Tip & How-To about Computers & Internet
If your laptop wont boot up....
If You laptop wont boot up, try removing the battery and pressing and holding the power button for 30-60 seconds. This SOMETIMES resets the laptop.
Hint: re-insert your battery before you reboot the system.
Computers & Internet Logo
it wont come on. it wont turn on
Try a hard reset. Sometimes it works and is always the first step to take.
Remove the battery and the ac adapter plug from the laptop.
Press and hold the power button for fifteen seconds.
Install either the battery and A/C adapter .Now just press the power button to attempt a boot into the OS.
Contract for further instructions.
Hope this helps.
Oct 07, 2011 | HP Pavilion dv1000 Notebook
the laptop will not come on?
Hi.
Try a hard reset. Sometimes it works and is always the first step to take. Remove the battery and the ac adapter plug from the laptop. Press and hold the power button for forty seconds. Install either the battery or ac adapter power and press the power button toattempt a boot into the OS.
Hope this helps. Shiboram
Sep 18, 2011 | Toshiba Satellite Pro 4600 Notebook
dell inspiron m5030 wont boot up, ac adapter has green light then once it is pluged in light goes out.
Install the battery and ac adapter .Now press the power button to attempt a boot into the OS.
If that doesn't work then remove the hard disk to see if it gets past the splash screen and the BIOS whines that it can't find a boo-table OS. That would indicate a hard disk failure.
Also try to remove the memory module(s) from the DIMM slots and then reinstalling them. That reset the modules and cleans some oxidation off the module pins (if there is any)
Hope this helps.
Let me know if you need more information
Thanks
Apr 26, 2011 | Dell Inspiron M5030 Laptop
My Apple mac book pro will not boot up. I have a grey screen. I've taken out the battery held doen the on button for 5 seconds and re connected it nut I've still got a grey screen. Help
The grey screen is the bios of your laptop is booting, this is freezing for some reason.
Do 3 things.
Try holding power button down for longer at least 10-20 seconds.
do a PRAM reset, apple symbol, alt P & R keys all held on boot up.
Do a smc reset.
  1. Shut down the computer.
  2. Disconnect the MagSafe power adapter from the computer, if it's connected.
  3. Remove the battery.
  4. Press and hold the power button for 5 seconds.
  5. Release the power button.
  6. Reconnect the battery and MagSafe power adapter.
  7. Press the power button to turn on the computer.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Apple MacBook Pro Notebook
Toshiba M305-S4819 laptop won't turn on. After
check first the chager is working or not, then power button, after that dc connector.. if its okay motherboard problem need to check th MB then fix it..
Sep 10, 2009 | Computers & Internet
279 people viewed this tip
David Payne
David Payne
