Tip & How-To about Computers & Internet
Computer problems no power,self rebooting
If you are experiencing this problems..
you can follow this steps..
first if no power check your cables for loose wires..
next check your front panel wires in your motherboard...mostly the power panel maybe it is not properly connected...
much better if you kno how to short your power on pins so that you surely know if it will turn on...if you short it and it didn't react or still no power.. your power supply is your problem..
next if you are experiencing self rebooting..
if you are experiencing self rebooting in windows logo...
you can see the logo but it will reboot without notice,,
first try to check your motherboard capacitors...
this are the one that will be the first to be damaged if there are problems in power supply...
if you have already check it..try to run it again and if the computer display a message that you are prompting to select start windows normally, last good configuration,..
try to choose the last good configuration..if it hangs up..
try it again then choose safe mode if hangs again..
you need to run system restore... if you don't have it..
you need to format your hard disk..
i advise you to remove your hard disk and make it a slave to another pc so that you can back up your important files...
then return it to your cpu and format it...
if you are suspecting that it was a virus that cause your problem.. make sure that the pc you will use to be you back up point have an anti-virus software.. and try to run scan first so that the virus will be detected and prevent it for entering the other pc...
Computers & Internet Logo
hi ,, i have just fitted a intel d845gvsrb in my pc but i am not sure where the tower speaker wire , reset sw , power sw , power led , h h d led and the black single one go`s can you please help me ..
The Picture below shows you the locations of the places to put those wires are in relation to your motherboard. In yellow is the power switch and such. and the audio connection is in red.
The Pin layout for the power and other connector are as follows:
the layout for the audio header is as follows: avatar23454_8.jpg
To install the cable that connects a front panel audio solution to the front panel audio header, follow these steps:
  1. Turn off all peripheral devices connected to the computer. Turn off the computer and disconnect the AC power cord.
  2. Locate the front panel audio header (J8A1).
  3. Remove the three jumpers from the header (this disables the back panel audio connectors).
  4. Install a correctly keyed and shielded front panel audio cable.
  5. Connect the audio cable to the front panel audio solution.
To restore back panel operations follow these steps:
1. Remove the front panel audio cable. 2. Install a jumper on pins 5-6 (rear R channel). 3. Install a jumper on pins 9-10 (rear L channel). 4. Install a jumper on pins 1-2 (mic). 5. Replace the cover.
Apr 17, 2011 | Intel D845GVSR Motherboard
the printert dos not respiond to any cartridge and dos blink at all /
Issue: All the lights blink In this error condition , the following blinking lights pattern displays on the control panel:
  • On/Resume light : Blinking
  • Check Paper light : Blinking
  • Check Print Cartridge light : Blinking
  • Black Start Copy light : Blinking
  • Color Start Copy light : Blinking
Figure 107: All the lights are blinking on the control panelc00864301.gif Solution one: Make sure that the front panel overlay is installed correctly If the front panel overlay, or bezel, is incorrectly installed, the product may indicate a false carriage stall error condition. If the product has not been set up before, follow these steps to ensure correct installation of the front panel overlay. If the front panel overlay is already installed, and your printer has been working for some time, do not attempt to reinstall the overlay. Press firmly on the overlay to ensure proper installation of the overlay adhesive or pins. NOTE: If you have already installed the front panel overlay, proceed to the next solution.
  1. Disconnect the power cord from the rear of the product.
    Please arte me Thanks Techbelkin
    TECHBELKIN ORIGINAL SOLUTION
  2. Locate the front panel overlay and peel off the paper backing to expose the adhesive as shown in the graphic below. Figure 108: Remove the paper backing from the front panel overlayc00005257.jpg
  3. Lift the scanner lid.
  4. Carefully line up and install the front panel overlay. Figure 109: Install the front panel overlayc00005258.jpg Figure 110: Correctly installed front panel overlayc00005259.jpg
  5. Reconnect the power cord to the rear of the product.
  6. Try the intended task again.
Solution two: Reset the All-in-One Follow these steps to perform a power reset. Step one: Perform a power reset
  1. Press the On/Resume button (c01602202.gif ) to turn on the product.
  2. With the product turned on , disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the wall outlet.
  4. Wait at least 15 seconds.
  5. Plug the power cord back into the wall outlet.
  6. Reconnect the power cord to the rear of the product.
  7. If the product does not turn on automatically, press the On/Resume button (c01602202.gif ) to turn the product back on.
Step two: Print a self-test report Follow these steps to print a self-test report.
  1. Load plain, white paper into the paper tray.
  2. Press and hold the Cancel button (c02517757.gif ), and then press the Start Copy Color button. The product prints a self-test report.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution three: Service the All-in-One If you have completed all the steps and are still experiencing a problem, continue to the Service the All-in-One section at the end of this document. Service the All-in-One If you have completed all the preceding steps and are still experiencing a problem, service the product. Determine if your product is in warranty or out of warranty. If you need help determining your product's warranty status, go to HP's Warranty Check Tool .
  • If your product is in warranty , contact HP.
  • If your product is out of warranty , fees might apply for contacting HP.
Jan 08, 2011 | HP PSC 1315 All-In-One InkJet Printer
my pc wont turn on
Follow the below Steps:
1st Step: Check whether you have connected the power cable and display cable? If no, connect the same. If yes, then follow the next step.
2nd Step: After switch ON the system, check whether the keyboard lights are flashing? If no, then the problem with the SMPS of your system, replace the same will resolve your problem. If yes, follow the next step.
3rd Step: Try to go to BIOS mode and check whether the HDD has been detected. if no, then check the HDD cables., If yes, follow the next step.
4th Step: Check for any beep sounds. Also check whether the RAM has been properly inserted.
Revert back for more assistance and give your valuable feedback/rating for the solution provided.
Thank you for using Fixya.
Feb 13, 2010 | Sony VAIO VGC-RB42G PC Desktop
Printer wil print when scanning but not from computer
There are a few steps you will need to follow to resolve this problem. Follow these steps one after the other. start with the first step. after each step, try to print and see what happens. if your problem is resolved, ignore the other steps.
Step one: Clear any paper or carriage path obstructions
1.
With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
2.
Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
3.
Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
4.
Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
5.
Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
6.
Press the On button to turn on the product.
Step two: Ensure correct installation of the front panel overlay
If the front panel overlay, or bezel, is incorrectly installed, the product may indicate a false carriage stall error condition. If the product has not been set up before, ensure correct installation of the front panel overlay by following the instructions below.
If the front panel overlay is already installed, and your printer has been working for some time, do not attempt to re-install the overlay. Press firmly on the overlay to ensure proper installation of the overlay adhesive or pins.
NOTE: If you have already installed the front panel overlay, proceed to the next step.
1.
Disconnect the power cord.
2.
Locate the front panel cover and peel off the paper backing to expose the adhesive as shown in the graphic below.
3.
Lift the scanner lid and carefully line up and install the front panel overlay.
4.
Plug the power cord in.
5.
Try the print job again to see if this step resolved the issue.
If the issue is resolved , you do not need to continue with the rest of the instructions on this page.
If the issue is not resolved , continue to the next step.
Step three: Plug the product directly into a wall outlet
Verify that the product is properly connected to a suitable power source by following the instructions below.
1.
Verify that the computer and the all-in-one product have a three-prong power plug.
2.
Unplug the power cable from the back of the all-in-one.
3.
Unplug the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
4.
Plug the power cable into the back of the all-in-one.
5.
NOTE: If the product prints when plugged directly into a wall outlet while unplugged from any power strips or surge suppressors, the power strip or surge suppressor may not be allowing sufficient voltage to reach the product.
Step four: Perform a partial reset
A partial reset will return user settings to factory defaults. you may have, language and country/region settings also resetted. Perform a partial reset of the product by following the instructions below.
1.
Unplug the power cord from the unit.
2.
Reconnect the power cord into the unit.
3.
When the lights begin to flash, press and hold the On/Resume and Paper Size buttons.
4.
When only the On/Resume light is flashing, release the buttons.
When the On/Resume light is steady, the reset is complete.
5.
Step five: Remove and re-install the print cartridges
Improper placement or installation of the product's print cartridges can cause the product to indicate a carriage stall error condition. Ensure correct installation of the print cartridges by following the instructions below.
1.
With the printer plugged in and turned on, open the cartridge access door (see the illustration). After a moment, the print carriage should come to the center.
The print cartridge carriage is the plastic part that holds the print cartridges.
NOTE: If the carriage does not come to the center, try turning the printer off and on.
2.
When the carriage is at the center of the access area, unplug the printer.
3.
Remove the cartridges from the carriage and check them for damage. Check for obstructions under and around the carriage. Replace any damaged cartridges.
NOTE: Try to inspect and reinstall the cartridges as quickly as possible, so that they do not dry out. Avoid touching the copper-colored parts of the cartridge.
4.
Reinstall the print cartridges.
The black or photo cartridge goes on the right.
The tri-color cartridge goes on the left.
5.
Close the cartridge access door, plug the printer back in and turn it on.
6.
Step six: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
May 19, 2009 | HP PSC 1210 All-In-One InkJet Printer
my thomson dti 6300 250gb free view box wont turn on
Emailed Topuptv and got this reply
Dear Sir/Madam,
Thank you for contacting Top Up TV.
Please note that we are currently aware of an issue affecting some Thomson DTi6300 boxes.
If your DTR will not come out of standby and is not responding to your remote control, please try the following procedures.
Step 1: Power cycle
First of all, remove the power to the box and wait 20 seconds before restoring power.
Wait while the box tries to restart and allow 2 -3 minutes for this to complete.
Try this at least twice.
If it doesn't go to the solid green light then proceed to the next step.
Step 2: Front Panel Reset
Note: This procedure will unfortunately cause you to lose all of the recordings that you have stored on the box. You will need to be able access the back of the DTR and the front panel buttons
1. Remove power to the unit by removing the power cable from the back of the DTR.
2. Wait 20 seconds and restore the power cable while holding in the standby/power on button on the front panel of the DTR.
3. Release the standby button immediately you see a light 'blip' on the DTR front display and then immediately press the following front panel arrow buttons in sequence Up>Down>Left>Right
4.The DTR will now show the Orange LED with the Green LED flashing until the format has been completed in about 60 seconds. The DTR will return to ON automatically.
5. If requested, perform a channel scan to complete the operation.
We apologise for any inconvenience caused. Our Customer Services department can also be contacted on 08444 159 159. However, please note that we are currently experiencing high call volumes and so may not be able to answer your call as quickly as we would like.
Kind Regards,
Richard
May 04, 2009 | Televison & Video
169 people viewed this tip
David Payne
David Payne
