Tip & How-To about Computers & Internet
Fix calibration of CD/DVD drive - no disc error
Many times people complain that their optical drive in their PC, XBox, PS, DVD Player, etc does not read any disc they put in to it. The cause of this is usually a dirty lens but can also be related to a drive whose laser is starting to weaken.
Most, not all, optical devices have one or more laser calibration screws. CD players have 1, DVD drives has 2 (one for Cd's and one for DVD's). Turning these screws in the correct direction with increments will resolve more disc read issue not solved by cleaning the lens. This article will explain how to do this on a PC optical drive which can be applied to other drives as well.
1) First thing you need to do is shut the PC off.
2) Next you will need to remove the unit from the PC. To do this you open your computer case and then remove the screws from the drive as-well-as the cables. Then pull the drive out.
3) Almost all units have 4 screws on the bottom of the unit close to the 4 corners. Remove these screws and move to the side.
4) This step requires a paper clip or stiff pin like object about 2 inches long. In the front of the drive you will see a little pin hole, usually on the right side. Put the paper clip into it and push. This will manually release the drive tray. Pull the drive tray all the way out til it stops.
5) Depending on the drive this step will vary but we will use the most common. On the left and right of the drive are clips for the face plate. Push those in and pull gently on the face play toward the tray. Then on top of the drive there is another clip. Press this one in. Once the face plate moves, pull it to the end of the drive tray.
6) Now you can remove the top cover, this may take a little work. Some drives have the top partially clipped on to the drive inner workings.
7) Once inside you will need to study your unit's circuit board to see how it comes off and remove it.
8) Now look at the laser device. Study the device on the top back and bottom and look for 1 screw for CD and 2 for DVD. The 2 screws will be right next to each other about a 1/4 inch in most units. These screws are small and require a tiny flat head to move. Some allow phillips. Since each unit is different I opted not to provide a picture. The screw will be close to a small trace or ribbon. This is my best way to tell you where it is located.
9) Most increase calibration by turning to the right (clockwise). If this doesn't work try going left (counter-clockwise). Turn the screw a 1/4 turn.
10) Place the board back on and place the top cover over it. The top cover is needed for testing because it contains the disc guide for spin-up.
11) Use some plastic to insulate the bottom of the unit and hook it to the PC then boot up. Test the drive. If it works shut off the PC and reassemble the unit. If not repeat the calibration process in #9 until the unit works.
If the calibration does not work or is already all the way up, the unit will need to be replaced. Typically you can get 1-2 tuneups per unit this way til you need a new laser or unit.
Good Luck
Computers & Internet Logo
everytime i put a disc in my xbox it reads dvd. I got to keep ejecting it and closing it back to make it read the game . Pleasee!!!!!!!!!!!!!!! help me
Just to make certain it's not a burnt game on a modded/flashed xbox then more likely your optical dvd drive on the DVD player for the xbox 360 is going out. The lens and laser can be acting up inside and the only way to fix this is to replace the optical dvd drive. You can remove the optical drive and it has 4 screws. You carefully remove the chip inside and transfer to new xbox 360 optical drive which by the way has to be the exact same model to work properly. There are detailed instructions on youtube on how to remove and replace a xbox 360 dvd player.
Dec 22, 2010 | Microsoft Xbox 360 Console
discs cant be read
If you are getting this it is the sensors on the back of the drive overheating you can use the video Xbox 360 repair guide or send it in
Jul 11, 2010 | Microsoft Xbox 360 Console
my 360 will not read my disc even tho they are clean
The optical drive on the xbox wears over time. Call 1-800-4MYXBOX and get a repair scheduled.
Aug 03, 2009 | Microsoft Xbox 360 Console
dvd drive not reading a disc
If this happens with every disc, then your drive needs fixing/cleaning or replacement. If it only happens with a specific disc such as your game, then something's wrong with the disc. If it's a homemade DVD you may be dealing with copy protection. Try cleaning the disc and the player. Try the disc in another computer.
Jul 08, 2009 | Dell Dimension XPS 400 PC Desktop
won't read disc's
HI. this is being caused by a damaged optical lens assembly. you have two choices here. you can opt to replace the entire DVD-ROM drive or, you can replace the optical assembly.
we recommend replacing the entire DVD ROM drive. this is much easier and, its just plug-n-play.
Mar 27, 2009 | Microsoft XBOX 360 ARCADE Console
7,718 people viewed this tip
David Payne
David Payne
