Tip & How-To about Computers & Internet
Acer Aspire One WiFi FIX.
The Aspire One is a great machine that, for me, was mildly crippled by a finicky Wi-Fi connection. There has been some discussion about this on other parts of the web. For some people, the actual wireless module turns on and off occasionally. For other people, the wireless connects and works just fine, but then won't work for a few minutes - but doesn't disconnect from the router. After a brief wait, the internet works again.
This was a bit frustrating. I had the problem of the module remaining connected but not working. Fooling with various settings helped, but it was still not as good as it should be, so I decided to replace the module with an Intel 4965AGN wireless module. This is the easiest fix for those who have this problem and have been frustrated by a solution. I say "easy," because it was easy to spend $35 for the module on eBay and install it, rather than spend another 3 hours fiddling with the settings.
I followed the disassembly guide here to take the keyboard and top panel off. This guide is great, and the author did a nice job with the descriptions.
http://www.aspireoneuser.com/forum/v...hp?f=40&t=1443
It was a really easy operation to crack the case open. I then removed the Atheros and replaced it with the Intel 4965 card. Here's where the easiness comes in.
If you look at that guide above, after installing the card, he has you removing all sorts of other parts just to run the new antenna wires. (The Intel card has three antenna jacks, the Atheros only two.) There is really no reason to do this unless you are really serious about having diversity reception. The Intel card will work just fine with only two antennas.
The antenna leads that you remove from the Atheros have the same connector as the Intel card, so just go with the two leads instead. Then you don't have to take apart your screen and all of the other tricky parts. Now, you won't get true Wireless-n without the third antenna, but reception overall seems better with the Intel card, and the Intel card does not get as hot as the Atheros. (Which is kind of nice, since the card is under your right palm. And actually, the Intel card does not get hot at all.) And you can connect to a Wireless-n device, which is not possible with the Atheros.
Also, the Intel card works properly with the hardware on/off switch. No problems there.
A couple of tips. Before you install the Intel card, remove the Atheros drivers and software from your AAO. You can use Add/Remove if you do this BEFORE you pull the Atheros card. Otherwise, Windows wants you to reinstall the card before you remove the drivers.
Also, when you take the AAO apart, use a credit card or other thin piece of plastic to push in the tabs on the keyboard. This saves you from scratches if you use a metal tool.
I hope these suggestions help anyone who is looking to do this easy mod. I wouldn't have added the new card if I had to go through the complete disassembly to add the third antenna, but this is not a necessary step. The new card completely solves the finicky internet problem. For some reason, the Atheros just does not work well with the Acer hardware.
Computers & Internet Logo
How can I get my acer aspire one mini laptop to access wifi?
Connecting your Acer laptop to your home wireless network is fairly simple. Before you begin you need to know the SSID broadcast name (Wi-Fi) network name and security passphrase (Wi-Fi network password).
Move the Wi-Fi switch to the "On" position. Not all models have this switch. Open the Windows Start menu and select "Connect To." A list of available connections will appear. Select "All" from the drop-down menu to view all available networks and connections within range. Select the desired network and click "Connect." Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access.
Wireless configuration for your laptop http://en.kioskea.net/faq/294-wi-fi-wireless-configuration-for-your-laptop - for-acer-users
Feb 21, 2013 | Acer Aspire One AOA150-1949 Laptop
does acer aspire 5742 have wi-fi
Actually, Wi-Fi is another term for Wireless Network. Well, the answer to you question is Yes, it is a wi-fi ready machine. You don't need any additional hardware to access a Wi-Fi network, in other words, it is a wi-fi certified machine. Hope this helps.
Good Luck.
Thanks for using FixYa.
Apr 11, 2011 | Acer Aspire 5742Z-4200 Notebook
im using acer aspire one za3 and cant connect to wifi..wifi does not work
Feb 23, 2010 | Acer Aspire One PC Notebook
how do i switch on wi-fi on my acer aspire 5735 laptop ?
Check in your laptop you find wi fi switch turn it on.
then check in device manager that your wi fi driver is installed and enable.
then view for wi fi networks then you find your router if it is in range connect into it.
let me know if you need more assistanse.
Thanks.
Sep 19, 2009 | Acer Aspire 5735 Notebook
393 people viewed this tip
David Payne
David Payne
