Tip & How-To about Computers & Internet
Cleaning your Keyoard
Hello
This is a tip explaining exactly what steps you you should follow if you would like to Clean your keyboard. What usually happens, is that keys get stuck, due to dust particles or faulty rubbesr under the keys itself.
Before we start cleaning, you need to shut down your computer and unplug your keyboard from either the USB slot, or the PS2 port.
Now, you will need:
  • Some Spirits/alcohol
  • Cotton swabs
  • high static cloth/cleaning cloth
  • Vacuum or compressed air
  • Clean, soft paint brush
  • And lastly, some patients..
Step1
Ok, the first step will be to place your keyboard in front of you on a level surface.
Now, either use a vacuum or some compressed air to ****/blow out the particles beneath the keys. If you use a vacuum or compressed air, turn the keyboard downwards so that gravity will pull the particles down as well.
Step 2:
When you are done removing the particles underneath the keys, place the keyboard on a flat surface like figure 1. Now you will need to dip the cotton swabs into the alcohol or spirits and clean the tiny spaces between each key.
Step 3:
Now, after you have claened all the tiny spaces between the keys as seen in figure 2, i usually use a regular soft paint brush and just brush off the whole keyboard, at the side of the keys, as well as the bottom side.
Step 4:
Lastly, take the cleaning cloth and put some alcohol on it. Now wipe clean the whole keyboard after you have completed the abovementioned steps.
Now, you are done. Just plug the keyboard back in, and start up your computer. I always keep my soft paint brush near, to minimize the dust builup on the keyboard between cleaning periods.
Hope you can find this helpfull and rate acordingly.
Kind regards
Andrea
Computers & Internet Logo
My keys are sticky and i would like to clean them out. how do i disassemble the keyboard?
Take a picture of your keyboard!! UnPlugg It!!! then use a small screwdriver and carefully pop off the keys, all of them.. let them soak in warm soapy water. while those are soaking, take some rubbing alcohol and q-tips and clean the rest of the board. towel dry and finish cleaning the keys. once dry use the picture and carefully start snaping the keys back into place. just take your time and all will go well. the first key removed should be an unused one.preferable at an edge. if something does go wrong it will happen the first attempt. if that goes well.. game on. if not so well.. just use rubbing alcohol and qtips on the whole thing while it is unplugged
Oct 29, 2013 | Razer Deathstalker Gaming Keyboard
Keys n,b and SPACEBAR and arrow keys aren't working on my Lenovo laptop
The keyboard is slowly dying. Try and clean the keyboard off with a Q-Tip and some rubbing alcohol, or purchase a new keyboard online for your exact model and install it.
Oct 18, 2013 | Lenovo 3000 Y410 Laptop
My Casio px 575r has two keys stuck in the upright position. I don't know how exactly to open the keyboard up for a further exam.
take screws out from back,will see PC board,remove all screws frm it to gain access to keyboard keys.Possible broken spring in one key or just gummed up.Clean with Q tips & rubbing alcohol.I cannot promise much but I clean electronics & PC keyboards this way & works for me,good luck
Oct 17, 2012 | Audio Players & Recorders
spilled water on laptop. now keys don't work. help.
Hello
First unpug it from your pc.Then try running a hair dryer on low heat into it.Most keyboards are somewhat rugged as far as taking damage from liquids.
Let it dry out for a few hours and try it again,if it does not work you will need to get a new one,as using a defective keyboard will cause other problems.
Mar 07, 2011 | Computers & Internet
how can I tell if caps lock is on please? I have an Acer 5732Z
You can use the Keyboard Acessbility options to activate sounds for these keys (CAPS, NUM and SCROLL LOCK) for XP just follow these steps http://www.worldstart.com/tips/tips.php/102
Jan 13, 2010 | Acer NSK8458AN Keyboard
148 people viewed this tip
David Payne
David Payne
