Tip & How-To about Computers & Internet
How to quickly reinstall your Operating System
We all have problems with our operating systems. A good practice is to reinstall from time to time. Some experts recommend 3 months, other ones recommend 6 months. The point is to reinstall when you need to. Maybe your operating system will work perfectly for a year. But for the ones of you that are using it at its full capacity it is a very good practice and of course safe.
Some of us are frightened to reinstall the operating system not for the process itself, but for the other 3rd party software you install after that. We lose a lot of time, looking for the discs and the keys for the specific software.
Well here is a quickly solution and a comfortable one in my opinion.
You could do the following at the next reinstallation of your operating system.
I will present the process step by step:
-Reinstall your O.S. as normally. Make all your custom settings( disable the error report, disable remote, automatic updates, etc);
-Install all the drivers for your computer in the proper order (chipset, vga, sound, etc);
-Install all the software that you need (Ms Office, Corel Draw, Photoshop, Python, Visual Studio, Min Gw studio, etc- these are pure examples);
-Make further settings for your operating system and applications;
For the final steps of the process you will need a Hiren's Boot CD. Here is a link to all its components: http://www.hiren.info/pages/bootcd . The following link is for downloading the content of the future CD: http://www.hirensbootcd.net/ . After downloading, burn it on a CD.
The next steps are:
-Restart your computer
-Select from the boot menu to boot from CD
-Select run BootCD from the menu- This is for the newer versions of the software. Also on the newer version you have a Mini Windows XP- very helpful, but I will explain it in another review.
-The software the you will use from the CD is Norton Ghost. The exact key combination for the program is: 2-2 (press 2 and another menu will appear. In this one press again 2 for Norton Ghost)
-Another menu will appear for the type of Ghost images that you want. You may want to split the image- you do not need additional software.
-Run the suitable application for you.
-For making the image the steps are: partition-to image- select the hard drive- select the partition that you will recover later- select the path- give a name- and select a compress rate. (I recommend a fast one)
-For recovering the image: partition- from image- select the image- select the hard drive- select the partition.
After recovering from that image you will have the O.S. as you installed it. You can use the image as many times as you want. It won't deteriorate.
Also you can use the image on different computers with the same configuration. Just be careful with the partitions. You can use Partition Magic, also present on the CD.
The time of the process varies because of the hard drive(how fast it is), the compress rate. But it will not take longer than installing all of those again.
It is a difficult process only the first time, because after that the O.S. will be ready in a couple of minutes, with just a few clicks.
Oh, and do not forget to backup the important files and documents before recovering your partition.
Computers & Internet Logo
phonecomes on wont do anything else
the problem is as a result of software corruption. Your phone operating system is corrupt for one reason or the other. The phone operating system might have gotten virus through bluetooth transfer, internet browsing or via the memory card.
To solve the problem, you need to flash the phone. Flashing the phone means reinstalling the phones operating system software files. The phone will be fully formatted and a fresh operating system files will be reinstalled.
I don't think you will be able to flash this pone yourself because of the tools involved. You will be needing the phone's flashing cable, flashing software and a computer.
Phone experts are the ones that have this software and cable for various phones.
Therefore, I would suggest you give your phone to a phone tech to help you fix this problem. The phone tech will help you flash the phone and your phone will be perfect again.
I am recommending you to a phone tech because this is not what you can do yourself.
I hope you understand this.
Good luck.
Jan 09, 2012 | HTC Cell Phones
frozen screen
Good luck.
Jan 05, 2012 | Cell Phones
freeze when turning on
Good luck.
freezes before booting up
Good luck.
Jan 04, 2012 | Cell Phones
my lg rumor 2 phone is frozen on the startup screen .
Good luck.
Mar 04, 2011 | LG RUMOR Cellular Phone
1,918 people viewed this tip
David Payne
David Payne
