Tip & How-To about Televison & Video
Watch various videos and unprotected DVDs on ARCHOS 7
The ARCHOS 7 offers customer uncompromised access to the Internet, TV and media content… With its stunning 7 inches amazingly high-resolution screen, 800x480 pixels, and huge disk capacity, it is the best travel company and portable audio/video player you can imagine, which will definitely accompany your travels and holidays in a comfortable and convenient way.
To enjoy videos on ARCHOS 7, you should make sure what file formats are compatible with it, following is the detailed information:
Video playback:
MPEG-4 (ASP@L5 AVI, up to DVD resolution)
WMV (MP@ML, up to DVD resolution) including WMV protected files
M-JPEG (Motion JPEG Video) in QVGA resolution
With optional plug-in (downloadable from your tablet on www.ARCHOS.com):
HD support: MPEG-4 (ASP 720p) & WMV HD (MP 720p)
H.264 up to DVD resolution with AAC
MPEG-2 MP@ML up to 10 Mbps (up to DVD resolution) and AC3 stereo sound (5.1)
Audio playback:
Stereo MP3 decoding @ 30-320 Kbits/s CBR & VBR, WMA, Protected WMA, WMA pro 5.1, WAV (PCM/ADPCM)
AC3 stereo audio and 5.1 sound files (via SPDIF output of DVR Station)
Flac and OGG Vorbis audio files
With optional software plug-ins (downloadable from your tablet on www.ARCHOS.com):
AAC, AAC+ stereo audio files
Obviously, the ARCHOS 7 supported file formats are limited, if you want to watch you various video files and unprotected DVDs on it successfully, format conversion is necessary. By now, Pavtube Video Converter would be a good assistant for you. It is able to help you convert videos from DVs or camcorders (JVC, Panasonic, Cannon, Sony, etc.), TiVo (*.tivo), DVDs (*.vob), YouTube (*.flv, *.f4v), *.mts, *.m2ts, *.mkv, etc. to ARCHOS 7 compatible format. You can look through its step by step guide as below.
Step 1: Run Pavtube Video Converter, and click "Add" button to load video files to it
Step 2: Select output format for ARCHOS 7
Click on the pull down menu of "Format" firstly, and then select "Archos", after that, all the profiles for Archos will be listed out, here I choose "Archos 5/7 WMV Video (*.wmv) for example.
Step 3: Specify destination folder
Click on the folder icon at the end of "Output" to specify where to locate the output files.
Step 4: Click on "Settings" button to adjust audio and video parameters
Actually, the default settings can basically satisfy your ARCHOS 7, but if you want to have your own changes, you can adjust all the items like codec, aspect ratio, frame rate, sample rate, bit rate, and audio channel in the following window:
Step 5: Click "Convert" button to start conversion
Once conversion is finished, the output files can be found out via clicking on "Open" button with ease. Afterwards, just enjoy them on your ARCHOS 7 freely.
For more: http://www.pavtube.com/video_converter/
Televison & Video Logo
How do I change my LG 4k to a higher resolution.
You cannot change anything from the tv side. TV automatically select the resolution based on the content you are playing. Play a 4K video the tv will take care of it.
Jan 29, 2015 | LG 65LA9700 65" 3D 1080p LED-LCD TV - 16:9...
Bought an Archos 7 Home Tablet Yesterday and the screen is all in GERMAN how do I get it to display in ENGLISH I was not given the option to go to any setup mode date time and language were already set up in German please help
You should get to the "language and region settings" from the menu, and choose a language. If you see everything in german, the help I can give you at first that language means german as "sprache".
If this is not enough you should need a dictionary or a web-translator page on the internet.
Here is the user manual of your item:
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
gylacz
Mar 03, 2011 | Archos 7 Digital Media Player
hi ive been offered a techwood twp4210 plasma tv and i have a couple of questions can you advise if this is hd ready also how old are they, have also been advised that on start up it shows green sparkles is this serious thanks
The unit was being manufactured in the early to mid 2000's but I believe is not out of production. It is NOT an HDV. Here are the specs for the TV.
Product details Manufacturer Techwood Built-in Sat-Tuner No Compact Flash Card No Digital Tuner without Digital Tuner DVD Player / Recorder No HDTV Norm No Loudspeakers without Loudspeakers Memory Stick No Multi Channel Receiver without Multi Channel Receiver Type No Multimedia Card No PCMCIA Interface No Common Interface Slot No DVB-C No DVB-S No Screen Format 16:9 Screen Size in cm 106 cm DVI Interface No Electronic Program Guide (EPG) No Screen Size in Inches 42 in Secure Digital Card No Energy Savings Trust Feature No HD Tuner No Smart Media Card No Type of Monitor Plasma Display, Plasma Horizontal Resolution in Pixel 852 PC Interface No Vertical Resolution in Pixel 480 Brightness in Candela/m² 650 HDMI Interface without HDMI Full HD without Full HD (1080p) DVB-T without Digital Tuner HD ready Not HD Ready LED Backlight without LED Backlight DLNA certified No Energy Saving Trust Feature No HDMI No HDTV No Internet Access NO WEB CONTENT ACCESS EAN 5017416142205, 5017416183666
Nov 19, 2009 | Televison & Video
before i buy it i need to know if i need a broadband dongle to connect the archos 5g to the internet
The Archos 5g should have 3g access to get on the internet as long as you get the Archos through a service provider. Where are you located?
Archos.com information:
The ARCHOS 5g does even better. Not only do you have an uncompromised web experience, but you can have it all-day, everyday. Surfing the web is now completely seamless.
You can watch online video or download movies or music albums from the Media Club even when you’re in the train. With its high storage capacity, you surely can download a lot ! And since the 3.5G network provides the same navigation comfort as your home broadband connection, you will hardly notice any difference.
All of this without compromising the essential features of the ARCHOS Internet Media Tablet.
You can store and play all your digital library in high definition quality. And since it is an ARCHOS 5, you can connect it to a DVR Station, and record TV. Just like that.
Dec 12, 2008 | Archos Internet Media Tablet MP3 Player
connecting to a tv
YOU NEED TO GO TO SETTINGS ANDCHANGE THE PLAY MODE TO PAL FORMAT
Feb 11, 2008 | Archos 605 WiFi Digital Media Player
1,039 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
