Tip & How-To about Computers & Internet
Where has the run command gone/how to show run command.
In Windows Vista and Windows 7 , the run command is hidden by default. This was probably done to declutter the start menu , but I like having the run command available as it does come in handy for more advanced users.
So , how do I get it back?
Right click anywhere on your startbar and select properties.
Now , under the start menu tab , select customize.
Now , just under the recorded TV section , there is a check box with the run command. Check the box and select okay.
Your run command will now once again feature in your start menu.
Please remember to rate this solution if you found it helpful.
Kind Regards
StephanSA
Computers & Internet Logo
how do I change the default gaqteway
  1. In Windows 7 and Vista, click Start. In the search box, type cmd , and then press Enter. In Windows XP, from the Start menu, click Run... . In the "Open:" field, type cmd , and then click OK.
  2. This will open the command prompt. At the prompt, enter ipconfig . This will display your network information, including your default gateway.
Apr 26, 2012 | Vizio XWR100 Wireless Router
SmartAX MT880 driver
The SmartAX MT880 is a Router and does not require drivers to access.
Access to the Router can be done by type the I.P address of the Router in a browser e.g Internet Explore
To find the I.P address of the Router.
From a Windows PC connected to the SmartAX MT880 via a network cable,
Click the Start Menu, Click Run (On Vista and 7 you can type run in the search bar)
From with-in Run, Type cmd, Click Ok
Once the Command prompt windows appears, type Ipconfig /all with the window.
From the list of information find the line called Default Gateway (most like under Ethernet adapter Local Area Connection) a example is provide below.
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
IPv4 Address. . . . . . . . . . . : 192.168.1.13
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
In this example the I.P address of the router is 192.168.1.1.
Oct 27, 2011 | Microsoft Windows Vista Ultimate Edition
166 people viewed this tip
David Payne
David Payne
