Tip & How-To about Computers & Internet
How to change your drive letter in Windows XP
1. Right click on your "My Computer" icon and select Manage.
Note you can also right click on the "My Computer" icon from your Start Menu.
2. Next click on "Storage" and then "Disk Management"
3. Next right click on the drive you want to change the drive letter on and click on "Change Drive Letter and Paths".
4. Next click on the "Change" button
5. Next click on the letter drop down on the right. Note you can change the drive letter to any letter that is not already used. However in most cases you will not beable to use letters A-D but E-Z should be open for you to select.
Also note if you are needing to change a drive letter to something that a device requires you to select but it is being used by another device you will have to move the other device to another letter first.
6. After selecting the drive letter click OK.
Note the below message come up. So as long as you are on changing the drive letter of a CD-ROM or Harddrive then you can just click YES. Keep in mind that if a program was installed from this the drive that you changed the drive letter of to be able to use that program you may need to reinstall and/or redirect the program to the new drive letter.
7. At this point the drive should be changed. Close out of Computer Management and reboot your computer to make sure your change takes full effect.
Note the steps for Windows Vista and Windows 7 are pretty much the same however if you go to the below link you can see the steps along with the screen shots of the menus.
http://www.fixya.com/support/r4176803-change_drive_letter_in_windows_vista
Computers & Internet Logo
my drive is brand new, unused, when I click on the Start button, then Computer, I see the newly attached iomega drive as a CD Drive. so far so good. But when I RIGHT click on the iomega drive, chose Properties, I see that the entire drive is USED UP even though I've put nothing on it. when I try to drag something onto the disk, it says there's not enough room on the drive. Q. How can I clear the drive so it's ready to use?
As long as it is just the USB 3.0 and not the USB 3.0 with encryption. You will just need to format your drive.
Windows 7 / Vista 1. Connect the Iomega Hard Drive to the USB on the computer. 2. Next, open Disk Management. (Right click on the Computer icon > select Manage > click Storage > select Disk Management ) 3. You will see a prompt indicating you must initialize a disk before Logical Disk Manager can access it. The disk will be selected by default. Read the note at the bottom of the window and select the partition style you want to use. 4. Click OK. 5. The drive will now appear as Unallocated and the bar will be black. Right click on the black bar and select New Simple Volume. 6. When the New Simple Volume Wizard opens, click Next. 7. It is recommended to leave the maximum disk space selected. Click Next. 8. Assign the next drive letter available. (It is recommended that physical drives are placed before mapped network drives.) Click Next. 9. Windows will automatically select NTFS as the volume format. This is the preferred file system for use with Windows 7, Vista, and XP. 10. Select the option for Perform a quick format, enter a volume label if desired, and click Next, then click Finish. The drive will be ready to use when the format completes.
Windows XP / 2000 1. Connect the Iomega Hard Drive to the USB on the computer. 2. Next, open Windows Disk Management. (Right click on My Computer > select Manage > click on Disk Management ) 3. If the Disk Wizard opens, click Next. Select the disk, click Next, then Finish. If the Wizard does not open, locate the drive in the lower list. Look for a disk that does not show a drive letter or file system. CAUTION! Make sure you select the correct drive before proceeding. The following steps will erase all information from the selected drive. 4. Right click on the drive name and select Initialize Disk (Windows XP) or Write Signature (Windows 2000), then click OK. NOTE: If the options listed above are not available, you might need to delete the primary partition. 5. The drive will now appear as Unallocated and the bar will be black. Right click on the black bar and select New Partition (Windows XP) or Create Partition (Windows 2000). 6. When the Create Partition Wizard opens, click Next. 7. Verify that the partition type is Primary partition and click Next. 8. It is recommended to leave the maximum disk space selected. Click Next. 9. Assign the next drive letter available. (It is recommended that physical drives are placed before mapped network drives.) Click Next. 10. Select the option for Perform a quick format, click Next, then click Finish.
Nov 25, 2010 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
hard drive needs to show as f instead of g on computer when plugged into usb
Connect your harddrive to computer then when you power up the computer press F8 key then enter in safe mode.
Then it fix messup .
If still not show as G then right click on my computer icon then click on manage.
Then click on storage->removable storage or disk management there you can see your drive icon right click on it then change drive letter.
Nov 17, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
how to i change the drive f back into what it was now dvd rw
If you are using Windows XP.
1. Find the 'My Computer' icon (usually located in our Start Menu)
2. Right-Click on 'My Computer' and select 'Manage'
3. Click on 'Disk Management'
4. In the bottom-right list, Right-Click the drive you want to change and select 'Change Drive Letter and Paths..."
5. Click "Change..."
6. Select a new drive letter and hit 'Ok'
7. Click 'Yes' to the warning that pops up after
You're done.
If you use Windows Vista, figure 1 below shows you how.
Figure 1:
Changing Drive Letters in Windows Vista
(http://pcsupport.about.com/od/windowsvista/ht/chdrlettervista.htm)
Here's How:
  1. Click on Start and then Control Panel.
    Tip: In a hurry? Type computer management in the search box after clicking Start. Choose Computer Management from the list of results and then skip to Step 4.
  2. Click on the System and Maintenance link.
    Note: If you're viewing the Classic View of Control Panel, you won't see this link. Simply double-click on the Administrative Tools icon and proceed to Step 4.
  3. Click on the Administrative Tools link.
  4. In the Administrative Tools window, open the Computer Management program.
  5. In the Computer Management window, locate the Disk Management option on the left and left-click on it.
    If the Disk Management option is not visible, look under the Storage option by clicking the small arrow next to the word Storage.
  6. On the right-hand side of the screen, locate and right-click on the drive that you wish to change the drive letter of and choose Change Drive Letter and Paths....
  7. In the Change Drive Letter and Paths window, click on the Change... button.
  8. The Change Drive Letter or Path dialog box will appear. Choose the drive letter you wish to assign to this partition.
    Click OK.
  9. The Confirm window that appears advises you that "Some programs that rely on drive letters might not run correctly. Do you want to continue?".
    Note: If you have software installed to this drive, the softwaremay stop functioning after a drive letter change. Nearly all softwaredefaults to the primary drive though, so this is rarely a concern.
  10. If you're sure you want to make this change, click Yes. Depending on the speed of your PC, the change should be nearly instant.
  11. You can now close the Computer Management and Administrative Tools windows.
Aug 04, 2009 | Teac (DW-224EA-AM6) CD-RW/DVD-ROM (Combo)...
3,639 people viewed this tip
David Payne
David Payne
