Tip & How-To about Panasonic Lumix DMC-TZ50 Digital Camera
Lumix DMC-TZ5 - Adding Time and Date stamp to photos
  • Make sure you have set the date and time correctly on your camera.
  • View the picture you want to Time stamp, by changing left hand slider to green icon.
  • Press the circular 'Menu/Set' button
  • Press down arrow to get to playback mode in the onscreen menu.
  • Press right arrow to access this menu.
  • Press down arrow until 'text stamp' is highlighted.
  • Press right arrow to select.
  • Choose whether to apply stamp to single or multiple photos
  • Press 'Menu/set' to select photo to stamp.
  • Choose which stamps to add. Date, time, age etc..
  • Press 'Menu/set' again and select the 'Yes' box.
The only problem with this is that it will re-size your photos to about 3m, which can make them grainier if you took them at a higher resolution. Unfortunately there is no other way to time stamp your photos on this camera.
Panasonic Lumix DMC-TZ50 Digital Camera Logo
how to seup date and time on the screen when we
Hello Dear,
In all Canon PowerShot and IXUS series cameras date and time can be stamped on the photos shot in Post Card Size, to set the Camera into this mode do the following:
On Camera in Shooting mode (Live view is visible on LCD)
Press Function/Set button once
From right-left move to the Post Card Size
Press Function/Set again.
Now, Press Menu Button
From up-down move down
On Stamp Date (Option Name written, Visible on the Right top Corner of Screen)
From right-left move and select you want only Date or Date and Time both.
Press Menu again
Now, you are ready.
For more clarification please revert.
Warm Regards,
Joseph Manoj
May 22, 2010 | Canon Cameras
manual too difficult
It seems to me, after reading the Operating Instructions, that it's not possible to stamp the photos automatically while taking them (EXCEPT for when stamping TRAVEL DATES - see below).
What you can do is enter the Play mode, the stamp the photos manually- 1 to 50 photos at a time.
To do this, kindly look on pages 66-67 for detailed instructions (with illustrating images).
Be sure to set the correct time and date prior to stamping the photos. Look on page 16 for further instructions.
If you're taking pictures during traveling, you can set TRAVEL DATE, which will also have a reference to the day number of your travel (page 48).
Hope you'll find my information useful...
Good luck,
Pelu.
Apr 09, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
time and date display
I have the same camera and the only way to do this is to first, Make sure you have set the date and time correctly on your camera. Take a picture or View picture you want date & time stamped. Press the circular 'Menu/Set' button Press down arrow to playback mode Press right arrow on 'text stamp' Choose whether to apply stamp to single or multiple photos Press 'Menu/set' to select photo to stamp. Choose which stamps to add. Date, time, age etc.. Press 'Menu/set' again and select 'Yes' in box. The only problem with this is that it will resize your photos to 3m, which can make them grainier if you took them at a higher res. Gillian
Feb 20, 2009 | Panasonic Lumix DMC-TZ50 Digital Camera
how to make date stamp option ON in Canon IXUS70 Model
Hi there, my name is Rob and I can help you.
To put the date stamp in a picture do this:
1) Make sure you have the correct date and time set in the camera. To do this:
Push the function/set button. Press the directional button down to select Date and Time.
Push the directional button to the right then down or up to set the date and time. Then press the function/set button to save it.
Then:
2) Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
Scroll right to turn on the Date and Time Stamp, then up or down to until it says On.
Press function/set when your done.
That is your solution. Remember once the date/time stamp is embedded in a picture, you can't take it out.
Let me know if you have any further questions, and thanks for coming to FixYa. Please feel free to rate my solution a fixya.
Rob
Feb 19, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
TZ 5 not TZ50! Date stamp.
I have the same camera and the only way to do this is to first, Make sure you have set the date and time correctly on your camera. Take a picture or, view picture you want date & time stamped. Press the circular 'Menu/Set' button. Press down arrow to playback mode. Press right arrow on 'text stamp'. Choose whether to apply stamp to single or multiple photos. Press 'Menu/set' to select photo to stamp. Choose which stamps to add. Date, time, age etc.. Press 'Menu/set' again and select 'Yes' in box. The only problem with this is that it will resize your photos to 3m, which can make them grainier if you took them at a higher res. Gillian
Aug 30, 2008 | Panasonic Lumix DMC-TZ50 Digital Camera
3,575 people viewed this tip
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
