Tip & How-To about Cell Phones
How-To get your carrier's network updates without contacting them!!
This is very simple. All you have to do is power your phone completely off for 5 minutes and then power it back on and it will send the updates automatically to the phone and you wont have to do anything!! This works for most if not all carriers.
Cell Phones Logo
LG Rumor 2 turning on and off.
First, make sure if this problem appear after you install any APP, if so you can try to brush system to fix it.
Else maybe the following cases:
1, mobile phone motherboard leakage lead the current too large.
2, The inside circuit protection of the lithium battery is too sensitive, so it power off when circuit is large.
3, the battery itself is aging.
4, Battery contacts are dirt-bit, causing bad power supply.
5, The engagement between the battery and the phone is easy to loose bits. (try to remove the back case and press the battery then try to turn on it to see if it also turn off and on). If so, just make a piece of paper to stand the battery up
Of course, don't forget to see if the power button is back to its own place
Apr 08, 2013 | LG Rumor 2 Cell Phone
how to update software using pc
Use OVI softwARE or upgraind your phone
Jun 29, 2011 | Nokia 3110 Cellular Phone
i want to update my phones software
TO update the phone software you can contact the your mobile care authentic units or one the mobile you go to settings ->phone mgmt->options->software update.
NOTE:you may require internet connectionand data charges may apply
Dec 13, 2010 | Cell Phones
I can't record with my DVD player on 1x-16x DVDs
This unit is too old and too basic to handle 16x speed. However, there is a firmware update for this model DVD/VCR to record on 8x.
All you have to do is call the toll-free number in your manual and request it. They will send you an update disc.
Here is the basic procedure after you receive the update disc:
1. Turn on your TV and your combo unit. The tray should be closed. The unit must be in DVD mode.
2. Quickly press the sequence CM Skip, 6, 5, 4 (This will switch it into firmware update mode. The tray will eject automatically.)
3. Insert the disc and push the tray back in.
4. The update will begin. It will take approx. 2-3 minutes. It will tell you when it is complete and eject the tray.
5. When it is done, remove the disc, but DO NOT close the tray. It will go back in later. Turn the power off.
6. Wait a few minutes and when the tray goes back in wait about another 10 seconds and then you may turn the unit back on.
Firmware update procedure is now completed.
Sep 11, 2009 | Emerson EWR20V4 DVD Recorder/VCR
no text
i had a problem like this and i called tech support, they told me to turn the phone off & then back on... it worked. maybe you should tell your sister to try that too
Nov 05, 2007 | Motorola Mobility MOTORIZR Cellular Phone
85 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
