Tip & How-To about Cameras
How to resize a picture or image to create a smaller size for convenient e-mailing
With the advent of the Megapixel camera , our photo's that we take are getting bigger and bigger. This is all good to have a nice and big resolution picture , but the trouble comes in when you try to e-mail a 4Mb picture on a limited internet connection.
There is lots of software out there that can re-size a picture or photo , but I prefer and recommend Pixresizer because its free and really easy to use.
Download Pixresizer HERE
Once downloaded , unzip the program and install it to your computer. If you do not have software to unzip it , please download winrar HERE.
Now open the program.
You have a choice of converting multiple files or a single file at a time.I'll be demonstrating how to convert a few files at the same time. The concept is the same for converting a single file.
Click on the "work with multiple files" tab.
  1. Select the folder where the photo's which you want to resize are located .
  2. Select the folder where the resized files are saved.
  3. Move the size dragging scale to select desired size.
  4. Select the output format (Jpeg is fine)
  5. Finally Save Pictures.
And that's all. I now converted 7.8Mb of photo's to only 200Kb which is a much more appropriate size for sending in a e-mail.
Please remember to rate this tip if your find it helpful.
StephanSA
Cameras Logo
my camera the mercury cyberpix 2-210s only take 20 or so pictures and has a memory card of 8 mb and I don;t understand why.
Your Mercury Cyberpix S-210S has an internal memory of 16MB and can be expanded using an SD/MMC Card up to 512MB.Since the picture you capture using this 2 Megapixel camera has an approximate resolution of 1600*1200 and a size of approximately 400kB you can store only around 18 to 20 photos in an 8MB Memory Card.So if you want to store more pictures you have to insert a Memory Card of bigger capacity.Remember the maximum Memory Card capacity supported on your camera is 512MB.Thanks for choosing Fixya.
Jun 19, 2011 | Kobian Mercury 3.1 Deluxe Classic Digital...
With 5-megapixel camera, I want to capture maximum resolution.
how I get maximum resolution by 5 mp camera with small photo.
my friend mega pixel relates to the print out u want out of ur photo file,on the monitor screen everything looks same if u dont zoom too much ,
for 5X7 print 1 mega pixel photo looks fine and more than enuff if u want a 5X7 print out of it
for 6X8 and 8X10 2 mega pixel is ok and for further enlargements u need higher mega pixel
or if u need output on large LCD screens of like 46 inch and 52 and 60 inch then also u need good resolution pics to display properly other wise pixelation will appear
so how can i help u more in this pls rate me FIXYA for this if u like
Mar 17, 2009 | Mercury Electronics CyberPix S-555V...
Lack of mb in photos
If you have your camera set to take the highest resolution pictures(8 MegaPixel), but save in jpg format, then 3 - 4 MB is a normal size for the image file. There is nothing wrong with your camera.
If you have your camera set to save in RAW format, the image files will not be compressed and MUCH bigger. However you will need software that will be able to manipulate images in RAW format.
Jan 07, 2009 | Sony Cyber-Shot DSC-F828 Digital Camera
I need to double check what the megapixel count on the Fuji Finepix s700 is
you get better resolution on large pictures (like a 10" x 13" or bigger ) when you work with more than 4 megapixel yours got 7.1 so you can get nice posters :)
Jan 02, 2009 | Fuji FinePix S700 Digital Camera
I'm getting really confused with the resolution stuff
The C4000 is a 4 megapixel camera and can produce photos that should produce very nice 8 x 10 photos. 11 x 14 prints may be pushing it a bit. Your cameras should be set for 2048 x 1536 and the .jpg compression should be set to "Super High". Better yet, that camera can produce TIFF format. For photos you plan to print, use the TIFF format. The other half of this process is the printer. Most inkjet printers have a number of settings. Make sure that it is set for photo paper and be sure to use glossy photo paper. If you can print a 8 x 10 print in less than a minute, your printer is not set right. If it seems like it is taking forever, it is set right. .................... Using Photoshop Elements 2: Open your photo into Elements. Click Image, Resize, Image Size Remove the checkmark from "Resample Image" Change resolution to 300. Notice that the width height is about 5 x 7 inches. So if you print that photo at 300 dpi (dots per inch), you will get an outstanding 5 x 7 print. Most inkjet printers produce their very best outputs at 300 dpi. At 200 dpi, the image is still quite good. When you get below 150, you will start to see changes in quality. Now set the Resolution to 200 dpi and notice that the output size has changed to about 8 x 10 inches. Now check to see how it will look on paper. click OK. Click File, Print Preview You can verify that the photo fits on the paper and that the paper is correct (horizontal/vertical). Now print the photo. The next window that opens should let you get to your printer properties and you can verify that you have the printer set for it best settings and that paper is set to photo paper.
Sep 06, 2005 | Olympus Camedia C-4000 Zoom Digital Camera
313 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
