Tip & How-To about Computers & Internet
How to delete files that are used by other programs in windows XP/Vista?
Today tip will help you to delete the files and folders that are being used by another programs and applications, for example a virus affected file. You have tried to delete such kind of files or folders and received the any following messages.
· Cannot delete file: the file is in use by the other program
· Cannot delete file: There has been a sharing violation
· Cannot delete file: The file is in use by another program or user
· Cannot delete file: Disk is not full or write-protected and that the file is not currently in use.
· Cannot delete file: The source or destination file may be in use
Normally, a windows restart will allow you to delete such files or folders that are being used by other program, but if you want to manage it without restart your computer then simply you need to download a freeware tool called Unlocker.
You can download this tool for any windows version using Unlocker link. Download it and run the easy setup.
After installation, right click on file or folder that you want to delete and select the option Unlocker.
If your requested file or folder is used or locked by other application then a small window listing of lockers will appear.
Here simply click on “Unlock All” button and now you can easily delete this file.
Thanks,
Bhautesh.
Computers & Internet Logo
when i want to open device manager this option come. windows\system32\devmgmt.msc.
The error is popping up because of corrupt system files. the system files might have been corrupted because of Virus attack or recent changes to your programs(install/uninstall/update applications)
Please try the below steps.
Method 1:
Try the following steps and check if that fixes the issue:
a. Click Start, type cmd, right-click cmd.exe and select Run as administrator.
b. At the command prompt, type regsvr32 msxml3.dll and then press enter.
Method 2:
Run System File Checker (SFC) scan to fix any corrupt system files. To do this, follow the steps mentioned in the link below:
How to use the System File Checker tool to troubleshoot missing or corrupted system files on Windows Vista or on Windows 7
http://support.microsoft.com/kb/929833
Method 3:
Run a Microsoft safety scanner to make sure computer is free from virus infection:
http://www.microsoft.com/security/scanner/en-us/default.aspx
Disclaimer:
If you run the virus scan the program that is infected with virus will get deleted. So you have to reinstall the program. Also if the files and folders are affected with virus then they might even get deleted.
courtesy: http://answers.microsoft.com
May 23, 2013 | Dell Inspiron 15r n5110 Laptop
example of computer viruses
virus can be many tyoes as file virus, hidden virus, boot sector virus and other types of virus
Jul 05, 2011 | Computers & Internet
my computer where infected with virus please help me to remove it
There may be another alternative.
You can remove the infected hard drive and use another computer to put it into as a slave/secondary drive.
You can then try to "Clean" the infections via this computers antivirus and malware cleaners. Check the Gizmo site for some really great advice and loads of programs that can help you.
Make sure this other computer's security is up to date first.
Jan 14, 2010 | Microsoft Windows XP Professional With...
i want to remove deepfreeze software from my pc but i forgot the password
follow the path name to it's folder and delete the contents, an example is:
c:\program files\deepfreeze
I am certain there are more folders in the path. Active files will not delete this way, so you may have to use task manager to turn off the deepfreeze applications to fully remove the program
Jun 04, 2009 | Computers & Internet
C:\resycled\boot.com is not a valid win 32 application.
I just had this problem and went to a few forums for answers.
Update your anti-virus program and restart your PC in safe mode by repeatedly pressing the "F8" key upon restarting.
When in safe mode, use your anti-virus program to scan your computer. When the scan is done it should tell you if it found anything that could be bad for your system.
When scan is finished, go to My Computer - Tools - Folder Options - View
When in "View" click on the button that says "show hidden files and folders". Select the "apply" button, then "OK".
Now, go to your infected drive (the one you cannot access) and "right-click" the drive followed by "open".
You should see the hidden folder "Recycler - resycled - Autorun.ini"
Select the files and then press and hold the "shift" and "delete" keys at the same time, then press the "enter" key. Restart your computer, and you're done. You should now be able to access the drive that had a problem.
If you do not see these files then chances are your anti-virus may have already taken care of the virus affecting your computer.
hope this helps
Jan 14, 2009 | Tablets & eReaders
170 people viewed this tip
David Payne
David Payne
