http://www.fixya.com/support/r4218022-kenmore_oasis_constant_audible_beep
If the control board connector plug appears to be intact and corrosion free, and unplugging the washer for 30 minutes does not clear the problem, more than likely you will need to replace the user interface.
If you have questions about this repair, please post back and let me know. I hope you find this information helpful.
Jun 28, 2010 | Washing Machines
Kenmore oasis electric dryer beeps and displays code F45
We had this error on our machine for about a year before we finally got sick and tired of it. Our dryer was purchased in 2006.
Here is the solution: the code means there is an error on the thermistor. Our thermistor was loose, as were other electrical wires. My husband tightened up all the connections and the thermistor, and we have never had this error again.
However, we will never buy these machines again either, because we have had numerous other errors on the washer and dryer.
Nov 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
kenmore oasis washer
This is a common problem with the Oasis. The problem is the User Interface Control board behind the control panel. There's a relay on the board that shorts out and causes the washer to randomly (and constantly) beep. This can also occur with the washer turned off. Since the circuit board is not serviceable it is recommended that you replace the control board. Searspartsdirect.com carries replacement parts for your washer. Just type in the model number and search under the console heading for the user interface board. If you are usure which part, I'm talking about, please post back with your model number and I can assist you. I hope this helps.
Aug 08, 2008 | Kenmore Oasis HE 27082 Top Load Washer
3 audible beeps every 20-25 seconds
Try unplugging the washer for about 20 minutes then plug back in and use. I have found that this actually works! The only thing I can figure out is that it takes time for the electronic control to clear. If that doesn't fix the problem I would call sears tech since it is less than a year old. They have a 1-2 year warranty.
Dec 21, 2007 | Kenmore Oasis HE 27062 Top Load Washer
591 people viewed this tip
Top Washing Machines Experts
