Tip & How-To about Computers & Internet
How to Update My Nvidia Graphics Card/Onboard Drivers.(HP, Dell , MSI , XFX , ASUS ,Gigabyte)
It is recommended that you update your graphics card drivers at least once every two to three months. This will ensure that new software can use your graphics card to it's full potential.
There are two sets of drivers usually available for any given card namely : The manufacturer driver and the Nvidia driver. Many manufacturers can create the same card all based on the same Nvidia chipset on the card. Thus , there are no major differences between the different manufacturer's cards as they all use the same chipset and basic driver.
Thus you could theoretically use even a different manufacturer's driver for your card , but this is prevented using software.
This difference in the drivers are minute and relate to small details of the card operation.
A great misconception among computer users is that you can only use the driver from the manufacturer of your graphics card. This is completely untrue as the Nvidia drivers are updated more than most manufacturer's drivers and for me personally simply work better.
So now I will show you how to update your card from the Nvidia website.
#1 Identify the card in your computer.
Firstly you will have to identify your card if you don't know the model number. This can be done in three ways...If you know the model number , proceed to step 2.
  1. Look on the box if you have one for your model which is something like 9600gt / 8800gts / gtx275.
  2. Open your side panel of your PC and have a look on the card itself for the model number.
  3. Go to Control Panel - System - Device Manager - Display Adapters and your model should be displayed here if you have a previous version of the drivers installed.
For a laptop or onboard card , try googling either the laptop model number or the motherboard model number to determine the chipset model.
Now that you have determined the model of your card , we can proceed to step 2.
# 2 , Finding , Downloading and installing the correct driver.
Go to the NVIDIA DOWNLOAD SITE
Then Follow the following steps. I will use as an example the 9600gt for windows 7 32bit in English UK
You can also try using the self identification function on the website.
Select The Product , in this case a GeForce
Select the model series , in this case a 9000 series (the card is 9600 so it falls in the 9000 series)
Select your operating system , I'm using Win7 32bit
And finally select your preferred language.
Now hit the search button and this will bring up your download page.
Just hit the download button and the download will start.
Once the download completes , simply run the setup and restart your computer once this completes and you have a updated graphics card driver.
Please remember to rate this tip if you found it useful.
StephanSA
Computers & Internet Logo
updated the driver and my card not working from that time> card getting overheated when useed
HI. This will usually occur if the actual new updated driver pack is corrupted or flawed through no fault of your own. I would recommend to restore the previous working driver. This will restore stability until a new update is available. This will happen from time to time, due to the fact that, many driver updates may be packed incorrectly or built with flawed code. Simply rollback to the previous driver to correct the issues with the overheating. Continuing to run this defective new driver pack will damage your chip set.
Aug 06, 2011 | XFX NVIDIA GeForce 8500 Graphic Card
I have an AGP rage 128 video card in an AMD athlon
did you try to take the card out and then put it back in?
Oct 30, 2009 | Ultra ATI Rage 128 Pro Graphic Card
ACTIVATE MY VGA
need to go on line to the manufacture and request updates and activation and it will be done automatic every few months, there are free software at pcworld.com and other pc magazines download center of free update software update and drivers update and any or new software fixs that will improve the performance of your equipment and operation on the system.
Feb 26, 2009 | MSI NX7300LE-TD256EH GeForce 7300 LE,...
monitor screen freeze with driver...
hi! you don't need to update the driver cause the problem is in your hardware. Graphic seems to be a bit grounded, try cleaning the contact pins of your AGP graphic card with eraser, clean it side by side and then put it back again to an AGP slot, then boot your CPU again. If it still the same, try it in another motherboard that support you graphic card just to be sure before we conclude that its the graphic card has the problem. Anyway if it still under warranty you can claim for a replacement to the store where you bought the graphic card.  Have a nice day!
Dec 28, 2008 | ATI RADEON X1650 Graphic Card
ATI 9600 xt problems
Hi, Im guessing that your motherboard has an intergrated video card & you installed the 9600 card into the opened AGP slot on the board. If you would have listed the model number of your motherboard I would't have to guess. What you need to do is enter your bios & make a change so your bios loads the AGP slot & not the intergrated video card. How to get into your bios? As soon as you turn on the Pc press the Delete key every two seconds. If your system fails to load the bios than you will need to try some of the others F keys. Let the PC finish loading. Re-start the PC. As it starts up try the F1 key every two seconds. Continue in this manner using these other F keys untill your system boots into the bios. F2, F10 or F12. One will work for you. Once in the bios use your manual if you have one. You are looking for Video display. You want the bios to load the AGP slot first, this will disable the intergrated video automatically. Your Pc will now see your 9600 video card & you will be able to load it's software. If the 9600 uses ATI's software you should update the Radeon software by going to ATI/AMD & update your video software with the latest drivers. Click the link I have posted below to upgrade your Radeon 9600XT card. Good idea to save the link.
http://ati.amd.com/support/driver.html
Fill in the needed information to get to your driver software.
If your using Win XP Pro or Home click here:
http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp
Feb 19, 2008 | ASUS RADEON 9600XT, (128 MB) AGP Graphic...
342 people viewed this tip
David Payne
David Payne
