Tip & How-To about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front load washer
When you own one of these you need to remember to always take things out of you're pockets. But what you should due is once a year clean out pump assembly. Plus bring in a tech too run a Diagnostic test on you're machine to clear any error codes that might still be on you're machine.
Whirlpool Duet GHW9150P Front Load Washer Logo
how to remove factory stereo
First things first, every car is different. Basically you have to remove the surround from around the radio, it is usually one piece. Look for screws which are always hidden. Pull the surround of which will take a bit of force but remember if it feels like it is stuck look for more screws. Once that is off there should be 4 screws/bolts holding the radio and pocket below it in, remove them and it will be out with the wires still attached.
Jul 15, 2011 | Car Audio & Video
the red light saying CLEAN PUMP is on and i dont no how or what to do please help jodie
Very easy to do FIRST UNPLUG THE WASHER! There should be a access panel on the front which would be a kick panel or on the rear of the unit remove it and you will see a white or tan looking cylinder thing that is the pumps trash collector remove it counter clock wise it may be tight to unscrew but it will might have to man handle it and once removed clean all the gunk out of it and look up into the pump and where the water flows into the trash collector and make sure it is free and open. Once cleaned put back together. This should solve the problem biggest thing with these new machines is people don't clean there pockets out before washing and these new machines arnt like the old ones where the items would sit in the bottom of the basket for you to remove at the end of the wash at least yours tells you to clean the pump instead of a error code but hope this helps and good luck!
Jan 10, 2011 | Washing Machines
how to change water pump
remove radiator fanbelt then water pump you will need a diagram for this, the water pump has from 4 bolts or more depending on year. the main thing is to clean!!!!! the surface good. put gasket and rtv on new pump reverse task. remember to replace coolant. run with radiator cap off but don't drive. when the themostat opens fill. turn off put cap on fill resevoir
Aug 15, 2010 | Chevrolet TrailBlazer Cars & Trucks
I have four blinking lights and it reads clean filter cartridges or call for service. First three lights blink jet one jet two and light and also heat light. All four blink and tub will not heat up. Keeps kicking on making a humming noise and cuts back off. I have cleaned the pump from lime and it ran about 2 hours and does the same thing starts blinking again.
Is your pump actually moving water?
I think you should replace your cartridge filter or at the very least, do a thorough cleaning in accord with the manufacturer instruction.
There is a possibility you have pump impeller damage or there is other problem with the pump.
May 13, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Small items missing from wash, need to access catch
They can be pulled between inner/outer drum..Check clean filter
Nov 02, 2009 | Kenmore HE2 Plus Front Load Washer
2,818 people viewed this tip
Dan Webster
Dan Webster
Sal DeAngelo
