Tip & How-To about Computers & Internet
Make your Folders Private
  1. Open My Computer
  2. Double-click the drive where Windows is installed (usually drive (C:), unless you have more than one drive on your computer).
  3. If the contents of the drive are hidden, under System Tasks, click Show the contents of this drive.
  4. Double-click the Documents and Settings folder.
  5. Double-click your user folder.
  6. Right-click any folder in your user profile, and then click Properties.
  7. On the Sharing tab, select the Make this folder private so that only I have access to it check box.
Note
  1. To open My Computer, click Start, and then click My Computer.
  2. This option is only available for folders included in your user profile. Folders in your user profile include My Documents and its subfolders, Desktop, Start Menu, Cookies, and Favorites. If you do not make these folders private, they are available to everyone who uses your computer.
  3. When you make a folder private, all of its subfolders are private as well. For example, when you make My Documents private, you also make My Music and My Pictures private. When you share a folder, you also share all of its subfolders unless you make them private.
  4. You cannot make your folders private if your drive is not formatted as NTFS For information about converting your drive to NTFS
Bhautesh.
Computers & Internet Logo
How do I install print shop 3.5 on Vista Home?
Insert the disc into the DVD drive in your computer. The installation should begin automatically or give a pop-up asking you what you would like to do. Select Run Setup.exe. Note: If the installation does not begin automatically follow these steps: Click on Start. Click on My Computer (Computer on Windows Vista and Windows 7) Right Click on the DVD drive containing The Print Shop 3.5 disc. Left Click on Open. Double Left Click on Setup.exe. The installer will now search your computer to make sure you have the required Windows Updates in order to install The Print Shop 3.5. If it detects that you are missing an update the installer will prompt you to install these now. Once the updates are complete the installer will move to the next step automatically. From here you should follow the on screen prompts to complete the installation.
Feb 12, 2015 | Encore The Print Shop 3. 0 Deluxe for...
google on windows 7
Click Here and install Google Chrome again
Please rate my response!!!
Jan 29, 2010 | Google Chrome
Install Works 9 from CD? How? Microsoft Works9
Insert the cd into the cd drive, the setup should come up automatically, if it doesnt come up then open my computer, double click on the cd drive, if the setup still doesn't come up, right click on the drive and click on open, if it didn't open automatically. Then look for the setup file and double click on it to start the setup.
if it still doesn't install try the cd on another computer to confirm if the cd is working. if it works on another computer then the issue is with your cd/dvd drive, if it doesn't work on other computers aswell then the cd is the problem.
Sep 11, 2009 | Microsoft Windows Vista Ultimate Edition
downloaded drver for my printer. the add new printer wizard can't
Hi ...
If you have the driver CD that you recieved with your printer, follow the below steps to install the saftware:
  1. Turn on your computer.
  2. On your computer quit any open applications, including virus checkers.
  3. Insert the MultiPASS MP730/700 Setup CD-ROM into your CD drive. The [MP Setup] splash screen will appear automatically.
    1. If MP Setup does not start automatically, on the Windows desktop, double-click My Computer (on Windows XP, click Start then click My Computer).
    2. Double-click the CD-ROM icon. If MP Setup does not start, double-click 'Setup.exe' (on Windows XP, 'Setup').
  4. In the MP Setup splash screen, click 'Install MP Drivers'.
    Note: For Windows 2000 users, if Service Pack 1 or later is not installed, MP Setup will display a message and installation will be aborted.
  5. Follow the on-screen instructions, clicking the appropriate button to move from one screen to the next.
  6. MP Setup will install some system files and may prompt you to restart your computer. If you are not prompted to restart, click 'Finish' in the MP Drivers Setup window and then proceed to step 7.
    1. If you are prompted, make sure radio button 'Yes, I want to restart my computer now.' is selected in the MP Drivers Setup window and then click 'Finish'. DO NOT remove the CD-ROM at this stage. MP Setup splash screen will open after Windows has restarted.
    2. If you had to restart your computer and the MP Setup screen is not displayed or you closed it, on the Windows desktop, double-click My Computer (on Windows XP, click Start then click My Computer).
    3. Double-click the CD-ROM icon. If MP Setup does not start, double-click 'Setup.exe' (on Windows XP, 'Setup').
  7. In the MP Setup splash screen, click 'Install MP Toolbox.'
  8. Follow the on-screen instructions, clicking the appropriate button to move from one screen to the next.
  9. At the MP Toolbox Setup dialog box, click 'Finish'.
  10. Confirm the MultiPASS is turned on.
  11. Connect the USB cable to the MP730 and computer USB ports. Windows will detect the printer and proceed to install the driver files.
  12. Your MultiPASS includes additional software applications that you can install now or at a later date. To install the software, click 'Install Utility Software' and then proceed through each installation.
You can also download the drivers by visiting the below link and selecting your operating system.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=9035#DownloadDetailAct
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
My drives r not opening by double click
That usually happen when your computer was infected by virus, have it scann using different scanner not that is found in your computer cause that cannot detect the virus.
Thanks.
Nov 22, 2008 | Microsoft Windows XP Professional for PC
172 people viewed this tip
David Payne
David Payne
