Tip & How-To about Computers & Internet
How to remove the text from the Desktop icon
Desktop is the interface of Windows, which contain the icons, taskbar etc. that allow the user to interact with the computer to perform different operations. Usually the picture of icon represents its purpose so if you want your desktop looking very clean then you can remove the title under the desktop icons. May be you are thinking it is so easy, just go to rename option and set blank name or single spacebar entry but the problem is this, windows will not allow you to set blank name or name with single spacebar entry. Here interesting thing is this; window will allow you to use the ASCII code for a space, which is 0160.
First clear all the text from that icon
Now type the ASCII code, simply hold the Alt key, type the number 0160 from the number pad and release the Alt key then press Enter button to finish the process.
But if you want to remove the text of multiple icons, then repeat the above process with adding one extra ASCII code for second icon, (for example for second icon you type the 0160 twice and for third icon type 0160 three times with Alt key and so on).
Computers & Internet Logo
HOW TO DELETE AERO FROM MY WIN 7 HOME
Windows Aero Glass is Microsoft's 3-D high-end interface for Windows 7. In order to get this interface, you must be running a video card that supports running Aero Glass. Some video cards barely support running Aero Glass and performance suffers and the computer will lag. By simply disabling Aero Glass, you can take a crawling computer and bring new life into it. In any situation, if you want to increase performance, disable Aero Glass.
Right-click on the desktop and select Personalize. Select Windows 7 Basic theme and a "Please Wait" icon appears and changes your theme. Select Windows Classic theme if you are used to a Windows XP look and feel. A "Please Wait" icon appears and changes your theme. http://social.technet.microsoft.com/Forums/en-US/w7itproui/thread/ce96731f-8f7a-4d13-ba9b-7826cb595e3d
Feb 14, 2013 | Computers & Internet
move task bar to bottom of page
The desktop screenshot might need reducing
Click start "Control Panel."
Click "Display" and then select the Settings tab in the Display Properties window.
Use the slider bar under in the screen resolution section of the applet to change the resolution and click "Apply."
The screen repaints at the new resolution.
Click "Yes" to keep the resolution, or answer "No" at the prompt to revert to the original settings.
The taskbar is a central user interface component within the Microsoft Windows 2000 operating system.
Located along the bottom of the screen by default, it includes the "Start" button, provides one-click access to all open programs and contains a collection of utility icons and the system clock in a section called the Notification Area.
Windows 2000 gives you the ability to adjust the behavior of the taskbar in several ways.
After you know where to find the proper menu item, performing this task takes only a few clicks.
Right-click on an empty area of the taskbar and select "Properties."
Click the "General" tab located along the top of the resulting dialog box.
Check the Always on Top box if you want the taskbar to appear above all other items on your screen.
Check the Auto Hide box if you want the taskbar to disappear into the bottom of the screen when you move the cursor away from the taskbar.
Check the Show Small Icons in Start Menu box if you want to enable this behavior.
Check the Show Clock box to show the system clock within the Notification Area at the right edge of the taskbar.
Check the Personalized Menus box if you want the "Start" menu to show the items you use regularly and hide the items you don't.
Click "OK" to confirm your changes.
They take effect immediately.
Hope this helps
Nov 09, 2012 | Microsoft Windows 2000 Professional for PC
what does gui means?
GUI is a Graphical User Interface, which is for making "Windowed" Applications.
Nov 01, 2010 | Microsoft Internet Explorer 8
taskbar and Desktop icons flash/flicker on and off and don't allow her to open the Start menu or click any of the icons
restart computer and keep tappig F8 when
select safe mode from advance menu
*select win xp os
*get into safe mode and check
if u dont have any issue
then click on start->run->msconfig
click on selective startup
uncheck load startup items
click applay
click close
reboot and chack
if same problem
reboot computerr in safe mode
create new user acount
Feb 18, 2008 | Lenovo 3000 C200 Notebook
186 people viewed this tip
David Payne
David Payne
