Tip & How-To about Audio Players & Recorders
Installing a fllat screen tv on the wall
We have found many people facing the bodacious task of mounting a large or medium flat screen on a wall. The following should help considerably.
You Will need a helper so know one gets injured. Attach the brackets to the Wall using heavy duty 3/8 x 3 long lag bolts. Use a level for straightness.
If you wish to hide your wires behind a wall for a much nicer set up.
Drill a hole in between the bracket centers on the wall and then use a electricians fish tape to run the rest of your wires. You may repeat this step for speaker wires.
Last thing is to lift your unit up onto the bracket. Danger- This TV can be very bulky and heavy. Place your wires through the holes first before hanging.
Plug in your HDMI cable to the Flat Panel and route to the manufacturer's designated component.
remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
Omnimount tv mount strong enough to hold?
Even though there is a significant weight difference, your Omnimount might not be adaptable but I advise working carefully if you try it to avoid an expensive crash.
Nov 09, 2013 | OmniMount FP-CL Medium Cantilever Mount...
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Dec 19, 2010 | Toshiba REGZA 46RV530U LCD TV
how to setup my flat tv in the wall?
Any of the "big box" stores that sell large-screen LCD/LED/PLASMA TVs will also sell the wall-mount units.
Or, try 'www.eBay.com'.
Nov 14, 2009 | Samsung SyncMaster T260HD flat panel TFT...
need wall mount
If you are in Australia, ALDI is offering a wall mount bracket for large screen tv;s up to 100KGS the price is $50. Available on www.aldi.com.au
Mar 26, 2009 | Televison & Video
124 people viewed this tip
 Grubhead
Grubhead
