Tip & How-To about Audio Players & Recorders
How to reprogram your remote number 1 question
Number 1 answer google it as in need codes for philips remote it should then have several listings find the one that looks like your remote select it then it should show the codes for alot of tvs find your with the instructions it gives you on how to reprogram your remote using those codes if the codes dont work for you it should tell you how to do a scan search with your remote
I bought a Phillips SRUS 10827 (other numbers are UPC 09585 16678 or other numbers on pckg are 8670 000 50321 )@ Tuesday Mornings...the product did not come with instructions or a code list. The package says it works with 625 brands. I have not been able to find code list elsewhere including through the store and or other Phippis information sites. Thus I have never been able to use the remote. Any chance these codes are universal brand codes? Or...do I need specific brand and model numbers for each piece of equipment? I am looking to use it most on an older model JVC dvd/vcr in my mother's room. I bought this remote hoping she would get confused with 5different product remote controls as she isn't knowledegable about technology ( 75 years old and counting!!) Can you please answer as many of these questions as possible OR point me in the right direction????? THANK YOU!!
You might need better glasses... lol
The model you have is probably an SRU 510/87 ( S R U 5 1 0 / 8 7 ). If so then you bought a programmable remote for operating the TV only. Yes, it will work with almost 650 different products. But all those products are TVs, not VCRs, DVD players etc.
Also, the user manual is normally a thin sheet/booklet sandwiched between the front and back cards of the product blister pack. I guess you missed it somehow in the way you opened the pack, presuming that the pack was new.
If you want to use a remote to control a DVD player, then you need a device that controls TV, DVD, Satellite etc. i.e. a multi-device remote. Philips does make such models, but the SRU510/87 is not one of them.
If it's any use, then the programming codes are also available online: http://www.urc.philips.com/
Put in your country, then select the remote from the drop down list. I have checked. The SRU510/87 is listed. There are links from the device code page that will also download the pdf file for the user manual.
Sep 05, 2014 | Televison & Video
lost remote and tv locked
It is not possible to unlock this TV without its remote control. If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the sites by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Gopakumar Gopalan Google
Feb 09, 2014 | Philips Televison & Video
i have a philips tv and need a code for a philips universal remote.
The remote codes are available here: http://www.urc.philips.com/ ; select your country and click the right arrow. Then identify your remote model and then click on the remote code finder for that remote. The model number is usually on the front of the remote and inside the battery compartment. Use the search engine or go through the list of all Philips remotes.
If your TV was released less than 6 months before the remote was programmed or is newer than the TV, then the code may not be included.
For example the SRP4004/27 uses the code 2195 for all Philips devices and 3715 for all Philips Magnavox devices.
I hope this helps.
Nov 20, 2010 | Computers & Internet
i need the code for a sharp tv with the phillips universal remote
The codes are specific to the model, and Phillips makes several different models. Phillips codes are available here:
Once you find your remote control in their list, if there is no obvious list of codes, try the Quick Start Guide or the User Manual.
If the guide for your specific remote doesn't have Sharp televisions in the list, try codes 0509, 0913, 0907, 0603, 0002, 0502, 0224, 0228, 0202, 0111, 2550, and 0813.
If none of these work, please reply with your specific television and remote control models.
May 31, 2010 | Philips Universal PH301S Remote Control
164 people viewed this tip
 Grubhead
Grubhead
