Tip & How-To about Dryers
Saving money drying clothes
The biggest thing to remember about your clothes dryer is that it has to get the moisture out. If you keep your venting clean it will aid your dryer in shorter drying times. The more heated dry air it can pull through wet clothes while they are tumbling the faster clothes will dry.
If the venting is restricted by lint or kinked, or low quality venting, all end up costing more in drying times. Use good venting, preferably steel, and do use the proper vent cap on the outside wall.(check lint does not catch here also)Many service calls could be prevented by regular maintenance of venting.( thermal safety fuses which all dryers have are the reason for most service repair calls when the venting has not been cleaned) Also the shorter distance your dryer is vented, the better.
The second less obvious problem is not cleaning the lint screen. All the air or almost all passes through this screen before being exhausted outside. You need to clean the lint first. Second you need to wash the lint screen in the sink to clean off any build up of fabric softener that can also cause slow drying. Water should run straight through the metal mesh, if it ponds it is coated with softener, and water should wash this off.(I have been on service calls where dryers were not drying correctly and just washing off the lint screen of fabric softener fixed the problem)
Lastly wiping the two short parallel bars about three inches long found inside the dryer with alcohol to remove any fabric softener or other coating will keep the automatic cycle working right.Not all dryers use these........
Before thermistors, when thermostats were all that was out there.........
Hope this saves you some money and time.......
Dryers Logo
whirlpool duet electric dryer leaking water
Check and clean your venting from the dryer to the outside. If it is plugged it will trap the moisture in the machine. Remember heat doesn't dry the clothes without air flow to push the moisture out.
Mar 04, 2013 | Whirlpool Dryers
Dryer not turning off when clothes are dry (model LDE 400ACL)
Normally if you have an automatic cycle that turns off the dryer when the clothes are dry, it will do it with a special thermostat or moisture-sensing system. The thermostat tells the dryer to heat until the interior of the dryer reaches a "pre-set" temperature.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. If there is a moisture sensor, the timer advances only if the moisture content of the clothing is low enough. The timer advances until the interior cools, then the termostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But... if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix this problem, clean the vent and/or internal ductwork and make sure the vent is not compressed or kinked. If that doesn't work, then your thermostat, moisture sensor or timer could be the culprit.
Jul 15, 2009 | Dryers
Dryer will not turn off
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 20, 2009 | Dryers
new dryer, not drying clothes, vents cleaned, old dryer worked ok
repl/ thermistor and coils,,, remember these machines have moisture sensors,,,,,,,
Dec 30, 2008 | Kenmore Elite HE4 Electric Dryer
178 people viewed this tip
Top Dryers Experts
