Tip & How-To about Computers & Internet
CARE FOR YOUR PC MONITORS AND LAPTOP SCREEN
The monitor is a very essential part of the computer which plays a major role in displaying every data/ actions done by the computer in a way we can read, understand and appreciate with the use of colors, writings and drawings
TIPS ON PCS MONITORS AND LAPTOPS SCREEN CARE
* Do not place a magnet or any appliance that have a magnet close to your pc monitor because it will cause some color distortions to that part of the monitors that effect may not be reversible
* If the pc monitor displays “ NO SIGNAL “ on the screen or those not display any thing when booting , check the connection CABLE and make sure it is properly connected or change it if it is rusted.
* Do not place your monitors or laptops on tables with wheels to prevent accident.
* Do not spill solvents or liquids on your pcs monitors or laptop screens.
* To prevent radiations from your monitor always use the screen shield.
* Handle you laptops with care ,do not drop it or sit on it or press the screen.
* The laptop screen uses liquid crystal display (LCD) technology which makes them very fragile , always handle it with care because it is very expensive to replace a fault part.
* Store your laptops in well padded bags to prevent damage to it when it is being transported.
Computers & Internet Logo
i have 1 gb thumbdrive and i want to make a small partition about 2mb in my thumbdrive for my machine...this machine can read 3 binary numbe only.........................
http://www.filehoo.com/download/Partition-Magic-8,0.aspx
Partition Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your computer-preventing conflicts, protecting data, improving efficiency, and increasing performance.
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems. Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
hope this helps
Apr 28, 2011 | Computers & Internet
vertical lines on inspiron 9300 laptop lcd
The possible reasons for this could be;
1.)A loose connection between either the graphics card and the computer mainboard or between the Graphics Card and the Computer Monitor.
2.)Your LCD monitor has become faulty and either needs to be repaired by a technician or replaced.
3.)Your graphics card need to be cleaned, clean the gold finger contact on the card.
However in my experience I would say that the monitor has become faulty, try this monitor on another computer and if it still displays vertical lines then you know that this is the case.
If your monitor works on another computer then I would say that your computer or Graphics card is having some troubles.
Overheating plays an important role here.
Kind Regards
damnor01
Feb 03, 2011 | Dell E173FPb 17" TFT LCD Monitor
power supply done but display is not
Symptom : No Image on the screen. I cannot turn on the monitor.
Checklist 1 : Is the power connected properly ?
Action : Check the power cord connection and supply.
Checklist 2 : Can you see "No Connection. Check Signal Cable" on the screen ?
Action : Check the signal cable connection.
Checklist 3 : If the power is on, reboot the computer to see the initial screen ( the login screen), which can be seen.
Action : * If the initial screen (the login screen appears, boot the computer in the applicable mode (the safe mode for Windows 98/95) and then change the frequency of the video card.
* Note : If the initial screen ( the login screen) does not appear, contact a service center or your dealer.
Sympton : I cannot see the ON Screen Display.
Checklist : Have you locked the On Screen Display (OSD) Menu to prevent changes ?
Action : Unlock the OSD by pressing the MENU button for atleast 10 seconds.
Hope this helps.
Have a good day.
Dec 08, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
I want to connect a Ultrasharp 1907 FPt monitor to my Dell inspiron. I have a power cable and also one from monitor to lappy, do I need a driver?
to toggle the screen between your laptop and the dell 19" monitor. Hold down the Fn key on the laptop and tap the F8 key. The screen would move to the external display.
There are three settings that can be done by the Fn + F8 key combination
1. Both the laptop and external monitor works
2. Only the external monitor would work
3. Only the laptop screen works
Thanks
Proton
Nov 04, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
122 people viewed this tip
David Payne
David Payne
