Tip & How-To about Computers & Internet
How to change drive letter on XP
Go on
Start
Settings
Control Panel
Administrative Tools.
Computer Management.
chose Disk Management .
Right click on drive letter do you want to change, select
"Change drive lefter and paths" and choose desired letter.
Don't try to change boot drive letter.
http://minitehnicusdiy.blogspot.com/
Computers & Internet Logo
when i putting password in my samsung hard disk ,the computer switch off.and now i can't open my hard disk to i use it ..
You can gain access to a working hard drive that is inaccessible when the system starts and assign it a drive letter under the Windows Explorer interface. Or, you can import foreign disks into Windows or create a partition and format them. You can scan a drive for bad sectors or lost clusters and repair the system files to allow access to a corrupted drive. In short, you can utilize the drives as they were intended to be used by completing some operating-system configuration steps that are occasionally required for some drive installations.
Click "Start" (the Windows Orb) and "Computer" to access the Windows Explorer screen. Right-click on the inaccessible drive and choose "Properties" from the context menu. Click the "Tools" tab and click "Check Now" under the Error-Checking section. Select both check boxes to allow the system to automatically fix file-system errors and to scan for and attempt recovery of bad sectors. Allow the system to run the scan the next time the system is booted. Restart the computer to complete the scan and check for access after the scan completes. Click "Start" (Windows Orb) and "Computer" to access the Windows Explorer screen. Right-click on the inaccessible drive and choose "Properties" from the context menu. Click the "Security" tab and click "Edit" to change permissions for the drive. Click "Users" from the Group or User Names section. Check the "Allow" box for full control and check for access after the settings are saved. Click "Start" and "Control Panel" and then click "Administrative Tools" and double-click "Computer Management" to launch the utility. Click "Disk Management" to display a list of all detected drives in the system. Right-click in the left column of the inaccessible drive and click "Import Foreign Disk" to allow the system to convert the disk signature to a local disk. Check for access after the settings are saved. Click "Start" and "Control Panel" and then click "Administrative Tools" and double-click "Computer Management" to launch the utility. Click "Disk Management" to display a list of all detected drives in the system. Right-click in the right column of the inaccessible disk and choose "Change Drive Letters and Path." If no letter exists, click "Add" and assign a drive letter from the list of available letters. If a drive letter is listed, click "Change" and select a new letter to eliminate any conflicts with other devices in the system. Check for access after these settings are in place, which may require a restart of the system. Click "Start" and "Control Panel" and then click "Administrative Tools" and double-click "Computer Management" to launch the utility. Click "Disk Management" to display a list of all detected drives in the system. Right-click in the right column of the inaccessible disk and choose "New Simple Volume" to create a partition and format it for use. Click "Next" when the New Simple Volume Wizard appears. Click "Next" to accept the maximum for the drive. Click "Next" to accept the suggested drive letter assignment. Click "Next" to format the volume with the suggested defaults or change them if desired. Click "Finish" to format the drive and make it accessible to the operating system.
Feb 02, 2013 | Samsung G2 Portable External HX-MU032DC/...
wd my book 500gb external is not being shown on the computer what so ever. Is also making horrible clicking sound
Click "Start" (the Windows Orb) and "Computer" to access the Windows Explorer screen. Right-click on the inaccessible drive and choose "Properties" from the context menu. Click the "Tools" tab and click "Check Now" under the Error-Checking section. Select both check boxes to allow the system to automatically fix file-system errors and to scan for and attempt recovery of bad sectors. Allow the system to run the scan the next time the system is booted. Restart the computer to complete the scan and check for access after the scan completes. Click "Start" (Windows Orb) and "Computer" to access the Windows Explorer screen. Right-click on the inaccessible drive and choose "Properties" from the context menu. Click the "Security" tab and click "Edit" to change permissions for the drive. Click "Users" from the Group or User Names section. Check the "Allow" box for full control and check for access after the settings are saved. Click "Start" and "Control Panel" and then click "Administrative Tools" and double-click "Computer Management" to launch the utility. Click "Disk Management" to display a list of all detected drives in the system. Right-click in the left column of the inaccessible drive and click "Import Foreign Disk" to allow the system to convert the disk signature to a local disk. Check for access after the settings are saved. Click "Start" and "Control Panel" and then click "Administrative Tools" and double-click "Computer Management" to launch the utility. Click "Disk Management" to display a list of all detected drives in the system. Right-click in the right column of the inaccessible disk and choose "Change Drive Letters and Path." If no letter exists, click "Add" and assign a drive letter from the list of available letters. If a drive letter is listed, click "Change" and select a new letter to eliminate any conflicts with other devices in the system. Check for access after these settings are in place, which may require a restart of the system. Click "Start" and "Control Panel" and then click "Administrative Tools" and double-click "Computer Management" to launch the utility. Click "Disk Management" to display a list of all detected drives in the system. Right-click in the right column of the inaccessible disk and choose "New Simple Volume" to create a partition and format it for use. Click "Next" when the New Simple Volume Wizard appears. Click "Next" to accept the maximum for the drive. Click "Next" to accept the suggested drive letter assignment. Click "Next" to format the volume with the suggested defaults or change them if desired. Click "Finish" to format the drive and make it accessible to the operating system. Hope this helps.
Jan 09, 2013 | Western Digital My Book Home 500GB...
Hard drive not accesSible
Dec 23, 2012 | Computers & Internet
how to i change the drive f back into what it was now dvd rw
If you are using Windows XP.
1. Find the 'My Computer' icon (usually located in our Start Menu)
2. Right-Click on 'My Computer' and select 'Manage'
3. Click on 'Disk Management'
4. In the bottom-right list, Right-Click the drive you want to change and select 'Change Drive Letter and Paths..."
5. Click "Change..."
6. Select a new drive letter and hit 'Ok'
7. Click 'Yes' to the warning that pops up after
You're done.
If you use Windows Vista, figure 1 below shows you how.
Figure 1:
Changing Drive Letters in Windows Vista
(http://pcsupport.about.com/od/windowsvista/ht/chdrlettervista.htm)
Here's How:
  1. Click on Start and then Control Panel.
    Tip: In a hurry? Type computer management in the search box after clicking Start. Choose Computer Management from the list of results and then skip to Step 4.
  2. Click on the System and Maintenance link.
    Note: If you're viewing the Classic View of Control Panel, you won't see this link. Simply double-click on the Administrative Tools icon and proceed to Step 4.
  3. Click on the Administrative Tools link.
  4. In the Administrative Tools window, open the Computer Management program.
  5. In the Computer Management window, locate the Disk Management option on the left and left-click on it.
    If the Disk Management option is not visible, look under the Storage option by clicking the small arrow next to the word Storage.
  6. On the right-hand side of the screen, locate and right-click on the drive that you wish to change the drive letter of and choose Change Drive Letter and Paths....
  7. In the Change Drive Letter and Paths window, click on the Change... button.
  8. The Change Drive Letter or Path dialog box will appear. Choose the drive letter you wish to assign to this partition.
    Click OK.
  9. The Confirm window that appears advises you that "Some programs that rely on drive letters might not run correctly. Do you want to continue?".
    Note: If you have software installed to this drive, the softwaremay stop functioning after a drive letter change. Nearly all softwaredefaults to the primary drive though, so this is rarely a concern.
  10. If you're sure you want to make this change, click Yes. Depending on the speed of your PC, the change should be nearly instant.
  11. You can now close the Computer Management and Administrative Tools windows.
Aug 04, 2009 | Teac (DW-224EA-AM6) CD-RW/DVD-ROM (Combo)...
103 people viewed this tip
David Payne
David Payne
