Tip & How-To about Computers & Internet
How to Test Your Laptop Battery?
How to check charge times for laptop battery?
install all drivers and laptop batteryMaximiser ThinkPad configuration software, then open the “ControlPanel” ——”Thinkpad Configuration”——”Power Management”——”BatteryInformation”——”Cycle Count”, then it will show you
Laptop batteries canfail, or over time can lose their ability to hold a charge. If yourlaptop suddenly stops cooperating, you can usually determine if a badbattery is causing the problem by removing it from its bay (on thebottom or side of the laptop) and running the laptop from the lalptopac adapteronly. If the batteryless laptop runs properly when connected to theadapter, the battery has most likely kicked the bucket, shuffled offits mortal coil, and otherwise become defunct.such as”Dell Inspiron XPS M170 Battery
Dell Inspiron XPS M170 Battery 9 cells 6600MAH
You can further test this hypothesis by substituting a laptop batterythat you know is functioning well from another laptop of the samemodel. You may be able to borrow a coworker’s battery or take thelaptop to a cooperative retailer’s repair counter.
If, in the other hand, your batteryless laptop doesn’t run when connected to the laptop AC adapter, either the adapter or the laptop’s internal electronics have failed. Again, if you can borrow a known-good acadapter, use it to see if the problem is caused by the cords orconverter or if the issue lies deeper within the laptop itself.
How to charge for the new bought laptop?what to do to maintain the laptop battery?
Lithium(hydronium) battery (such as toshiba laptop battery ,compaq laptop battery)needscertain electromotive force inside to keep the activity of internalchemical substances. Therefore, you should charge full and use it up.Generally speaking, the first three charging take about six hours.Charge to 100% is ok then. You should not charge only for a shortperiod of time, when the electric power is less than 10%, charge intime. If you used it up completely, it’ll cause damage to laptop battery; at the same time, if the power is more than 60%, you should not charge as possible as you. The laptop battery which won’t be used for a long, should be used to about 50% power left, and then keep it in room temperature dry environment.
Computers & Internet Logo
lenovo thinkpad R51e ,when i power on the laptop it show error271
This error message is generated when the BIOS Date and Time is incorrect. Go into the BIOS configuration to change the Date and Time. When you reboot and still get the same error message then the BIOS battery is flat and needs to be replaced and the Date and Time setting needs to be change to the current Date and Time after replacing the battery.
If you cannot get into the BIOS configuration (press F1 on bootup) or you get a lock icon in the top LH corner of the screen, this is a Power on Password symbol, enter the passsword to bootup the laptop and then press F1 to get into the BIOS configuration.
Aug 10, 2009 | Lenovo ThinkPad R51e Notebook
IBM Laptop Battery Power Saving Tips
It's not just suitable for IBM laptop battery, everyone who has a laptop battery should have a read about this. If you need some laptop battery, you can visit: http://www.udtek.com
Jun 04, 2010 | Computers & Internet
Problem with a IBM ThinkPad T20 2647 PC Notebook
check ur hd for bad sectors...shutting down for no reason is usually this(bad sectors)
also check system information and check device manager..could be software problem/incompatabilty/no drivers installed/or two devices trying to use same resource and shutting down cos cant.
Jan 07, 2009 | IBM ThinkPad T20 2647 Notebook
IBM Thinkpad T23 Won't Start
do you have a hard drive install??
laptop need a hard drive to start up. the one time start up you see before is just a accident.
as far as battery not charge, that is the porblem you run into, when you get laptop from ebay (taking chance).
you also need to download all of the drivers from IBM for the laptop.
Dec 10, 2008 | IBM ThinkPad T23 2647 Notebook
Clean install of XP, but can't reinstall drivers
plz download the drivers from the manufacture website and try
Nov 27, 2008 | IBM ThinkPad T23 2647 Notebook
196 people viewed this tip
David Payne
David Payne
