Tip & How-To about Computers & Internet
How to setup WEP on an SMCD3GN Wireless Cable Modem Gateway
1. Log into the router. To do this you will need to open your web browser and enter http://192.168.0.1
2. You will need to log in to the router. The Default Username and Password:
User Login
Username: cusadmin.
Password: password
3. Next click on [WIRELESS] link on the Side Navigation bar.
4. Select [WEP] from the [SecurityMode] drop-down menu.
You can choose between standard 64-bit or 12b-bit encryption keys. Below are the configuration options for 64-bit WEP. A passphrase or a manual key can be used
NOTE: To enter a manual WEP key you will need to enter hexadecimal values (A-F and 0-9). Example: 64-bit hexadecimal keys are exactly 10 characters in length. (123654ACDE is a valid strong of 10 characters for 64-bit encryption).
To automatically generate a 64-bit WEP key, enter in a Passphrase (keyword- ex. homegateway). And click the [Generate Keys] option. Once you do this, the Gateway will dynamically generate 4 keys. Simply configure the Default Key to the one key that you will be using across your network.
5. Select the Open System, Shared Key or Automatic from the [Authentication] drop-down menu. Note in most cases you want it set to Automatic.
For more security, you can use 128-bit WEP encryption. To use this mode, select the [128 bit (26 hex digits)] from theWEP Key Length drop-down menu option and the configuration section will be displayed. 128-bit encryption requires a longer key than 64-bit encryption. Keys are defined by entering in a strong in HEX (hexadecimal- using characters 0-9, A-F) or ASCII (American Standard Code for Information Interchange – alphanumeric characters) format. ASCII format is provided so you can enter a string that is easier to remember. The ASCII string is converted to HEX for use over the network. You can manually enter in the 26-digit hexadecimal key.
Example: 128-bit hexadecimal keys are exactly 26 characters in length. ( 234FEDCBA12340013333389319 is a valid string of 26 characters for 128-bit encryption).
NOTE: If you are having a difficult time getting the wireless connection up after enabling WEP- Please confirm that you have configured the SAME WEP key on both the Gateway and Client card.
6. Click the [Apply] button to save your settings
Computers & Internet Logo
how do i enter code or setup code in my computer
You need to plug in a ethernet cable from a computer to a lan port on the router. Open a command prompt and enter ipconfig make note of the default gateway address. Open a web browser and enter the default gateway. Log into the router and go to the wireless security. Enable wep, wpa or wpa2 and set a password. Enter this password into any computer to connect to your wireless network.
Nov 18, 2013 | Computers & Internet
hello i just baught a playstion3 how do i reset my router cause i forgot the password for the wpa key
chevyjosh815
If you forgot WEP key for your router you just need to log into the router and look up the key. If you do not know the Admin password for your router then you will have to do a hard reset of the router.
The links below are examples of what steps you woudl need to go through to look up the WEP info on your router.
How to setup WEP on a Linksys Wireless-G Broadband Router
How to setup WEP on a Belkin N1 Wireless Router
If you have any questions or problems let me know the make and model of your router so I can better help you.
Issken
http://www.fixya.com/users/issken
Oct 01, 2010 | Sony Playstation 3 (PS3) Console
need to find out my WEP key...how do i do that?
melissa_saen
Your WEP is the security access key for your wireless network so this will be on your wireless router/access point. If you do not know what it is you will need to log into your router to look it up. The links below are some examples of how to access the WEP info on your router.
How to setup WEP on a Belkin N1 Wireless Router F5D8231-4 v5000
If you have trouble let me know the make and model of your router and I can give you the steps to access your WEP settings.
Issken
Sep 09, 2010 | Video Game Consoles & Games
how do i find my wep key?
christian46
The WEP key is the security access key on your wireless router. If you do not know what it is you will have to log into the router and look it up. Below is links to access the WEP on a Belkin and SMC router. IF you do not have those or not those models let me know and I will make a walk through for you. Just let me know the make and model of your router.
Issken
Jun 30, 2010 | Sony PlayStation 3 40GB System
9,866 people viewed this tip
David Payne
David Payne
