Tip & How-To about Microsoft Windows Vista Ultimate Edition
Super fast shutdown
If u want to shutdown ur pc faster or slower:
1- start-->run-->regedit
when u start run and then write regedit
2- +HKEY_LOCAL_MACHINE
+SYSTEM
+CurrentControlSet
Control
left kick on control and u will find WaitToKillServiceTimeout.
dobbel kick on WaitToKillServiceTimeout.
in WaitToKillServiceTimeout its 20000 it means 20 secunds...if u want to shudown windos faster then get the numbers smaller, like 10000 or 5000 (10 sec or 5 sec) or if u want to shutdown longer writ 50000 (50sec).
Microsoft Windows Vista Ultimate Edition Logo
locked out c drive
Go to regedit
Navigate to hkey local machine >System>Current Control Set>Control>Storage And set the value to 0
U will be able to read write ur device again
Jan 05, 2014 | LaCie Computers & Internet
I have a Toshiba L305-s5955 and my dvd drive has disappeared. How do I get it back? Thanks.
If the DVD drive has disappeared in the windows explorer.
Here's the step.
1. Go to Start, on the start search box,type REGEDIT and enter. A registry editor will come up.
2. On the left pane of the window, there are folders.
Open HKEY LOCAL MACHINE/open SYSTEM/open Current Control Set/ open CONTROL/ open CLASS/ open the 4D36E965...folder
3. After opening the 4D36E965, on the right pane of the window, under name look for the lower and upper filter files, or even just one of them and DELETE.
4. Then restart NB to take effect.
5. Check in the windows explorer if the DVD-RW drive is back on the list.
6. Insert a disc to check.
Feb 27, 2011 | Toshiba SatelliteĀ® M115-S1061 PC Notebook
I picked up this program called personal antivirus and I can't get rid of it.i looked in my programs and it's not even there.Any ideas?
go to start menu, then go to "run", then type regedit and hit enter.
Now you are in registry.
Find the HKEY LOCAL MACHINE and expand it, then find Software, and expand it. You should see your program here, right click and delete file.
Do the same with HKEY LOCAL USER
Also go to start menu, search , type program name. When found, right click and delete all files.
Oct 01, 2009 | HP Compaq Presario SR2180NX (RK548AA#ABA)...
cd drive not detected
Lets do this.
1. Close all programs
2.Click on Start, Run, and type REGEDIT and press Enter.
3.click HKEY LOCAL MACHINE - SYSTEM - Current control set - control - class - select {4D36E965-E325-11CE-BFC1-08002BE10318} - on the right hand side you'll find upper filters and lower filters entries - right click and delete both(Upper and lower filters) - restart your computer and hope this works for you,
Awaiting response.
Thanks..
Sep 08, 2009 | Acer Aspireā„¢ T180 PC Desktop
343 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
