Tip & How-To about Computers & Internet
Without purchasing new disc burning software, there are actually 3 ways to burn CDs & DVDs in your Mac OS X system (Mac OS X 10.3-10.6)
There are methods using Finder and Disk Utility.
Both are easy to do and when set up to use will have you burning music, video, data, and image files (ISO) to CDs or DVDs in no time at all.
BURNING DISKS WITH FINDER
1.) Create a Burn folder and burn a CD/DVD
* The easiest way to burn a disc with Finder is to create a Burn folder with Finder. Here's how you do that:
* Click on any blank space on your desktop and in an instant, Finder will appear on the Apple menu bar next to the Apple menu icon.
• Click on File and select from the drop down menu
* This distinctive folder will now appear on your Desktop
* Now insert a blank CD or DVD and in moments, you will see this window pop up:
• Just click the OK button.
* In a few more moments
on your desktop, you will see this Untitled DVD (or "CD: for CD-ROM Disks) icon:
• Now you can either drag and drop files into the folder, or just double-click the folder and also drag and drop files into the open Burn Folder window
* If you notice, each file you drag (or copy and paste) into the Burn Folder window will have a small curved arrow at the bottom left corner of the file.
That is merely a designation that the file is a image of the actual file and ready to be burned to the CD or DVD you use.
* Notice the Burn button (highlighted in the red box). This is the button you will press, to commence the burn (or copying) of the data you have placed in the burn folder to be copied to disk.
• Click the Burn button, name your disk and that is all it takes. When the process is complete, you will now see a formerly Untitled Disk icon on your desktop replaced with a "Your_new_disc_name" DVD.
(Additional Note: If you wish, you can also simply bypass creating a Burn folder, insert a blank CD or DVD and simply drag and drop or copy and paste files into the open window of the Untitled CD as well.)
BURNING A DISC WITH DISK UTILITY
There are actually two ways to burn data to an DVD or CD with Disk Utility:
1.) Burn a disk in Disk Utility
* Simply open Disk Utility by either clicking anywhere on a blank space on your Desktop window and Finder will appear near your Apple menu, select Go >Utilities and that will take you to the Utilities Folder which is the default location of the Disk Utility application.
* Or you can click the Finder icon on your Dock, open a new Finder window, click on "Applications" listed in the side window and select the Utilities folder
* Either way, you will land here.
• Insert your CD or DVD.
* Once you open Disk Utility, you will see this main window
* Now all you need to do is click the "Burn" button located on the Disk Utility toolbar.
* For an example, I am striving to burn a copy of my Quicken .dmg file to CD.
* Once I have selected the file, then I click the Burn button located at the bottom right corner of the Finder window.
* Follow the onscreen instructions to start the burn process.
2. Creating a multi-session disk using Disk Utility:
Now it is known, that one cannot burn more than once with a single CD-R disc, but it can be done as provide from the knowledge base of Apple support:
you could use this burnaware its totally free if you dont like it just uninstall it also there are plenty of free burning sofware cnetdownload.com or majorgeeks
http://www.majorgeeks.com/BurnAware_Free_d5839.html http://www.majorgeeks.com/CDBurnerXP_d4242.html Active ISO Burner
will allow you to burn an ISO image file to CD-R, CD-RW, DVD-R, DVD+R, DVD+R
DL(Dual Layer), DVD-RW and DVD+RW (including double layer, DL). Active@ ISO
Burner software accepts command line parameters to automate ISO images burning
process. Burn audio, video,
and data CDs/DVDs and create and burn ISO files. Instant CD & DVD Burner is
the ideal choice for anyone looking for a simple but full featured CD/DVD
burner. Build and burn ISO files on the fly and compile all kinds of audio,
video, and data CDs and DVDs from any kind of file (MP3, WAV, AVI, MPEG, DIVX,
XVID). Instant CD & DVD Burner supports all major drives including CD-R,
CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM (SCSI, IDE, EIDE, and USB 1.0
and 2.0). Burn4Free CD and DVD
is a burning solution that's compatible with more than 3,000 DVD, Blu-ray and
CD burners. Burn data and audio from different file types (WAV, WMA, MP3, OGG,
FLAC, WavPack, and CDA). Burn and save ISO files, open and save your project to
disk, verify content, print compilations, copy DVD, copy BLU RAY and import
your audio compilation from M3U and ASX playlists. The drives supported include
dual-layer DVD, CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM, BD-R,
BD-RE (SCSI, IDE, EIDE, and USB 1.0 and 2.0). http://download.cnet.com/burnaware-free/3000-2646_4-10878661.html?tag=mncol;8 BurnAware Free is a
full-fledged disc burning tool - fast, lightweight, feature-packed and, most
importantly, 100% free. The program burns all types of CD, DVD and Blu-Ray
discs containing data, digital photos, music and video. With BurnAware Free,
you will be able to create bootable or multi session CDs and DVDs, high-quality
audio CDs from your collection of MP3, WAV, WMA, OGG, M4A, AAC and FLAC files,
burn disc images, copy discs to backup ISO images and do a whole lot more. Multi-disc file
backup and restore on CDs, DVDs and Blu-ray discs; create compressed backup
archives with powerful password protection; split archives automatically across
multiple CDs, DVDs or Blu-ray discs; restore archive contents to their original
locations; integrated Audio CD ripper store your audio tracks as WMA or WAV
files; new option for setting the number of copies you want to burn (available
for all disc formats); discs can now be verified immediately without being
ejected first (if the drive supports this feature); numerous other small
improvements that make the program easier to use and more effective; burn files
and folders on data CDs/DVDs/Blu-ray discs; burn Audio CDs from WAV, MP3, FLAC,
WMA and Ogg Vorbis files; burn MP3-CDs from your MP3 files; burn Video DVD,
Video CD (VCD) or Super Video CD (S-VCD); create and burn CD/DVD/Blu-ray disc
images; burn speed and other options can all be set automatically. Macrium Reflect Free Edition. An
award winning disk imaging solution for free. A complete disaster recovery
solution for your home and office. Protect your personal documents, photos,
music and e-mails. Upgrade your hard disk or try new operating systems in the
safe knowledge that everything is securely saved in an easily recovered backup
file. Macrium Reflect supports backup to local, network and USB drives as well
as burning to all DVD formats. This version is for non-commercial home use.
BurnAware Free is one of the most popular free
CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and
DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
http://download.cnet.com/active-iso-burner/3000-2646_4-10602452.html
http://download.cnet.com/instant-cd-dvd-burner/3000-2646_4-10393316.html
http://download.cnet.com/burn4free-cd-and-dvd/3000-2646_4-10217894.html
http://download.cnet.com/Ashampoo-Burning-Studio-Free/3000-2646_4-10776287.html
http://download.cnet.com/Macrium-Reflect-Free/3000-2242_4-10845728.html
http://download.cnet.com/ImgBurn/3000-2646_4-10847481.html
ImgBurn is a lightweight
CD/DVD/HD-DVD/Blu-ray burning application that has several modes, each for
performing a different task: Read - read a disc to an image file; Build -
creates an image file from files on your computer or network (you also can
write the files directly to a disc); Write - write an image file to a disc;
Verify - ensure that a disc is 100% readable (you can also have ImgBurn compare
it against a given image file to ensure the actual data is correct); and
Discovery - used in combination with DVDInfoPro, you can check the quality of
the burns your drive is producing.
