Tip & How-To about Cameras
Tips: How to burn AVI files (torrent/digital Camera videos) to DVD on Windows 7
Do you like to shot videos with your favorite digital camera to capture and keep every happy moment in your life? And do you never miss any movies which can be free downloaded from torrent sites, such as Pirate Bay, Vuze, etc. to fully enjoy digital life? That's wonderful digital experience, but to keep these movies and life memory forever is suffering, isn't it? 'Cause either your digital camera's memory or your PC hardware has a limit, so many digital lovers keep asking how to burn digital Camera/torrent files to DVD:
Q1: My torrent downloads are always in the .avi format. I would like to play these movies in a regular DVD player, but I don't know how to burn the DVD on my computer (running on Windows 7).
Q2: I've shot the movie myself using a camera, it is a two hour long .avi file. All I want is to be able to shove it in the DVD player (in the living room) and for it to automatically play.
A: That's true, most videos shot by digital camera, and most free downloaded movies from torrent are in AVI formats. A good and easy way to keep these videos and movies forever is to burn AVI files to DVD which makes easier for you to watch these videos on your DVD player without any hitch. That's easy to finish the whole task, first of all, let's look at all the things you will need to burn AVI movies to a DVD.
1. Things You'll Need to burn AVI files to DVD AVI to DVD Burner software
A black DVD disc
A PC running on Windows OS (including the latest Windows7)
A PC with DVD Burner
2. How to find a good AVI to DVD Burner?
Actually, there are a lot of AVI to DVD conversion software, please never get a one without free trying first. Before making a purchase decision, you can get recommendations from professionals, friends, etc. And the most import thing is to get a free trail by yourself. In fact, I have tried a lot of such software, but for the sake of simplicity and stability, I will present you such a conversion tool which works well to convert AVI format to DVD on windows 7.
3. Steps to burn AVI files to a DVD on windows 7
Step 1: Free download AVI to DVD Burner
Please free download this Windows 7 AVI to DVD Burner, install and run it. And insert a DVD disc to your PC.
Step 2: Add AVI files
Add AVI videos or movies by clicking "Add Video" button.
Step 3:Set DVD menu
Select your AVI files, then hit "Burn DVD" button at the bottom of the interface, and then check "Next", you can select DVD menu from built-in "Menu Template", and you can set background music and picture for your DVD menu by checking the related option to customize your DVD menu. Here I set the background picture by adding a picture from your PC. If you want to preview your DVD movies, you can click "Play" to make a preview.
Step 4: Start to burn AVI files to DVD
After everything is done, you can click "Next" to select your DVD burner from "Burn to" option. Then, you can hit "Start" to burn AVI files to DVD.
Tips:
Here below is the explanation of TV Standard:
"NTSC" is 30 fps, which is used in USA, Canada and Japan;
"PAL" is 25fps, which is used in Europe and Asia.
That's all, after the conversion is done, you can watch your torrent movies or digital camera videos on your DVD player.
Cameras Logo
i forgot my phone password...
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Sep 30, 2012 | Cell Phones
When using my Nikon CP 5400 - the videos are not longer clear and are grainy - is this a card issue or the camera? Also the camera is slow in capturing the current shot I am taking and I now miss the moments I am trying to take.
This sounds like an issue due to low light. The card will not cause the video or pictures to be grainy, but high ISO settings (used to compensate for low light) will. In low light, auto-focus has a hard time and usually a camera won't take a shot unless focus lock occurs.
Assuming you were shooting in a low-light situation, the solution is to add more lighting to the scene.
Note that the flash on your camera is only good for a distance of about 10 feet.
Mar 01, 2011 | Nikon Coolpix 5400 Digital Camera
No sound when recording video
Did you set up the camera to capture sound? This Camera has a Functions menu which is deep as the ocean, and standard movie capture does not also pick up sound. Additionally, if playing the movie back over an external device, use the A/V cable not USB, and get a High Capacity SD/MMC memory card if you want more than a few moments of video with sound. I would finally recommend an audio input device, as even when in Movie sound capture mode, the volume is never very loud.
Read the advanced manual completely.
Dec 25, 2008 | Canon PowerShot SD1000 Digital Camera
Just a video of 8.03 minutes captured in my Power Shot A550 Digital Camera shows 867 MB size
A 1.3 hour movie is recorded on a DVD, not a CD. DVDs can hold a minimum of 4.7 GB, or nearly seven times the capacity of CDs. Your 867 MB file of 8.03 minutes indicates that you were recording at about 1,800 KB/sec, or the highest quality recording level. (See specifications here.) If you're willing to record your video in a smaller size, you can get much more recording on a CD.
Apr 30, 2008 | Canon PowerShot A550 Digital Camera
360 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
