Tip & How-To about Audio Players & Recorders
Fixing sound.
If your sound does not work and the little speaker icon by your clock does not appear and your computer says no sound device. Simply download soundmax for free and install, this should solve your problem.
my speakers say they are plugged in but they dont make any sounds.what should i do?
if you do not see the little speaker by your clock, or even if you do but they still dont work. go to download.com type in soundmax and download this and install it this will definitly work.
Feb 23, 2010 | Audio Players & Recorders
No sound
First off, check to make sure the sound is not muted. check the speaker icon next to the clock or the sound properties in control panel. If it is not muted then download this driver: http://www.soft32download.com/software/free-download-IBM-ThinkPad-R40-Audio-driver.html
Jun 16, 2009 | Lenovo ThinkPad R51
How do I setup the SoundMAX device for AUX line-out?
The cable from the computer simply needs to be plugged in to the speaker/headphone jack on the computer, then run to the AUX input on the amp. Make sure the volume on the computer is set to about 75% - 90%.
Apr 07, 2017 | NAD C320 2-Channel Amplifier
No sound but it beeps
plz reinstall your sound drivers from the mother board cd,if after installing also no sound then you post back with your motherboard make and model no,
Jun 23, 2008 | IBM NETVISTA M42 - P4 2.4GHZ/512KB 256MB...
my mic is detected... sort of
All you have to do is right click on the speaker icon which is next to the soundmax icon in the taskbar and select the" ADJUST AUDIO PROPERTIES"
Now select the voice tab and in that under the VOIC3E RECORDING click on vloume and make sure the microphone volume is full now close it and click on Test Hardware.
Goodluck.
May 18, 2008 | Baby Gear
912 people viewed this tip
 Grubhead
Grubhead
