Tip & How-To about Computers & Internet
How to extend your laptop battery life
Thousands of people take their laptops on the fly, and unless you don't have a convenient electrical outlet, you can do this simple little trick to as much as double your laptop battery life. Simply, take the battery out (when not required for long periods of time) and keep it in a cool place, or in the refrigerator. Heat is the most damaging thing to things like electronic circuits and components, and by keeping your battery cool, you're extending it's serviceable life. Some say to let it run down to a 40% level, then take it out. Since lithiums don't have a memory, that won't hurt it. The ideal is to have some charge to keep the chemicals active, but not to overcharge it unnecessarily. Oh, and be sure the battery doesn't freeze...and then crack or be damaged.
Computers & Internet Logo
3 hp briggs and stratton misses when hot
it could be the coil, next to the fly wheel, worn out, or needs reset. setting is 13 thousands. or place a business card between it and the fly whee,l tighten up on it tight enough, that the card is hard to remove, but can be pulled out. by sliding it up against the card.
I hope that works, reguardless, please let me know what you do fine out if this don't work.
Luck..
Don Carroll
Aug 06, 2012 | Garden
battery light goes on and off
Your running the alternator on borrowed time as its a matter of time before the battery dies and needs replacement along with the old alternator. The light is indicating something wrong with the electrical system. A simple test at your favorite auto store capable of checking the battery/alternator system will reveal what's wrong or you can perform some simple measurements of battery voltage to determine the issues - the alternator is due for replacement and possibly the battery if it was allowed to operate with the battery light going on and off for a long time otherwise the alternator is on its last legs unless you can find loose connections on the alternator.
Usually alternators wear out; the brushes wear down after so many thousands of miles where they begin to lose physical contact and intermittently turn on the low voltage indicator warning you of electrical power problems. Measuring at the battery terminals should show battery voltage around 12.5v+, engine idling 13.5v+, above idling 14.3v+. If the last two voltages don't vary above battery voltage then the alternator is faulty. Remove it for testing before replacement. With so many miles on it, its due for replacement.
Oct 16, 2011 | BMW 325 Cars & Trucks
151 people viewed this tip
David Payne
David Payne
