Tip & How-To about Video Game Consoles & Games
Wii remotes no long respond (one or more remotes) - sync lost
Lately after firmware updates or power loss the Wii will un-pair from the Wiimotes. Some players don't know how to solve this problem. They assume it is the Wii or the batteries in the Wiimote but when they switch them or power off the unit, this doesn't fix it. Reason is that the Wiimotes need to be re-paired (re-synced). This Tip will explain how to do this.
1) In the front of the Wii there is a door. Inside this door you will find the SD card slot. next to the SD card slot there is a RED button with the word "Sync" on it. This is used to put the Wii in bluetooth discovery mode.
2) Take the first remote and remove the battery cover. Below the batteries is a small Red dot button. This is the Wiimote's connection button. First turn on the Wii then press and hold the Wii's Sync button for a few seconds to initiate Discovery Mode. Press and hold the Wiimote's button for a few seconds until the "Player Number" lights on the bottom of the front of the remote blink. The connection is complete when the Wiimote's "Player 1" light goes solid and the Wii will advance to the menu.
3) To re-sync (re-pair) the additional Wiimote's. Repeat the process but this time leave the Wii turned on. With each remote the next player light should turn on. Do this until each remote is synced.
Video Game Consoles & Games Logo
My remotes do not come up on tv.
press and hold the red button under the flap on the wii for 30 seconds, this will wipe all pairings you have had for remotes and wii fit board, etc then repair your wiimotes by pressing the red button on the wiimote and the one under the flap. then you should be able to pair the wiimotes. IF this doesnt work then your bluetooth board in the wii maybe bad and need replacing
Apr 10, 2011 | Video Game Consoles & Games
I cannot connect to wii console with remotes
In case you don't know how to do this: 1) Open the small door in the front of the Wii, and next to the SD card slot is a red sync button. 2) Take the back off your Wiimote and on the button right is a small red button. 3) Press the button on the Wiimote then the button on the Wii, this should sync the controllers.
Now sometimes this doesn't work. It happens to almost everyone. All of a sudden the Wiimotes just loose to sync, but after a long period of time they start working again. From what I know there is nothing you can do about this. But here are some things that you can try:
1) Unplug your Wii then plug it back in. 2) Try new batteries in your Wiimotes. 3) Keep trying to sync the Wiimotes. 4) Try to sync them in someone else's Wii, and then yours.
Sep 19, 2010 | Nintendo Wii Console
can't get 2nd player working on Indiana Jones Lego Wii game
The thing to get the two Wiimotes to work is to press the reset button on the Wii and on all the Wiimotes at the ame time. If you after that restart the Wii, it should automatically connect to both Wiimotes when you press A on them. If you then luanch the game, the two Wiimotes should still be connected. If not, just press A again. Then press whatever button you ned for multiplayer (+ I believe) and you shold now have 2 players. I hopethis helps, Yannick.
Jun 10, 2009 | LucasArts Entertainment Company Lego...
wii games that worked fine could have future problems
It is possible that you updated your Wii with a new firmware that was available on one of the game disks. Some modifications do not work anymore after a firmware update. So it might be possible that you have an older modification that Nintendo overrides with a new installed firmware.
It is almost sure that when you remove the modification completely, your Wii is working fine. If so, install a recent modification that is immune for these firmware tricks, dor example the D2Sun
Nov 28, 2008 | Nintendo Wii Console
i have had to borrow a wii as mine has been sent away for repair, can you tell me how to pair the remotes with the new wii please
to pair remotes with the Wii. There is a small Red button within the Battery compartment of the Wiimotes, and there is also a Sync Button on the Wii. Pressing these buttons at around the same time will allow the Devices to sync
Oct 27, 2008 | Nintendo Video Game Consoles & Games
440 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
