Tip & How-To about Computers & Internet
How to set up WEP on Linksys Router
Setting-Up 152-Bit WEP Wireless Security on a Linksys Dual-Band A+G Wireless Router
Question
How do I set up 152-Bit WEP on a Linksys Dual-Band A+G Wireless Router?
Answer
Wired Equivalent Privacy (WEP) can be a 64-bit key with 10 hexadecimal digits, a 128-bit WEP key with 26 hexadecimal digits or a 152-bit WEP key with 32 hexadecimal digits. This encryption will prevent other users from connecting to a wireless network using your own WEP key. It will also protect your wireless transmissions/communications from being accessed or received by other users.
NOTE: Make sure to change the wireless settings of either Wireless-A or Wireless-G depending on the standard your network is using.
152-bit WEP key only applies to 5GHz 802.11a Wireless enabled network.
To setup WEP Wireless Security on your Linksys router follow the steps below.
Setting-Up the Linksys Router to use WEP
Step 1:
Access the router’s web-based setup page. For instructions, click here.
Step 2:
When the router’s web-based setup page appears, click Wireless then click WirelessSecurity.
Step 3:
Look for SecurityMode and select WEP.
For Wireless-A Settings:
For Wireless-G Settings:
NOTE: If the screen on your router’s web-based setup page looks different, click here.
Step 4:
Look for the Encryption drop down menu and select 152 bits.
Step 5:
Look for Passphrase and type a wireless network password of your choice, then click Generate. In this example “MySecretKey” was used.
NOTE: You should come up with a password that is unique for your network and is a combination of numbers and letters up to 16 characters.
Step 6:
When you click Generate, the result will be a string of random characters.
Step 7:
Look for TXKey and select any number to determine which key you’ll be using. In this example, we selected 1.
Step 8:
Copy Key1 since 1 was selected under TX Key.
NOTE: Do not give this key to anyone. This will be your wireless network’s key.
Step 9:
Click .
© 2010 Cisco Systems, Inc. All rights reserved.
Computers & Internet Logo
want a secure line
kb19073-001_en.png NOTE: Image may vary depending on the type of router and computer you are using.
To setup your router's wireless security settings:
i. Accessing the web-based setup page
ii. Setting-Up the Wireless Security
Step 1:
Access the router's web-based setup page by opening a web browser. On the Address bar, enter your router's local IP address then press [Enter].
NOTE: The default IP Address of Linksys routers is "192.168.1.1". For instructions on accessing the web-based setup page using a Mac computer, click here.
Step 2:
When the login prompt appears, enter your router's Username and Password.
NOTE: The default password is "admin" and the Username field is left blank. If you have set a password before but forgot it, you need to reset the device. For instructions on how to reset a Linksys router, click here.
Step 3:
On the Setup page, click the Wireless > Wireless Security.
NOTE: If some of the tabs are missing in the web-based setup page, upgrade the firmware of your router. For instructions, click here. You can also set the wireless security of your Linksys E-Series routers with Cisco Connect. To learn how, click here.
On the Wireless Security sub-tab, there are various wireless security options that you can choose from.
However, as mentioned earlier, the three most commonly used security modes are WEP, WPA Personal (or WPA Pre-Shared Key), and WPA2 Personal. The instructions below will show you how to set up the following security modes. On the other hand, the WPA2/WPA Enterprise Mixed Mode, WPA Enterprise, WPA2 Enterprise, and RADIUS security modes will only work if the router is connected to a RADIUS server.
WEP can be a 64-bit key with 10 hexadecimal digits or a 128-bit key with 26 hexadecimal digits. This encryption will prevent other users from connecting to your wireless network. It will also protect your wireless transmissions from being accessed by other users.
NOTE: In case the screen on your router's web-based setup page looks different, click here.
Step 1:
On Security Mode, select WEP.
Step 2:
Under WEP Encryption, select 40 / 64-bit (10 hex digits) and enter a unique word in the Passphrase field.
NOTE: The 128-bit key uses a higher level of encryption compared to the 64 bit WEP. It uses a 104 bit (26 Hex Character).
Step 3:
Click the Generate button and copy the string of letters and numbers displayed in the space provided for Key 1. The Key 1 contains the wireless password.
NOTE: You can also create your own Wireless Password (Key 1) given that it is in hexadecimal format. The hexadecimal system consists of the characters 0,1,2,3,4,5,6,7,8,9,A,B,C,D,E, and F. You can only choose 10 characters (in any given order) from that set.
Step 4:
Click kb19073-007_en.png.
Wi-Fi Protected Access (WPA)
Wi-Fi Protected Access (WPA) is a Wi-Fi standard designed to improve the security features of WEP. WPA is stronger than WEP encryption. PSK and PSK2, the two types of WPA, give you a choice between two encryption methods: the Temporal Key Integrity Protocol (TKIP), which incorporates Message Integrity Code (MIC) to provide protection against hackers, and Advanced Encryption System (AES), which utilizes a symmetric 128-Bit block data encryption.
NOTE: For older versions of Linksys routers, WPA Personal is also referred to as WPA Pre-Shared Key. Refer to the image below for an example.
To set up WPA Personal on a Linksys router, follow the steps below:
Step 1:
On Security Mode, select WPA Personal.
NOTE: If you are unable to find the WPA Personal or WPA2 Personal in the list of choices for the Security Mode then you might need to upgrade the firmware of your router to its latest version. Upgrading the firmware can fix the bugs of the previous version and update its other features.
Step 2:
Enter your Passphrase.
NOTE: The Passphrase must consist of at least eight characters and is case-sensitive.
Step 3:
Click kb19073-011_en.png.
Sep 19, 2011 | Linksys Wireless-G WRT54G Router
I bought an Amazon "Kindle" Wi-Fi reading device
I do not recommend that you use WEP for security as this is no longer a secure method for wireless network.
Setting up a wireless network can be a bit tricky at times, but if you follow this step by step guide for Linksys routers, you will have your wireless network up and secure in no time.
It will walk you through resetting the wireless router and quickly setting up a securing your network.
Click here:
http://www.fixya.com/support/r8641009-wireless_network_reset_setup_linksys
Magoo
Feb 18, 2011 | Linksys Wireless-G WRT54G Router
I want to encrypt a wireless network with wep
Question
Answer
Step 1:
Step 2:
Step 3:
4439-001.pngFor Wireless-G Settings:
4439-003.pngNOTE: If the screen on your router’s web-based setup page looks different, click here.
Step 4:
Step 5:
Step 6:
Step 7:
4439-005.pngStep 8:
Step 9:
Click 4058-005.jpg.
Feb 26, 2010 | Linksys Wireless-G WRT54G Router
does not save wireless security settings
Encrypting the network blocks any unauthorized computer from accessing the network and using its broadband connection. To enable WEP on the router,
1. Open your default browser and enter the following IP address into the address bar: <http://192.168.1.1>
2. When prompted for a username and password type “admin” on password, unless you have previously changed the password of the router, and hit OK. This will bring you to the Setup page of the router.
3. Depending on the firmware of the router. Click on the WEP Key Settings button. Or you can click the Wireless tab and select Wireless Security. Or you can click the Security Tab and select Wireless.
4. From the WEP/Security Settings window, you may enable 64 or 128 bit WEP then enter your Password on the Passphrase field and click on Generate. Make sure to copy the characters on Key 1-4 on a piece of paper before you hit APPLY. You will be needing this once you enable WEP on the wireless PC’s. Also take note that if you enable 64 or 128 bit on the router, this should be the same WEP level that you will enable on the wireless cards.
To put in the network key in your wireless adapter follow the steps below:
WEP Encryption XP's Wireless Zero Configuration ( Advisable for XP PC's )
1. Go to start>Control Panel>Network Connections>Right click on the Wireless connection then click on Properties>Click on the Wireless Networks Tab
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then uncheck “The Key is provided for me Automatically”
3. Type your WEP Keys on both the Network Key and Confirm Network Key field. (This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.) Then hit OK and then OK again.
4. After hitting OK a pop-up should appear on the lower right hand side saying “Connected”. Try pointing your mouse arrow on the lower double monitor icon.
5. Restart your PC
WEP Encryption using the Linksys WLAN Utility ( 98/Me/2000 )
Make sure that the WLAN utility of the Linksys adapter is already is installed. If not, you may follow follow the procedures below for "Installing the Linksys WLAN Utility"
1. Click on Start then Programs, then click on anything that says something about the Linksys Wireless Adapter. On the menu, select either WLAN Utility or Wireless Configuration Utility
2. On the lower right-hand side of your screen, double click on the Linksys Icon. This will bring up the WLAN Configuration Utility.
3. Click on the Profiles Tab. Make sure that the SSID that is set to default is your routers SSID. Highlight Default then hit Edit.
4. Select Profile Wizard. Continue to click the Next button, until you get to the Security Settings Window.
OR select Expert Mode then Next. Then click on Security Settings
5. Set the same WEP level that you have enabled on the router. ( ex. 64 or 128 )
6. Type your WEP Keys. This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.
7. Hit OK then Next. On Confirm New Settings click Yes. And then click “Activate New Settings Now”
Nov 15, 2009 | D-Link Vonage-enabled Wireless Router...
Dual band setup/wep
you have dual band router.
It must be working on the 5 GHZ and 2.4 GHZ .
if you access the router set up interface , you will find the wireless settings of the router.
For 5 GHZ , you can set up different SSID than the SSID of 2.4 GHZ.
Make sure that both the wireless network names will be different.
You use the same security settings for both the bands.
For this you will need to access the router set up interface.
Click Here for more info
Oct 31, 2009 | D-Link DIR-825 Wireless QuadBand Router
251 people viewed this tip
David Payne
David Payne
