Tip & How-To about Computers & Internet
How to Clean and Disinfect your Keyboard and Mouse
Recent studies have shown that your average desktop Keyboard and Mouse have about 400 times more germs than the average toilet seat and are one of the most germ infected objects in the household.
This is understandable as you are probably touching it after you went to the loo , after you had your lunch , shaked someone's hand , touched a not to clean door handle to get in the room and then there is of coarse always the few drops of coffee and some cigarette ash in there if you smoke.
This combined with little hard to reach places and a relatively light free environment makes an ideal breading ground for germs.
For more info , see this article on the BBC web page. Click Here
So now , we need to clean our keyboards on a regular basis. My keyboard gets a lot of mileage so I have to clean it on a regular basis and learned a few tricks in the process which I will share in this tip.
This tip is only applicable to Desktop or freestanding keyboards and mice. Do not do this on your laptop.
Okay , so there are basically 3 steps.
#1 Clean off Dust and other solid objects.
#2 Clean off stains and other stubborn dirt
#3 Disinfect
You will need
  1. Vacuum Cleaner (not mandatory but recommended)
  2. Compressed air can
  3. Liquid alcohol based disinfectant in spray bottle
  4. Cotton swabs / Q-tips
  5. A clean microfiber cloth
To do this , go out and buy a can of compressed air from your local department store or electronics dealer. Get someone to hold the vacuum cleaner near to where you are working and start blowing compressed air in between the keys of your keyboard.
The vacuum will catch most of the debris and make for easier cleanup afterward if your keyboard hasn't gotten attention in a while.
Now , dip a q-tip in some of your alcohol disinfectant and rub it between your keys to clean the sides of every key.
Then , take your cloth and dampen a small area with some disinfectant or water and clean the top of the keys and the larger areas between keys. Do the same for your mouse.
#3 Disinfect
Now , use your compressed air at a reasonable distance from your keyboard and while spraying air , spray some disinfectant into the airstream and onto your keyboard. This will ensure that even the spaces between keys are disinfected. Now simply wipe off excess disinfectant from the top of the keyboard with the dry end of your cloth.
Also use some disinfectant on your cloth to wipe down your mouse.
And there you go , one germ free clean keyboard and mouse.
Please remember to rate this tip if you found it useful.
StephanSA
Computers & Internet Logo
xps 400, no keyboard in dos
Dear Sir:
I am recomending to go www. dell.com and go to troubleshooting section for diagnose the computer, the problem I see is driver some missing. You must need to reinstall. By that reason Run the Diagnose from Dell .
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 12, 2012 | Dell Dimension XPS 400 PC Desktop
NEED TO REPLACE THE SEAT AND COVER OF THE TOSCA TOILET
http://www.homeclick.com/web/catalog/product_detail.aspx?pid=365570&chnl=cse&ven=googlebase&cat=Bathroom%3AToilet%20Seats&brnd=Herbeau&itm=0651'Herbeau%200651%20Monarque%20Toilet%20Seat%20and%20Cover%20Only%20in%20Plain%20White%20-%200651
The picture shown with your post shows a toilet seat that looks like the one sold at site above.
But the site above is selling the toilet seat called the Monarque toilet seat and cover.
The particular seat shown is not called a Tosca.
Another site shows the identical whole toilet, and calls it the Herbeau
http://www.bizrate.com/miscellaneous/herbeau-toilet-and-toilet-seat/
The pdf from Eljer showing the Tosca toilet looks very similar to both the products shown on the two links above. Maybe this solves the question.
http://dallas.eljer.com/Products/Toilet/CatalogPage/0912000.pdf
Dec 05, 2010 | Eljer Toilet Seat Tosca 124200000
My USB mouse does not work I've tried using 3 different ones, My keyboard works fine in same USB ports
make sure the mouse lead is seated correctly and is not faulty also
make sure that the right type of mouse is selected it will be in the hardware tab or
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
hope this helps
Nov 30, 2010 | Dell Dimension XPS 400 PC Desktop
tosca toilet seat. Cant find any
But the site above is selling the toilet seat called the Manarque toilet seat and cover.
Another site shows the identical whole toilet, but calls it the Herbeau
Nov 08, 2010 | Eljer Toilet Seat Tosca 124200000
wireless mouse and keyborad will not work. replaces batteries and hit reset button on mouse and keyboard. can not get access to computer
Sounds like your USB circuit may have gotten fried due to a static discharge (assuming your keyboard and mouse are USB). You can purchase an "add-on" USB pci card or a PS2 Mouse and Keyboard.
Feb 01, 2010 | Dell XPS 400 PC Desktop
342 people viewed this tip
David Payne
David Payne
