CONTROL PANEL ERROR
CODE
PROBLEM
REMEDY E4
Thermistor problem
Shutdown unit and restart E3
Unrecoverable ofE2RAM data
Shutdown and unit and restart E2
Loss or corruption of stored data
Using remote control go to Cool mode and shutdown the
system, and then restart. E1
Code validation check fail
Shutdown and unit and restart. FL
Filter check warning
Press the “MODE” and (DOWN) “▼” buttons together until
error code disappear.
Note: If the problem persist replacement of control board is
needed.
-Push arrow up and arrow down together for 5sec. the room temp. will show.
need owners manual for my unit or the wiring specs for it cant find the model number help on that...
(More)
need owners manual for my unit or the wiring specs for it cant find the model number help on that would be great too
Hi Just had a Carrier Infinity 96 (40000BTU) installed a few months ago in our 1500 sq ft home. My...
(More)
Hi Just had a Carrier Infinity 96 (40000BTU) installed a few months ago in our 1500 sq ft home. My wife likes to keep our bedroom window open at night for fresh air, which, of course, cools down the house. Before going to bed, we turn down the thermostat to 15 degrees celsius. We turn it back to 20 degrees in the morning after closing the window. The problem is that it takes several hours to bring the temperature back up to normal. Shouldn't it heat up the house faster than that? Is there anything I can do to make it heat up faster? Thanks for any help, Bill Vancouver, BC Canada
where does the electric pilot hook up to the furnace unit. It seems my pipe has moved over the years...
(More)
where does the electric pilot hook up to the furnace unit. It seems my pipe has moved over the years or the bracket may need to be replaced because the gas is coming out but the pilot is not close enough to ignite right away therefore gas is building up until that point. How can I fix the bracket that holds the pipe so it is closer to the gas and ignites right away.thanx
