Tip & How-To about Computers & Internet
Broken Flash Drive ? , Flash Drive not working ? Dont trash it just yet.
Many people believe that when a flash drive stops working , you can throw it in the trash...this is however a expensive mistake to make as about 30% of drives can be repaired.
There are basically 3 causes for a flash drive to stop working.
  1. Partition is corrupted
  2. Broken electrical contact inside the drive
  3. Memory module is blown (no repairs possible)
#1 Partition is corrupted
If your flash drive's partition is corrupted you will not be able to access it. To fix this , do the following.
Go to My Computer
Right click on the flash drive
Select Format
Check the Quick Format option
Select Start
After the format is completed , test the drive. If it disappears or was never present to begin with , but windows detected when it was plugged in , try re-assigning the drive letter for the flash drive.
If you do not know how to do this , please follow the steps in the following tip i wrote : How to change a drive letter.
If the drive is not present in the disk management window , proceed to step 2.
#2 Broken electrical contact inside the drive
If the drive does not detect on your pc , this might be the cause.
What you need :
  1. Soldering Iron and Solder
  2. Magnifying Glass (Optional)
  3. Desk Lamp
  4. Superglue
Open the cover of your flash drive. This is normally done by pulling the two parts apart. Then have a look at where the USB is soldered onto the PC board. There will be four metal contacts soldered onto the board.
This is normally where a electrical fault will occur.
If you find one of the contacts are broken , simply solder it back into place and glue the cover of your drive back on.
If these steps fail to fix your flash , you can dump it in the trash with confidence that its dead.
Please rate this solution if you found it helpful.
Kind Regards
Stephan
Computers & Internet Logo
Whats the difference between trash and junk and how can I get rid of junk quickly?
Trash would be anything that you delete that comes from people you get email from. Junk would be like junk mail...unwanted or spam emails. Usually junk/spam email deletes instantly so you cannot retrieve it if you make a mistake. Trash usually deletes in 30 days. Some email servers allow you to change those settings as well
Jul 10, 2016 | Apple iPad Mini
lost power while driving
is the check engine light flashing, if so stop driving and figure it out, could have a cracked plug, or bad coil, these early trailblazers had an issue with the cylinder bore liners cracking and trashing the motor, try all new plugs and gap them correctly, .060 i believe, check the old ones for damage if found sell the car unless you want to replace the motor
Jan 15, 2013 | 2002 Chevrolet TrailBlazer
Error 2-Unit will not heat or brew. Stopped in middle of brewing cycle and flashed error 3 code. After unplugging unie and plugging back in an error 2 remains.
Error message 2 is a result of the water heating element burning out. The element is replaceable, if you can find a vendor who sells the element assembly. Price of a new element may be more that a new pot though, if you're lucky enough to find a parts vendor that sells one.
Dec 18, 2009 | KitchenAid KCM511 Coffee Maker
iPhoto accedently tossed christening photoes into trash. How to retrive.
If you did not empty the trash, you can open the trash and drag and drop the photos back into the picture or iPhoto folder. If you have emptied the trash, let me know and I'll research and see if there is a solution.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 28, 2008 | Computers & Internet
521 people viewed this tip
David Payne
David Payne
