Tip & How-To about Linksys Wireless-G WPS54G Print Server
WPS54G Printer Server Setup
I bought a Linksys Wireless-G WPS54G printer server and trie to put it in my home network. Following the instruction from the manufacturer and spent many hours, I still couldn't make the printer server work. There was no problem to get the IP address from my DHCP server using the wired connection. But when I pulled off the network cable and tried the wireless connection, I got "connection failed" error at the last step to install the printer server. I checked my router's client monitor and found the printer server did get the dynamic IP address wirelessly. When I pinged that IP address, there was no response at all from the printer server. In another word, the printer server couldn't communicate with other devices in wireless mode in the network. I searched the Internet and found there were many users had same problem and couldn't resolve the issue even from the manufacturer technical support. As a last resort before I was going to send back the printer server, I switched the network router to one of a different brand. My previous router was manufactured by BUFALLO INC and the new one was made by D-Link. After I rerun the installation following the instruction, the "connection failed" error was gone. The printer server could work finally.
The tip here is: Try a different brand router when there is a connection failure problem for installing the WPS54G printer server, if possible.
Linksys Wireless-G WPS54G Print Server Logo
I have a Linksys WPS54GU2 printserver connected to an Epson CX7800 printer on my home network. When I wirelessly print a multi-page document, the last page does not finish printing and does not eject from the printer. When I print from my desktop PC all prints as it should.
I'm not sure how you have your server set up, but when I did the initial setup I had to add my printer as a TCP/IP port.
See this link for instructions on how to do that: http://homecommunity.cisco.com/t5/Print-Servers/Installation-of-WPS54G-Print-Server-for-Windows-7/m-p/362651?comm_cc=HSus&comm_lang=en#M6440
The hanging on the last page happens if you don't have LPR byte counting enabled. Go find your printer in the devices and right click. Go to "Printer Properties", then the ports tab. Click "Configure Port", then in the popup dialogue make sure that LPR Byte Counting Enabled is checked.
Jan 03, 2011 | Linksys Wireless-G WPS54G Print Server
How can I connect wireless G print server to a 65bits windows vista without a problem, it just works for WIN XP
Hi, it appears that many are having problems with the WPS54G Print Server. I too have always found it hard to get pc to connect to it. My latest problem was with a Win 7, 64bit pc.
Setting up a printer with a print server is a two part configuration. First you need to configure the print server and then add a printer in your OS.
The following instructions are for a linksys wireless router and the linksys wirless print server model # WPS54G.
To set up the print server correctly go to this link.....http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&login=1&app=search&vw=1&articleid=4142&donelr=1
Following is the instructions from the above link:
Title: Connecting the PrintServer Wirelessly to a Wireless Router Article ID: 4142 Before configuring the wireless settings of the PrintServer, make sure to know the following settings on your linksys router: SSID, and wireless security. To check the wireless settings on the linksys router, click here.
Configuring the Wireless Settings on the PrintServer
The wireless settings of the PrintServer can be configured using its web-based utility. Make sure the PrintServer is set to a static IP on the network.
Record the Print Servers IP address you will need it later.
NOTE: Make sure the PrintServer is already working when hardwired to the linksys router before attempting to use it wirelessly on your network.
Step 1:
Access the PrintServer’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the PrintServer's web-based setup page.
Step 2:
Go to the address bar and enter the IP address you've assigned to the PrintServer.
NOTE: To assign the PrintServer a static IP address, click here.
Step 3:
When the PrintServer setup page appears, click Wireless.
Step 4:
Enter the same SSID you have on the linksys router. Make sure the Network Type is set to Infrastructure then click Save to apply your changes.
Step 5:
Click Security and look under the Security Mode field. Select the type of wireless security your router is currently using then enter the corresponding security keys.
Step 6:
Click Save to apply the settings then close the PrintServer setup page.
Step 7:
Unplug the Ethernet cable connecting the PrintServer to the linksys router. Power it off for 30 seconds then power it on.
Step 8:
Make sure the Wireless LED on the PrintServer is lit and the Ethernet LED is off to indicate that the PrintServer is in wireless mode then try to print wirelessly.
Stop if you can print at this point. If not continue. The following instructions are for Windows 7, 64 bit OS.
Once the above steps are completed open windows file explore. Click Network and you should see a "print server" listed. Click on PRINT SERVER and you will see a network icon labeled p1.
You should now be able to add a printer.
In win 7 open the add printer and click "Add a network, wireless or Bluetooth printer", and click next. A searching for printer window pops up. It will list any network printers or print servers it see's on your network. You should see a listing titled "p1 on Print Server".
At this point you need to click "The printer that I want isn't listed. This is just below the "Select a printer" box.
Next a "Find a printer by nane or TCP/IP address" window opens. Select "Add a printer using a TCP/IP address or hostname. Click next.
Another window pops up which ask for a printer host name or IP address. Enter the IP address of your print server (the one you recorded when setting up your print server), and click next.
The next windows states the device is of unknown type. Under Device Type, make sure Standard is checked. Out to the right is a down arrow, click it and you should see many different devices displayed. Scroll until you find "Hewlet Packard Jet Direct", click on it to select it and click next.
Finally a "Install the printer Driver" window should open. Select your printer and follwing the instructions. If your printer is not listed you can click "Window Update" which will look for new printer divers. Once the printer driver is installed you should be able to print.
As you can see this in not a simple printer install. Good luck!
Nov 23, 2009 | Linksys Wireless-G WPS54G Print Server
Linksys wireless print server WPS54G - wireles network problem
access your router and go to wi fi settings check is it enabled if not enabled it.
Also check its netwrok settings like dhcp , ip addreses , subnet mask gateway.
Also check in your network that in gateway is always your linksys ip.
Let me know .
Jul 29, 2009 | Linksys Wireless-G WPS54G Print Server
Problem with Linksys Wireless-G WPS54G Print, PS can't be found.
Check the settings on your wireless print server. And as well check your router.
Jul 26, 2009 | Linksys Wireless-G WPS54G Print Server
1,225 people viewed this tip
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
