Tip & How-To about Computers & Internet
Speed up your browsing of Windows 2000 & XP machines.
Here's a great tip to speed up your browsing of Windows XP machines. Its actually a fix to a bug installed as default in Windows 2000 that scans shared files for Scheduled Tasks. And it turns out that you can experience a delay as long as 30 seconds when you try to view shared files across a network because Windows 2000 is using the extra time to search the remote computer for any Scheduled Tasks. Note that though the fix is originally intended for only those affected, Windows 2000 users will experience that the actual browsing speed of both the Internet & Windows Explorers improve significantly after applying it since it doesn't search for Scheduled Tasks anymore. Here's how :
Open up the Registry and go to :
HKEY_LOCAL_MACHINE/Software/Microsoft/Windows/Current Version/Explorer/RemoteComputer/NameSpace
Under that branch, select the key :
{D6277990-4C6A-11CF-8D87-00AA0060F5BF}
And delete it.
This is key that instructs Windows to search for Scheduled Tasks. If you like you may want to export the exact branch so that you can restore the key if necessary.
This fix is so effective that it doesn't require a reboot and you can almost immediately determine yourself how much it speeds up your browsing processes.
Thanks
Have a great day.
Bhautesh
Computers & Internet Logo
file sharing between windows 2000 and XP
1) I believe that Windows XP is not setup for that by default,
you may need to install the old BETBUI service.
2) Also, if the 2000 machine has a login password installed,
it will NOT allow any other machine to browse it, without
logging in.
3) Password-less file sharing over NETBUI was available
on the consumer side of windows:
Windows 3.11 for Work groups
Windows 95, 98 and Millenium.
The professional versions of windows, built on NT
technology require a login:
Windows NT 4.0, Windows 2000, Windows XP,
and now Vista.
4) The best work around is to login to the 2000 machine when
it prompts you for a password, using your regular USER ID
and PASSWORD.
If the 2000 machine is not setup with a secure login,
just create a new account, ranking power user or higher.
5) Note that you only need to login over the network ONCE,
because windows XP can REMEMBER your password,
and login automatically the next time.
6) Make sure that the firewall (or A firewall) is not
blocking access to either machine, just disable the
firewalls for testing.
Similarly, if your LAN is behind a residential router, using
the router as a smart hub or switch, make sure that
the routers MAC address access blocking is disabled,
until you get everything setup and tested.
7) Finally if a PC is not visible in a work group, this does not
mean that it is not accessible. This is a Windows quirk.
You can try to access another computer by using the
default/administrative shares. These shares cannot be
disabled in XP, at least they will not stay disabled, as
they will restart during every reboot, whether you like it
or not.
This means that you can ALWAYS access all the drives
on another machine, whether you share them or not, unless
you take extreme measures in the local policies.
To access drive "E:" on a computer called "Henry" on a
machine in the same work-group,
open up windows explorer, and tyr the following into the
address line:
\\Henry\E$
This should access drive E:, after some delay, and possibly
a login prompt, even though drive is is NOT marked as
shared.
Down you just love windows ?!
Security by obscurity ?!
Microsoft is getting very good at hanging massive steel doors
on paper walls.
Hope this solves your problem, or gets around it.
Please rate my answers,
Martin
Jul 05, 2008 | Microsoft Windows 2000 for PC
Nav4_disp conflict?
The nv4_disp fix I was able to successfully restore my computer to tip-top shape in 5 easy steps. Here’s my 10 minute solution.
  1. Boot your computer into Safe Mode w/ Networking. For Windows XP users, this is accomplished by pressing F8 repeatedly when your computer is booting up. You will be presented with several options. Choose “Safe Mode w/ Networking.” This will boot Windows XP into Safe Mode, but you will be able to browse the Web.
  2. Go to NVIDIA’s Web site and download the latest display drivers for Windows XP. I saved the 20MB file to my desktop for easy locating later on.
  3. Remove the NVIDIA display drivers currently installed on your machine. To do this, right click on “My Computer,” then select Properties. Click the “Hardware” tab, then click “Device Manager.” You now see a list of hardware devices installed on your computer. Double click “Display Adapters.” You should now see your NVIDIA card listed. Click it once to highlight it, then click the “Uninstall” icon in the upper right of Device Manager menu. Say “peace!” as the NVIDIA drivers are removed from your machine.
  4. Install the updated NVIDIA display drivers. Double-click the NVIDIA setup file you saved to the desktop earlier. The installation will run its course.
  5. Reboot your computer.
After following these steps, Windows XP should start up as usual (prior to our little nv4_disp bug). Your “nv4_disp” problem is officially solved.
What caused the nv4_disp problem? In short, I have no idea. I’m actually still trying to figure this out, so I welcome any comments about what could have been the cause. In doing some quick searches across the Web, however, I see that this is actually a common problem.
Mar 06, 2008 | PNY Verto GeForce PCX 6600GT, (128 MB), (3...
107 people viewed this tip
David Payne
David Payne
