Tip & How-To about Computers & Internet
How to Remove and replace laptop keyboard
The direction below will help teach you how to remove laptop keyboardand replace it. This article doesn’t cover all models, but you may geta rough meaning, the disassembling steps are proper for most laptops.
Warning:
-If your laptop is still within the promised warrant period, thenplease don’t take your laptop apart, otherwise, you may lose thepromise of quality warrant.
-Before you open your laptop, please first remove the laptop battery and pull off ac adapter for laptop.
-If you break the keyboard faucet on the motherboard by accident, then you’d have to replace the entire motherboard.
-You should take the responsibility of the result.
This is HP/Compaq NC6120 laptop, and this method is also proper for other model laptops.
The indicator cover and the hinge cover are in one piece and isscrew-less in this laptop. Many others laptops the hinges cover areseparate from the indicator cover.
There are common also that screws are found underneath the indicator cover or behind the hinge covers.
In this case, there’s no need to remove the baffle of the keyboard,however, for many other models, you have to follow the next steps:insert a little screwdriver under the keyboard baffle, lift itcarefully and then put plastic clip into it, and then move the laptop replacement keyboardbaffle with your fingers; be careful, as some model baffles might beconnected to motherboard with cable. If you just pull out the cableincautiously, then you have to plug it back again, to remove thekeyboard, it’s not that necessary to disconnect the keyboard bafflefrom motherboard. You’d just need to release the baffle and then youcould see the screws used to fasten the keyboard
Remove screws and latches.
Just as the picture 3 shows, you could find the screws used to fastenkeyboard from the back cover of the laptop, 2 in all, and generally,there should be 2 to 4 screws on common laptops. And beside the screwfastening hp laptop keyboard,there marks some sign; under certain circumstance, Hinge cover hasscrews to frap keyboard. However, this tutorial doesn’t involverelevant case, hope you could notice that.
Push latches downward.
As picture 4 shows below, you could find some latches on the laptopkeyboard, total 4 latches, beside the key F1, F4, F8 and F12, use alittle flat screwdriver to slide down gently.
And as picture 5 shows below, lift the keyboard from the motherboard, once the HP/Compaq NC6120 Keyboardis moved and the flat connection cable between the keyboard andmotherboard exposes. And before you pull the flat connection cable outof interface, first unlock the connection cable-lock.
As picture 6 shows below, it illustrates how to unlock the keyboard cable-lock, and move it 1-2mm cautiously.
Attention:
lift up the cable-lock on both ends by not more than 1mm.
Over lifting would break the clips that function to position the cable in place.
As picture 7 shows below, now it’s the time for the HP NC6120 Keyboardto get off from laptop, and then pull the connection cable out of it.And when install the keyboard, follow the steps above just by theopposite sequence.
Computers & Internet Logo
how to remove spark plug
I have attached an article about how to change the spark plug on a walk behind mower.
The directions should be roughly the same despite the difference in brand and model.
I hope this helps!
How to Change the Spark Plug on Toro Recycler Self Propelled Mower
May 05, 2014 | Mtd 22" Yard Machine Push Mower
i have a blackberry bold 9000 mobile phone , it doesn't ring when the back cover is on , but when i remove the back cover it rings fine , what seems to be the problem and can u suggest a solution , can u help me
Hi boy_great,
You need to set the settings for the cover and without cover mode of the blackberry ,
Please follow the below steps :-
  1. Find the advanced option in the profiles menu and change the in and out settings for the holster or the cover. I hope this is the problem in your case.
  2. I direct removal of the battery also works sometimes , all you need to do , is
    remove the battery when your phone is switched on and after thirty to forty seconds connect the battery back again and restart the phone.Hope his helps ..:)
May 11, 2011 | Computers & Internet
how to replace memory cards on a dell laptop D600
Hello.
There's a great article found online from eHow with the following instructions:
Things you'll need:
  • SO DIMM 200-pin DDR SDRAM memory module
  • Phillips screwdriver
  • Shut down any currently running applications and turn off your laptop. Disconnect the power cord and any other attached cables. Remove any installed PC cards. Turn the laptop over and locate the battery compartment at the front edge of the device. Push the latch in the direction it indicates and remove the battery from the laptop.
  • 2 Examine the memory module cover, located next to the battery compartment. Unscrew the screw securing the memory module cover to the laptop. Remove the cover and set it aside.
  • 3 Push apart the clips located on either side of the currently installed memory module. Slide the module out of the socket and set it aside.
  • 4 Align the notch on the connector end of the memory module with the crossbar in the socket. Insert your replacement module into the socket and apply firm pressure until it is seated properly. Push the module downward until the clips lock it in place.
  • 5 Replace the memory module cover and screw it securely in place. Reinsert the battery into the battery compartment. Reinstall any previously removed PC cards and reconnect the power cable and any other previously disconnected cables. The laptop is now ready for use.
  • Hope this helps.
    Dec 23, 2010 | Computers & Internet
    240 people viewed this tip
    David Payne
    David Payne
