Tip & How-To about Winter Sports
Use a stomp pad when your on T-bar
It will give you an easier way to board
Winter Sports Logo
error 22 paper jam
Check the fuser exit sensor flag. The sensor is on a p.c. board on the bottom of the fuser. Three things happen to it. Sometimes the board comes out of its clips and drops away from the sensor arm. The arm itself can be stuck or broken. The ribbon cable going to the board can come loose. If you release the latches and move the front cover out a little, it will be easier to get in to the board and cable.
Feb 27, 2012 | Lexmark Optra Lx+ Laser Printer
hello mate, I have got problem with my plasma, it is 50 inch plasma Samsung. Problem : picture started fadding and now it has got blue screen and big black spot right in the middle of the screen which constantly expanding. I think it must be problem with picture tube, Can you please advice me what should i do, how much it gonna cost? thanks sumit
It is the Main pcb board.
"Digatal board"Not cheep. Can not give a exact price,without model number. but from 250-400.Can also be the t-com board.about 60-150 Plasma's Are
not easy to fix with out having it in the shop to check out. Some of the boards can cause the same problems. Lcd's are alot easier. Try out shop jimmy for used parts w/warenty. just put in model number. and it gives you a list of all the parts/prices. Some times can be foung on ebay. Hope some of this is useful to you.
Jan 15, 2010 | Samsung 50 in. Plasma TV
Video Board of the sony kv-32XBR200
have you heard about the jungle ic?
video board or what you call video detector, and video amplifier of a tv can only be found in the jungle ic or the system ic. try to resolder all pins of the ic.
you don't have to buy another board. if you can buy a schematic of the unit much easier for you fix it.
Apr 07, 2009 | Sony KV-32XBR200 32" TV
LED POWER ONLY LIFE, SCREEN DISPLAY DARKNESS
theres only one solution to the problem you have to replace the whole power supply board .its easier to replace them than finding and soldiering the defective parts like the capacitor on the board .u can just replace the power supply board if u think the power has a problem. if it doesnt work then u have to replace also the main board or the board connecting the rgb cable.its more expensive to replace the board but its worth it. ur lcd will work better and its easy to put them on the lcd casing .
Mar 01, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
914 people viewed this tip
Top Winter Sports Experts
vtrktrmn
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
