Tip & How-To about Microsoft Windows Vista Ultimate Edition
How to change windows log in sound
Goto control panel -> sounds and audio devices....
select sound tab from that dialogue box...
now select windows logon from program events and browse to set ur desire sound(the file should be in wav format only)
Microsoft Windows Vista Ultimate Edition Logo
the pdf button does not work
Make sure Epson Scan and the Epson Creativity Suite are installed correctly. See the Start Here sheet for instructions.
  • Make sure your Windows system is set up for scanner events as follows.
  • Windows Vista:
    Click sw_startbutton_1_er.gif > Control Panel > Hardware and Sound > Scanners and Cameras, or click sw_startbutton_1_er.gif > Control Panel and double-click the Scanners and Cameras icon. Click your scanner's icon, then click Properties. (When you see the User Account Control window, click Continue). Click the Events tab in your scanner's Properties window and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
    Windows XP:
    Click Start > Control Panel > Printers and Other Hardware > Scanners and Cameras, or click Start > Control Panel and double-click the Scanners and Cameras icon. Then right-click your scanner's icon and select Properties. Click the Events tab in your scanner's Properties window and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
    Windows 2000:
    Click Start > Settings > Control Panel, double-click the Scanners and Cameras icon, then select your scanner and click Properties. Click the Events tab in your scanner's Properties window and make sure the Disable device events check box is not checked. Also make sure the desired button is selected in the Scanner events list box, and the desired application is selected in the Send to this application list.
  • In Mac OS X, make sure you did not install the scanner software in Classic mode.
  • Epson Perfection V500 Photo Scanner
    Sep 17, 2013 | Epson Perfection V500 Flatbed Scanner
    i lose my sound
    Here is a guide to the sounds on a computer
    the drivers might have been corrupted by something foreign or you might have got a virus run your antivrus program
    if your computer came with a motherboard disc the sound drivers could be on it
    you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
    a yellow? question mark means you need to install/update driver to do this
    right click to install driver also
    click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
    click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
    click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
    hope this helps
    Jan 09, 2011 | ASUS P5PE-VM Motherboard
    i have reboot my pc.and now my songs are not playing?
    check your sound driver first.
    if sound driver functioning.
    go to start button.
    >control panel
    >sound, speech and audio devices then click sound and audio devices
    sound and audio devices properties box appear
    >click sound tab
    in the program events find start windows and windows logon then browse for media sound input for your windows bootup sound music.
    if that way cannot funtioning. you need to reinstall windows to fix this problems.
    Jun 27, 2010 | Computers & Internet
    no matter what I do/change I cannot get any windows sounds/alerts for startup/closedown or Outlook Express email. Tried systemrestore,did not help, tried changes in conrol panel still no sound except more then enough for speakers, videos yahoo alerts etc. Help Plz???
    asuming your sound card and speakers are working.
    From the control panel goto sounds and audio devices, double click,select sounds, under sound scheme select windows default, u can then go down the program events and select the sounds u want.
    Sep 02, 2009 | Dell Dimension™ B110 PC Desktop
    problem with compaq presario speaker
    Usually the driver for the sound system got a little screwed up.
    According to the documentation; this is what they recommend, however, do not flip out if you have already tried this. Go past this section and I will tell another approach.
    Checking your audio functions
    To check the system sound on your computer, follow these steps:
    1. Select Start > Control Panel.
    2. Click Sounds, Speech, and Audio Devices > Sounds and Audio Devices.
    3. When the Sounds and Audio Devices Properties window opens, click the Sounds tab. Under
    Program events, select any sound event, such as a beep or alarm, and click the test button.
    You should hear sound through the speakers or through connected headphones.
    To check the record functions of the computer, follow these steps:
    1. Select Start > All Programs > Accessories > Entertainment > Sound Recorder.
    2. Click the Record button and speak into the microphone. Save the file to your desktop.
    3. Open Windows Media Player and play back the sound.
    NOTE: For best results when recording, speak directly into the microphone and record sound in a
    setting free of background noise.
    ▲ To confirm or change the audio settings on your computer, right-click the Sound icon on the
    taskbar, or select Start > Control Panel > Sounds, Speech, and Audio Devices > Sounds and Audio Devices.
    Now, that is the HP way. And I suggest you do that.
    Another way would be to find the installation disk. And put it in your drive, then got to Start, Control Panel, System, and when that pops up go to Hardware, and then pick the Device Manager.
    Delete the Sound section. Windows will then wander around a bit, but will then try to reinstall them. When it does (and it will ask for the A drive usually) hit browse and point it to whatever drive you have put the installation driver disk in.
    Good Luck,
    -t
    Mar 04, 2009 | HP 2133 Notebook PC
    367 people viewed this tip
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
