Tip & How-To about Refrigerators
Refrigerator not gettin cold but freezer is good
Ok if you have a refrigerator that leaks from the freezer into the frige all you have to do is put all the food in an ice chest turn it off or better yet unplug it for no less than three hours then clean up the mess you just made on the floor and dont forget the standing water under the veggie drawers plug it back in and turn the thermostat setting to 3 and dont forget get your food back out the ice chest and put it back in frige grab a beer and relax cuz your done ha
Refrigerators Logo
The ice cubes from my refrigerator causing a bitter taste in mouth and discomfort in chest following drinking of water with ice cubes in same
try to clean it external evaporator and internal evaporator of the machine maybe some left over water is stock in the internal evaporator that's why its cousing the smell.
Mar 01, 2013 | Refrigerators
how do i defrost?
You have to remove all the food to a good ice chest with no ice. Pack it as full as you can before starting another one. You may need to put some in your refrigerator freezer. It will stay frozen for several hours while you melt the ice in the chest freezer. You can direct a fan blowing into it to speed up the melting. If it doesn't have a drain to catch the water in a tub you'll have to soak the water up in a towel etc. Don't chip at the ice to break it up quicker. You can damage the refrigeration coils.
Oct 09, 2010 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
freezer is not defrosting
1. Remove all of the food from inside the freezer and place it into the ice chest. Use more than one ice chest, if necessary. Cover the food with ice from a 10 lb. bag of ice. Alternatively, place all of the food from your freezer into the refrigerator compartment, packed tightly together.
2. Place one or two 10 lb. bags of ice into one or two large bowls inside the refrigerator compartment to keep the food chilled. Keep the door to the refrigerator tightly closed and avoid opening it during the freezer defrosting process.
3. Unplug the unit and leave the freezer door open.
4. Let the freezer defrost overnight or for at least eight hours.
5. Use the towels to wipe up the melted ice.
6. Plug in a hair dryer and direct it to the interior of the freezer to melt any remaining ice from the walls and door. Be sure to direct it into the vents of the freezer, too.
7. Wipe up any water from ice melted with the hair dryer from inside and around the freezer.
8. Plug the freezer back into the outlet, and return food still solidly frozen to the freezer compartment from the ice chest or refrigerator. Use any thawed foods within a day or two or discard.
May 25, 2010 | Maytag 21.0 Cu. Ft. Top-Mount Refrigerator...
I have water pooling inside the refriderator. It
there is a drain in the freezer than gets pluged, unplug frige from wall, put food in ice chest take hair dryer and melt ice thats at back wall in freezer remove icemaker if there, and back wall of freezer inside, melt any remaining ice, **** up water with wet vac or sponge,see the pinky size hole in the pan under the coils, point hair dryer at it for a wile. now take the the lower back cover off behind frige and blow all the dust out and find the plastic tube, about the size of your finger and put the wet vac on it until you can hear it sucking in the freezer, take e cup of hot soapy water ond poor it in the freezer pan. put everthing back and your good to go
Dec 09, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
179 people viewed this tip
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
