Tip & How-To about Microsoft Windows Vista Ultimate Edition
Speed Up Browsing
When you connect to a web site your computer sends information back and forth. Some of this information deals with resolving the site name to an IP address, the stuff that TCP/IP really deals with, not words. This is DNS information and is used so that you will not need to ask for the site location each and every time you visit the site. Although Windows XP and Windows XP have a pretty efficient DNS cache, you can increase its overall performance by increasing its size. You can do this with the registry entries below:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Dnscache\Parameters]
"CacheHashTableBucketSize"=dword:00000001
"CacheHashTableSize"=dword:00000180
"MaxCacheEntryTtlLimit"=dword:0000fa00
"MaxSOACacheEntryTtlLimit"=dword:0000012d
Make a new text file and rename it to dnscache.reg. Then copy and paste the above into it and save it. Merge it into the registry.
Microsoft Windows Vista Ultimate Edition Logo
website not displayed error http 500
The Web server (running the Web Site) encountered an unexpected condition that prevented it from fulfilling the request by the client (e.g. your Web browser or our CheckUpDown robot) for access to the requested URL.
This is a 'catch-all' error generated by the Web server. Basically something has gone wrong, but the server can not be more specific about the error condition in its response to the client. In addition to the 500 error notified back to the client, the Web server should generate some kind of internal error log which gives more details of what went wrong. It is up to the operators of the Web server site to locate and analyse these logs.
500 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle when it communicates with the Web server:
  • Obtain an IP address from the IP name of the site (the site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
  • Open an IP socket connection to that IP address.
  • Write an HTTP data stream through that socket.
  • Receive an HTTP data stream back from the Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receives an HTTP status code that it recognises as '500'. (Last updated: March 2012).
Fixing 500 errors - general
This error can only be resolved by fixes to the Web server software. It is not a client-side problem. It is up to the operators of the Web server site to locate and analyse the logs which should give further information about the error.
Fixing 500 errors - CheckUpDown
Please contact us (email preferred) whenever you encounter 500 errors on your CheckUpDown account. We then have to liaise with your ISP and the vendor of the Web server software so they can trace the exact reason for the error. Correcting the error may require recoding program logic for the Web server software, which could take some time.
Jan 28, 2013 | Facebook Social Network
Please describe solution of error 413 problem:
HTTP Error 413 Request entity too large
Introduction
The Web server (running the Web site) thinks that the HTTP data stream sent by the client (e.g. your Web browser or our CheckUpDown robot) was simply too large i.e. too many bytes. What constitutes 'too many bytes' depends partly upon the operation being attempted. For example a request to upload a very large file (via the HTTP PUT method) may encounter a ceiling on upload file size set by the Web server.
413 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle:
This error occurs in the final step above when the client receive an HTTP status code that it recognises as '413'. Frank Vipond. September 2010.
Fixing 413 errors - general
This error seldom occurs in most Web traffic, particularly when the client system is a Web browser. The problem can only be resolved by examining what your client system is trying to do then discussing with your ISP why the Web server rejects the number of bytes sent by the client system.
Fixing 413 errors - CheckUpDown
This error should simply never occur on your CheckUpDown account. If it does, it typically indicates defective programming of our systems or of the Web server which manages the site. The length of the HTTP data stream we normally send is relatively small and well within the limits of what most Web servers should accept.
Please contact us (email preferred) whenever you encounter 413 errors - there is nothing you can do to sort them out. We then have to liaise with your ISP and the vendor of the Web server software to agree the exact reason for the error.
hope this helps
Mar 01, 2011 | Computers & Internet
JN763. Access rejected from your IP address.
To resolve this problem, follow these steps.
  1. Using the Internet Service Manager (Microsoft Management Console), open the Internet Information Server (IIS) snap-in and select the Web site reporting the 403.6 error. Right-click the Web site, virtual directory, or file where the error is occurring. Click Properties to display the property sheet for that item.
  2. Select the appropriate Directory Security or File Security property page. Under IP Address and Domain Name Restrictions, click Edit.
  3. In the IP Address and Domain Name Restrictions dialog box, if the Denied Access option is selected, then add the IP address, network ID, or domain of the computer that requires access to the exceptions list.
    In the IP Address and Domain Name Restrictions dialog box, if the Granted Access option is selected, then remove the IP address, network ID, or domain of the computer that requires access to the exceptions list.
Jan 31, 2011 | Microsoft Computers & Internet
help me to solve my problem
Test your account with web messenger by logging in here:
http://webmessenger.yahoo.com/
If this fails, it means that there is a problem with your userid, password or account. Contact Yahoo for assistance.
If this works, then proceed to the next step.
Ensure you have a good stable internet connection.
Uninstall Yahoo Messenger and everything associated with your messenger.
Download the latest version from messenger.yahoo.com.
Try to log in again.
This should work and fix your problem.
Let me know how it works out and don't forget to give me a good rating as well as your vote.
Mar 25, 2010 | Yahoo Messenger
Jul 27, 2009 | Computers & Internet
349 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
