Tip & How-To about Computers & Internet
How to fix your wireless connection ("limited or no connectivity")
Although these instructions should work with pretty much any version of Windows, I wrote them for a computer that has Windows XP installed on it.
Also, it looks a lot worse than it really is (promise)...
  1. Select all these steps and paste them into Notepad (and/or print them out or something),because you'll need to close your web browser (Internet Explorer, Firefox, etc. -- whichever you're using) which will mean these instructions will go also close/go away. You'll also be needing to disconnect any ethernet ("network")cables from your computer (if there are any connected, of course).
  2. Close your browser.
  3. Disconnect any LAN ("network") cables attached directly to your computer.
  4. Click Start.
  5. Click Settings.
  6. Click Control Panel.
  7. Double-click Internet options.
  8. Click the Connections tab at the top.
  9. Towards the bottom, click the button labeled LAN Settings.
  10. Make sure that Automatically detect settings is checked, and that everything else (unless you have an advanced setup) is unchecked.
  11. Click OK.
  12. Click OK again (but leave the Control Panel window open).
  13. Now, click Start (again...).
  14. Click Programs.
  15. Click Accessories.
  16. Click Command Prompt.
  17. In the window that opens, type in ipconfig /release and hit Enter.
  18. Then, type ipconfig /flushdns (again, hit Enter).
  19. Then, type ipconfig /renew (..... Enter).
  20. Give it a minute to see if the "Limited connectivity" thing changes to how it should be (which is without the little yellow exclamation point). If it connects, great! (Glad I could help. Skip to step 25.) If not (which is usually my luck), see the next step.
  21. Go back to the Control Panel window and open Network settings (I think that's what it's labeled...)
  22. Right-click the icon that represents your wireless connection (which should be pretty obvious).
  23. Select Disable & then wait maybe 10 or 20 seconds.
  24. Repeat steps 22 & 23, except instead of Disable, select Enable (in step 23).
  25. (Before I type anymore...) Re-open your browser & see if it works. If not, let me know. :)
Actually, let me know either way (if possible) -- if not, no worries. :)
Hope that helps... Good luck!
Computers & Internet Logo
how to install xp on acer laptop
You'll need a windows xp operating system disk. If you already have windows xp on the Acer then check the Certificate of Authentication (COA) sticker to see what version of windows xp it has. You'll have to have an operating system disk with the same version otherwise once it asks for the key to activate windows it will not activate. For Example, if your COA says Windows XP Professional you cannot install a Windows XP Home version unless you purchased the Home Version and the COA Key has never been used.
Insert the disk in the drive and just follow the instructions. It's pretty straight forward and simple.
Apr 25, 2012 | Computers & Internet
i have just bought a new computer and i am trying to install my linksys adapter to my new computer. it worked fine on the old 1, but is not working on the new 1. I am wondering what could be some problems
The WUSB54GSC adapter had been out of production for a while...the last driver update was for Windows XP in 2008 (for Version 2 devices). You should carefully examine the device to see if it is Version 1 or Version 2, as this is necessary when visiting the driver page.
If you're trying to use the adapter on a Windows 7 machine, and Windows 7 does not automatically install the driver, then you're pretty much out of luck as Linksys does not supply a Windows 7 driver for this unit. They don't list a Vista driver, either, although often XP drivers will transfer to Vista without difficulty.
So...if you're trying to install it on a Vista machine, try downloading/installing the XP driver for your device version...it MAY work. If that does not work, or if it's a Win 7 machine, time for a new adapter.
Most new computers these days (at least laptops) have wireless built-in and don't need a USB adapter. I'm assuming, therefore, that you're using this on a desktop. If so, and you need a new one, very good quality ones can be had at WalMart for around $20. Just be sure whatever you buy is compatible to your operating system. It will be printed on the packaging.
Hope that's helpful.
Jan 20, 2011 | Linksys WUSB54GSC Compact Wireless-G USB...
printer does nt work on laptop
  • Win 98 software version will never support Win XP system. Please download the software for your XP machine via the below link.
DOWNLOAD FULL FEATURE SOFTWARE
  • Save the download the file to your desktop.
  • Uninstall the older version, restart the computer and install the new version from downloaded file.
Thanks & Regards
Rizwan
Jan 31, 2010 | HP DeskJet 840c InkJet Printer
need software
Your only hope is that you have a Windows XP pro installation disk to either repair or re install Windows, although a repair is only of use if you still have the principal windows installation. How is XP still there if the notebook has been formatted? If your recovery disk ;which I recon was on another partition on the hard drive is long gone, then the only solution is to purchase XP, although XP home is a cheaper, but just as good a version please rate this solution.
Nov 13, 2006 | Compaq Armada E500 Notebook
175 people viewed this tip
David Payne
David Payne
