Tip & How-To about Heating & Cooling
Air cond.
If your ac is running but no air is comming out the vents first check your filters they should be changed in summer time every month winter every other month keep clean for better air flow and to keep your electric bill down if its not blowing cold air you are low on freon if no air is comming out at all turn it off that means it is froze up that usully happens when you turn the thermostat setting to low you really dont want to set below 75 because the compresser never will shut off and it will freez up.
Heating & Cooling Logo
Why do condensation and frost come from air vents and can this be related to windows fogging unrelentingly in winter?
Suggest you check to see if your car has a cabin air filter. If so, changing this usually helps prevent the issue.
Oct 07, 2014 | Dodge Charger Cars & Trucks
heat and ac stopped working in 05 kia sedona
check that the heater control (tap ) is being turned on by the controls.. Have an accredited ac mechanic check the ac system .
Jan 07, 2014 | 2005 Kia Sedona LX
not blowing as much air out of the vents
Check your filter, could be dirty and restricting the airflow.
Also, most furnace/AC combination units are set to blow more air in summer and less in winter, could be you're used to summer airflow level.
Dec 16, 2010 | Heating & Cooling
Edgestar Portable AC/Heater
Yes, you need it to be hooked up in the winter also. If you don't have it hooked up then you are heating , and cooling the room at the same time.
Dec 02, 2007 | Heating & Cooling
150 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
